Question about Asko 24 in. D3350 Dishwasher
Asko 3350 Dishwasher
Stops 2 mins after start displaying code F7
    Scholar:
  • 55 Answers
The "F7" code means that the drain is blocked. To remove items from the drain: 1.Turn power to unit off. 2. Remove the "Coarse Filter" by squeezing the tabs together and lifting out. 3. Remove the "Fine Filter" and "Main Filter" by removing the screws around the filters and lifting them out. 4.Remove the small black adapter piece and check the sump area for debris. 5.Wash the filters out gently with hot, soapy water. DO NOT RUN THE UNIT WITHOUT THE FILTERS IN PLACE! 6.Replace the black adapter piece to its original position FIRST (Important!). 7.Replace the filters in reverse order of removal and turn the unit back on. The error code should reset and work normally. *In areas with hard-water, the filters should be removed every 8-12 months and submerged in a chemical solution (CLR or LimeAway) to remove mineral deposits. Hope this helps...
Posted on Sep 04, 2008
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
interrupted.
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Dado
Oct 06, 2015 | Asko Dishwashers
Asko D3350 code F7
you seem rushed
ok
the problem might not be in your senser or timer but in the pump its self
Sep 14, 2008 | Asko 24 in. D3350 Dishwasher
Calypso washer starts runs for 2 min stops then starts then stops the starts and c1 flashes
The CI and CA error codes indicate that current (amp draw) limits for the drive motor were exceeded. Since you indicate that these codes were displayed even though the washer is not overloaded, it is likely that you have a problem with the motor, motor controller or the universal joint. An item stuck underneath the nut-ate plate or between the spin basket and the outer tube of the washer could also cause this problem.
Nov 21, 2012 | Washing Machines
Hi i have a asko d3111 the pump is running the washing icon is flashing.i have cleaned all of the filters how do i reset it
i have an asko3132 washer starts but no water coming into washer then stops and displays error F7 have cleaned filter do i reset if so how
Jun 14, 2011 | Asko 1595 Dishwasher
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
May 20, 2011 | Thermador SC302T Electric Double Oven
Hi I have an Asko D3350, and have an 'F7' problem, can anyone help. Starts all wash programs then stops half way through with f7 showing. but the pump and discharge hose is clear. If it means anything it...
At the bottom of the dish washer where the water drains from there is a rectangular hole at the back (you will need to remove all the baskets and the screen). Grease can accumulate here and block the tube that feeds a pressure switch, causing this malfunction. This grease will not be visible as it sits under a lip on the other side of the rectangular hole and above it. This would need to be removed carefully as one doesn't want to push the grease into this tube
Feb 02, 2011 | Asko 24 in. D3350 Dishwasher
HI.... WOULD YOU PLEASE HELP ME TO RESET P/M ON PANASONIC COPIER 7728 . I DONT KNOW HOW TO ACCES THE SERVICE PROGRAM..... THANK YOU .
just press "user preset" "original size A3" and "3" simultaneously to enter service mode and the display will be "F1"
to reset the p/m, you should change the value of F7-c22 and F7-c26
go to F7 mode(press 7 to move to F7, then press start)
press "2" "2", then start
press "0" to reset the value of F7-c22, then press start
now press "2" "6", then start
press "120000" to reset the value of F7-c26 (this counter is countdown so it starts with highest count)
press start
press stop to exit F7 mode
press "user preset" and "stop" simultaneously to exit service mode
that's it
May 21, 2010 | Panasonic Office Equipment & Supplies
F7 code
yes remove filter and water from under filter theres a small chamber at the back of the sump,it may be full of fat clean it with your finger then try running some heavy wash cycles to clean it.
May 02, 2010 | Asko 24 in. D3350 Dishwasher
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
Dishwasher stops and displays fault code F7
If you have checked the sump filter at the bottom of the dishwasher, then close the door and turn on the power. then hold the start button with the + and - buttons under the LCD display, untill the drain pump starts. this should then reset the dishwasher
Mar 26, 2010 | Whirlpool Dishwashers
Asko 24 in. D3350 Dishwasher Logo
2,295 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
