Question about NEC MobilePro P300 Pocket PC
Point Tunneling Protocol (PPTP)
Does the P300 support Point Tunneling Protocol (PPTP)?
    Master:
  • 903 Answers
Yes.
Posted on Sep 15, 2005
SOURCE:
What is vpn server
Point-To-Point Tunneling Protocol (PPTP) is another tunneling protocol used to connect a remote client to a private server over the Internet. PPTP is one of the most widely used VPN protocols because of it's straightforward configuration and maintenance and also because it is included with the Windows operating system.
http://electronicshelponline.blogspot.com/ A VPN or Virtual Private Network is a method used to add security and privacy to private and public networks, like WiFi Hotspots and the Internet. VPNs are most often used by corporations to protect sensitive data.
Oct 25, 2016 | Computers & Internet
Teredo Tunneling Pseudo Interface cannot connect or start
If this message is in windows, then it is all driver problems. Try going to the intel website and looking up your motherboard, there should be several drivers in multiple categories to download, or one package, get the newest ones and install them all. Intel Driver Update Utility
Apr 14, 2014 | Intel Desktop Board D845GLVA...
Security concerns & VPN settings
You understand correctly. Your traffic from you to Golden Frog is encrypted both ways - that's why it's called VPN Tunnel. This way the traffic appears to come from them and not from you, so you can't be traced back easily. I say easily because there are ways, but then we're talking about serious knowledge and effort. Think "James Bond" - nothing for the "Household Hacker".
As encryption protocol you should definitely use L2TP with IPSec.
In general there are three protocols: PPTP, L2TP/IPSec, and OpenVPN.
PPTP uses 128-bit RSA encryption, the latter two 256-bit AES. I would choose OpenVPN over L2TP because of the lower overhead and therefore less stress on the CPU when encrypting data.
You should steer away from PPTP since it has serious security issues. First the encryption is done in one step compared to the two-step process in L2TP. Furthermore PPTP is a proprietary protocol using Microsoft's Point-to-Point Encryption protocol MPPE implementing RSA RC4 algorithms.
L2TP on the other hand is using the standardized IPSec protocol. RFC 4835 specifies either the non-proprietary 3DES or AES encryption algorithm for confidentiality. iVPN uses the AES algorithm with 256 bit keys. (AES256 is the first publicly accessible and open cipher approved by the NSA for top secret information.)
If you want to read more about PPTP vulnerability, you can find it here.
Your impression of torrents is not totally correct. The software itself is not virus infected and has it's legitimate use. Example: Most Linux distributions are available as torrents. The reason is that instead of 100,000 people downloading the image from one server, the image is shared between many people, therefore easing the load on the server and keeping the cost down, since you have to pay for traffic as a host.
The general problem with torrents is that they are often used for sharing illegal content or files, usually where the source cannot be determined with certainty. You should always treat downloads from the internet and/or unknown sources with suspicion and let your AV software run a scan.
Any general advice?
One big one for me is to never use Windows OS for my online banking. I might be paranoid, but then I think I worked too hard for my money and rather go through the inconvenience than through the "pain".
General information can be found here.
A wiki containing a list of banks and browsers supporting Linux is here.
A distribution especially designed or online banking called "Bankix" can be found here. The article is in German, but can easily be translated through Google. The main advantages are:
The internal hard drive is not accessible thanks to a patch to the Linux Kernel and the boot media is secured (prevents against Zero Day Exploits.)
Hope that helps.
C.Dante
Jan 08, 2013 | Computers & Internet
I am running vista and using the dlink di-808hv router. i have set up a pptp connection. when i use ms vpn to connect, it connects but only limited connectivity. can you help?
Peer to peer tunneling protocal is what pptp is if its connecting a limited connectivity that means some of the ports are stull being blocked thus needing for you to use your machine in a demilierized zone so this will open all avilable ports to your VPN software. Also keep in mind not all ISP's will support PPTP so you may have to use a softvpn software. Thanks i hope this helps
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 01, 2009 | D-Link DI-808HV Router (280006OB)
How to connect to my PIX 501 and use Windows Remote Desktop?
Here's a real simple problem to your remote access problems.
Go to: http://www.logmein.com
Sign up for a free acct, download/install their free software on your Server.
Now go over to your laptop, login to your new logmein acct.
In the next page, you'll see your Server listed. Click on it - follow instructions to connect.
This will tunnel through whatever stuff you have on your network!
Trust me - esp. in your scenario, this is *by far* the *simplest remote connect you'll ever perform! And it just .... works! Everytime.
gurutim
Mar 16, 2009 | Cisco PIX 501 Firewall
VPN Using XP Servers and D-Link WBR-2310
I had exactly the same problem. The solution is to set up pptp as a virtual server pointing to the lan ip of the server. Port forwarding only forwards the port but not the GRE protocol (pptp passthrough)
Jul 26, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Linksys Routers and Microsoft PPTP
Microsoft uses IP Protocol 47 [GRE] for this secure tunnel. Provided that the PPTP Pass Through is set to Enable on the Router's Filters page and port 1723 is forwarded to the VPN Server, the Router will allow authentication and remote access into your network. The router will also allow you access remote PPtP networks from behind the router providing the PPtP Passthrough is enabled on the router.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
BEFSX41 and Microsoft PPTP
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Setting up a PPtP server behind a WRT51AB Router
You?ll need to setup Port Forwarding to set up a PPtP tunnel behind a Linksys router. Please follow these instructions to setup the router to forwarding incoming PPtP traffic to your PPtP server: Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to our Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 47 ~ 47 1723 ~ 1723 IP Address 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application VPN VPN Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue. Restart your computer
Feb 16, 2006 | Linksys WRT51AB Wireless Router
NEC MobilePro P300 Pocket PC Logo
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
