Question about RCA VR637HF VHS VCR
Err message rca vcr VR702HF
I GET THIS MESSAGE EVERY I TRIED RECORD,REWIND OR PLAY THE TAPE
5 Suggested Answers
  • 119 Answers
SOURCE: Tape stuck in VCR, won't eject.
depending on th einternal design of the vcr. look for the loading/unloading mech, by finding the blak rubber belt that is looped from the motor to a pully. now turn it one way. it may thak 25 to 50 complete rotations of the belt. try turning both ways, one will load & 1 will unlaod. good luck.
Posted on Jan 24, 2007
dodgecharger
  • 254 Answers
SOURCE: VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Posted on Jul 10, 2007
  • 883 Answers
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Posted on Feb 05, 2008
SOURCE: RCA VCR # VR637HF
I have the same problem has you. I tried how to fix it, because VHS VCR are not sold anymore and i need it for my kids. They have a lot of VHS films. If i found a solution, i will share it to you.
Posted on Aug 31, 2008
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
How do i record on the vcr
do you hve anything going into either the cable in or the rca (red white yellow)?
if you do then make sure the correct input is selected
Jan 19, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
Tape gets tangled in rca recorder
Your take up spool or the pinch roller on the deck mechanism is probably not turning & causing the tape to spill into the deck. The cause of this could either be the motor is not turning the pinch roller if a belt has snapped or the clutch mechanism is not engaging the take up spool. If you remove the top cover & take a look at the tape when it is in play or rewind mode you will see if it spills on the right hand side, look to see in the right spool in the cassette tape is turning. The remedy would be to remove the deck mechanism & check the gears or belts.
Jul 26, 2009 | Sanyo DVW-7200 DVD/VCR
Can't find VHS video recording when I press play on VCR.
make sure your VCR is on the right channel TO record.
You may see the picture on the televison, but that doesn't mean that it is recording that channel. Also, make sure your tapes have the little plastic tab ON on the front of it. It will not record without the plastic tab or you can use a piece of scotch tape and put over the square hole.
Are you using coaxil cable or rca jacks to hook up vcr to tv?
Mar 11, 2009 | Televison & Video
RCA VCR # VR637HF
Aug 01, 2008 | RCA VR637HF VHS VCR
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
RCA dvd-vrc combo model DRC8320N
RCA MODEL DRC832ON..NEED REFERENCE # FROM SUPPORT TECH 1-866-775-0976 TO REPLACE PROCUCT..RAC SOLD TO AUDIO BOX..SEND DRC8320N TO: VENTURER ELECTRONICS, 203 EGGERT RD, BUFFALO, NY, 14215..WHEN YOU RECEIVE REF #..NEDD TO HAVE RECEIPT FOR PRODUCT LESS THAN 1 YR FOR WARRANTY TO BE EFFECTIVE
Jul 23, 2007 | RCA DRC8300N DVD Recorder/VCR
Tape plays for a while then stops...
play it till it stops when it ejects see if you can spin the wheel with your finger or if it feels like it is hung up try a different tape se if the problem goes away if it does not go away sounds like you need to get the heads cleaned or get a new VCR or better yet get a dvd player/recorder you can get one with a dvd/vcr and record your vhs on to DVDs
Jan 02, 2007 | RCA VR702HF VCR
RCA VR637HF VHS VCR Logo
79 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
