Question about Zebra LP 2844 Thermal Printer
Printing not centered
We have eight of these printers and print barcodes on them. One of these printers prints the barcode to the right-almost going off the lable. I have cleaned the rollers and print surface. The lables seem to be feeding straight...not to the left.
Does anyone have a suggestion?
  • printer babe Dec 10, 2008
    i have 3 of these printers two of them are printing perfect and the other one is printing on two labels we tried adjusting the lables it feeds well on the 1st the next to print it goes back and print on two lables please assist
  • Madison99
    Madison99 May 11, 2010
    I need to know.,..does the model have a Z at the end of it? Example: LP2844-Z
  • 35 Answers
If the other 7 printers print the barcode from the same software in the right place then the problem is with your printer.
Try to recallibrate the printer by doing this.
the printer should now perform a recalibration.
If this dows not fix it, then either the printer has a permanent fault or the printer driver/software is not set to the correct label width.
Posted on Feb 16, 2010
  • 254 Answers
Check the width of the label format.
Normally this printer will center the printing automatically when it receives the instruction to change the coordinates
Posted on Sep 04, 2009
  • pkwc Feb 04, 2010
    check if the center command is not missing?
  • pkwc Feb 04, 2010
Barcode Print aliginment is not proper in windows7
Try a different print driver. Go to Zebra web site and download driver for Windows 7'
Apr 22, 2014 | Zebra Office Equipment & Supplies
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
I have godex 1100 barcode printer which is not working. It doesn't print barcode. it responds the print command from the computer and tries to print but halt immidiately blinking status light. It gives...
You did not tell us, whether it is not printing barcode's alone or no text is printing.
You might hear beeps for 2 reasons, Sensor posistion is not correct. or ribbon is not correctly fitted.
Kindly check both these. hope this will solve your problems.
If you have any other queries with barcode printer kindly mail/call us.
Regards Trridev Labelss Mfg Co Web Marketing Division email
Manufactures of Self adhesive labels and resellers of barcode printers and scanners and ribbons
Sep 14, 2010 | Argox X-2000+ Thermal Label Printer
Ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Apr 13, 2009 | Zebra Z6M Plus Thermal Barcode Label...
How do you speed up the printing speed on a Paxar 9800/9850?
Press "escape"
Press Right arrow til display says "setup"
press "enter"
Display now says "supply"
press "enter"
right arrow til you see "speed"
press enter
adjust print speed IPS is "inches per second"
press enter after you change speed. hit escape key 3-4 times, then enter - you should see "print mode ready
If speed doesnt change it could be because the print speed is set by the software OR by the type of barcode you are printing. Serial barcodes default to 2.5 ips.
Apr 08, 2009 | Paxar Monarch 9825 Thermal Label Printer
How do you speed up he printing speed on a Paxar 9800/9850?
Are you printing a serial or parallel barcode? If you don't know, a serial barcode looks like a ladder as it prints out on the label. A parallel barcode looks like a picket fence. A serial barcode (ladder) prints at 2.5 ips by default. You can't increase the speed. If you're printing a parallel barcode (picket fence) you must hit "enter' once you adjust the speed setting in the printer menu. If you've done that and it still won't increase speed, then the speed is set by the software itself, and overrides any changes you make in the printer menu. The speed adjustment must then be made in the software, not the printer.
Apr 08, 2009 | Paxar Monarch 9850 Thermal Printer
Speed of printing barcodes
Generally the ZM 400 can cope with printing at the lower speeds when printing barcoedes that are the same. You may get pauses if the barcodes are sequential numbers or are all different, then the data to be transfered to the printer cannot cannot keep up with the printer and pauses while it gets more data. We have found that if you can select in your labelling software to print the barcode as a graphic, then it speed up quite a lot. It is a matter of matching your print speed and quality to match your expectations, sometimes you will just have to put up with the pauses.
Feb 02, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
May 25, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Can't get barcodes to scan?
have you tried different darkness settings? it sounds like you only need to turn the darkness up a little.
Apr 02, 2007 | Zebra 110XiIIIPlus Label Printer
Zebra LP 2844 Thermal Printer Logo
534 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
