Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Simpletech 500 gb external hard drive
I believe my power chord went bad. i plugged it in and am getting no power at all i took the hard drive off the chord . and let the plug stay in the outlet it did not get warm at all. do you believe this would be the problem.
  • mindwarp1966 Sep 07, 2008
    adonis i plugged my laptop chord into my simpletech external hard drive i found that it powerd up my external but i had to remove it as it would have fried the hard drive or another chord lol.
There is a power consumption work-around untill a Y usb wire can be purchased; the main power cable must still be used at all times but this workaround should only remain temporary!!!
Simpletech should have included this so laptop users could use the drive as their capacity is better than the packaged slimmer simpletech portable backup drives for laptops, which does include the Y cable....
1) unplug usb while powered and unknown hardware is present on laptop...
2) turn power switch off from the external HDD...
3) return power switch to on from the external HDD...
4) plug in usb connection to laptop...
Autoplay should read from external HDD!!!
**** Save some $$$ and buy a Y shaped cable to provide sufficient amount of power from laptop usb
ports, cause it's necessary to use 2 of your ports to provide power in addition to the main power from HDD to wall****
ADONIS
Posted on Sep 06, 2008
  • WattoAdonis Sep 08, 2008
    Best solution if you are not shy about doing this and can spend the money is; go back to the store where you bought your Simpletech external drive, and purchase another one so you can switch the power cords and return yours instead to get your money back... Just check store policy on returns!!! Or you can find another electronics store that can sell you another one with matching specs for voltage and consumption so as you mentioned it will not risk frying the drive!! Good luck with that! ;-)
    ADONIS
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
I need the dc power supply for SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Your solution is a 12 volt 1.5amp chord. With a negative outside/ positive inside plug tip polarity. Simple Tech model and part number: SYS1298-1812-W2
Jan 08, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
When i plug it it worked but now it doesn't so i change of computer and it work again but when i unplug and decide to use it again it didn't work again
You likely need to power the hard drive from and external power supply or use the included "Y" cable to plug into 2 USB ports at the same time. Some USB ports on computers do not supply enough power to operate correctly. If the hard drive did not come with a power supply or the "Y" cable, contact SimpleTech and purchase this accessory.
Apr 17, 2011 | SimpleTech FS-U25/500E 500 GB USB 2.0 Hard...
I have my Simpletech 500gb drive pluged in but
Okay, so it should be picking up with that machine. First try re-seating all cables (power and USB both sides) and also try plugging it into a different USB port. Be patient and give it a few minutes to find it. Let me know whether or not that works.
Dec 22, 2009 | SimpleTech 500GB SimpleDrive Pro External...
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
500g simpletech extrenal harddrive will not turn on
Sounds like a drive failure. If it under warranty then its time to trade it in.
Jul 29, 2009 | Western Digital 500GB My Book Pro-External...
Freezing
Maybe some bad sector in there. You should do a disk scan to check that.
Jun 24, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Simpletech 500 GB external hard drive - unresponsive
If you really can not get it to work anymore, you could try opening it up and connecting the hdd directly on a IDE/SATA port in your computer. This will only work if you have a desktop, for a laptop you would need all kinds of converters.
May 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
DC voltage
Could average around 12V I believe.
Mar 26, 2009 | Western Digital 500GB My Book Pro-External...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
351 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
