NEC MobilePro P300 Pocket PC Logo
A
Anonymous Posted on Sep 15, 2005
PPP Does the P300 support PPP?
Anonymous
Level 3:
Master:
  • Master 903 Answers
  • Posted on Sep 15, 2005
Anonymous
Master
Level 3:
Master:
Answers
903
Questions
43
Helped
143071
Points
2651
The P300 supports PPP PAP Authentication, PPP CHAP Authentication, PPP MS-Chap Authentication, and PPP Password encryption - MD5, but it does not support PPP data stream encryption.
3helpful
When i connect my samsung GT-S3653 with laptop for internet via samsung pc studio it showing error "os error PPP link protocal terminated, kindly provide the solution
If your using a DSL line, then the PPP settings should be adjusted...
PPP means point of protocal prresence used in DSL...
If you've converted over to CABLE or other means, then disable the PPP settings or Clear them out.
And have the system recommend a setting to start with when you reboot.
tip
How do you configure Multilink PPP on Cisco Routers
How do you configure Multilink PPP?
Given that the two sites that are connecting via Multilink PPP communicate with each other and coordinate the configuration, configuring Multilink PPP is easy. Here is a sample configuration of 3E1 circuits being bonded to form a single 6Mb Internet circuit:
controller E1 4/0
framing NO-CRC4
channel-group 1 timeslots 1-31
description Connect to OtherSite#1
controller E1 4/1
framing NO-CRC4
description Connect to OtherSite#2
controller E1 4/2
framing NO-CRC4
description Connect to OtherSite#3
interface Multilink1
ip address 1.1.1.1 255.255.255.252
no cdp enable
ppp multilink
ppp multilink group 1
interface Serial4/0:1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial4/1:1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial4/2:1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
This configuration is from a Cisco 7200 router that has Qty 1 Controllers E1 interfaces (plugged into module 4). These E1 controllers create the Serial4/0:1, Serial4/1:1, Serial4/2:1 interfaces that are bound to the multilink group #1, and other serial interfaces (Serial4/3:1, Serial4/4:1 and so on...)
It is the multilink1 interface that is actually the single combined interface that really has the “6Mb” of bandwidth, and that is where you would apply all of your “normal interface configuration” for this 6Mb connection that connects to the Internet. You can see how the multilink 1 interface has an interface number that matches the ppp multilink group. On that multilink 1 interface, you have the IP address for this link, an ACL on the interface, firewall, NAT, or other router interface commands.
By using the multilink interface, you are able to bond all three of these E1 interfaces into a single router interface — very cool!
To verify that your multilink interfaces are up and running, you can use the show ppp multilink command, like this:
Router# show ppp multilink
Multilink1, bundle name is OtherSite
Bundle up for 3w4d, 89/255 load
Receive buffer limit 85344 bytes, frag timeout 1000 ms
10518/6985 fragments/bytes in reassembly list
21651 lost fragments, 3287247349 reordered
17098/8879018 discarded fragments/bytes, 18 lost received
0xA990C7 received sequence, 0x7F6AA8 sent sequence
Member links: 3 active, 0 inactive (max not set, min not set)
Se4/0:1, since 3w4d
Se4/1:1, since 3w4d
Se4/2:1, since 3w4d
Router#
The key to configuring Multilink PPP is the multilink interface, the ppp multilink protocol on each router, and the ppp multilink group x command on each interface. Multilink PPP isn’t a difficult router configuration to set up, and it is extremely valuable when you need multiple circuits bonded into a single circuit from a single provider.
And for sure, you can just add multilink interface to be routed using OSPF, PBR or any other routing protocol.
on Jan 12, 2010 • Computers & Internet
5helpful
Fujitsu siemens scenic p300 vga drivers
Hi.
There are different P300 versions.
Click on the link below:
Fujitsu Siemens Download page. ( http://ts.fujitsu.com/support/downloads.html )
In the page put scenic p300, or put the serial, or put scenic p300 in model description.
In the following boxes select:
Personal Computer
Former Models
P series
P300
Select model in last box
In the next step you will be asked to select Windows operative system.
Select OS, then find the driver to download.
2helpful
How to get gprs setting as not launched in india
BSNL - GPRS (South Zone) settings for HTC or any other windows mobile users
[bsnl-wap]
-Homepage URL : http://localhost/home.wml
Bearer : GPRS
APN : wapsouth.cellone.in
User Name : ppp
Password : ppp123
[bsnl_internet]
-Homepage URL : http://bsnl.co.in
Bearer : GPRS
APN : gprssouth.cellone.in
User Name : ppp
Password : ppp123
[cellone-portal]
-Homepage URL : http://wap.cellone.in
Bearer : GPRS
APN : portalsouth.cellone.in
User Name : ppp
Password : ppp123
[bsnl_mms]
-Homepage URL : http://10.31.53.18/mms/
Bearer : GPRS
IP ADDRESS : 10.31.54.2
APN : bsnlmms
User Name : ppp
Password : ppp123
thanks
How to convert a ppp-file to MPEG?
http://convert-ppp-file.qarchive.org/
convert.software.informer.com/download-convert-ppp-video-format/
ptf.com/convert/convert+ppp+files+to/
That should do the trick.
How can i config my DSL acount in cisco 857
with a dialer interface:
interface Dialer0
description $FW_OUTSIDE$
ip unnumbered Ethernet0
ip access-group sdm_dialer0_in in
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ppp authentication chap callin
 ppp chap hostname xxxxxxxxxxxxxxx
 ppp chap password xxxxxxxxxxxxxxxxxxx
Has anybody configured Reliance Datacard - USB on ubuntu 9.04? Kindly give me step by step procedure for configuration? Regards, Moiz
First use the following command to see if your card is being detected by kernel.
cat /proc/bus/usb/devices
Then you can use the following script for the installation, you can check if this is for your version of Ubuntu.
#!/bin/bash
#This program automates task of setting up connection for Reliance USB Card on Ubuntu Hardy Heron. This program does not come with any warranty whatsoever. Please use it at your own risk.
# Detect Modem
echo "Modem Detected: $(lsusb | grep -i huawei | cut -d" " -f7-)"
# Get Connection Number from User
echo "Enter Your Reliance Data Card Connection Number : "
read connection
echo "Setting up connection with $connection"
#Install Gnome PPP Package
echo "Installing Required Packages.."
sudo apt-get install -y -q gnome-ppp wvdial
#Add entries to /etc/ppp/ppp-secrets and /etc/ppp/chap-secrets
echo "I:Modifying necessary system files to allow dialing with Gnome PPP..."
sudo chmod 666 /etc/ppp/pap-secrets /etc/ppp/chap-secrets
echo "$connection * $connection" >> /etc/ppp/pap-secrets
echo "$connection * $connection" >> /etc/ppp/chap-secrets
sudo chmod 600 /etc/ppp/pap-secrets/etc/ppp/chap-secrets
#Start Gnome PPP
echo "We are all set.... "
echo "Starting Dialer..."
gnome-ppp &
exit 0
I have used Internet many hours, days; without problems. But now, I can not connect anymore. PPP daemon has died = A modem hang up the phone (exit code = 16). Var/log/messages = warning: secret file...
your password file (papsecrets) has been given access to users outside your login.
This means someone could potentially hack your connection by gaining access to your papsecrets file.
User permissions for papsecrets needs to be reset to you only, and no global/group access should be allowed. Note: it is a hidden file but is in folder /etc/ppp/papsecrets
Restore the original permissions with:
# chmod a-rw /etc/ppp/papsecrets
# chmod u+rw /etc/ppp/papsecrets
Basically your operating system is defending you from sharing your internet passwords with the world.
Samsung sgh p300 phonebook copy to Samsung SGH P520
how can i transfer phonebook from my sgh p300 phone to my pc i dont have software cd but i have usb connector
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
