Spy ware is not running and ihave no sound - Computers & Internet
3 Suggested Answers
Open SKy
  • 618 Answers
SOURCE: spy ware disk
First things first:
You have to provide the name of the spyware you got? there is a lot version and names for all kind.
good luck
Posted on Mar 14, 2008
MysteryFCM
  • 187 Answers
SOURCE: Spy ware
It depends on the infection. My first recommendation would be to ditch Trend Micro, and get a better antimalware program (it's not very good compared to alternatives). Much better alternatives include; 1. NOD32 (or if you want the suite, NOD ESS) www.eset.com 2. Kaspersky www.kaspersky.com 3. Avira www.free-av.com 4. Avast www.avast.com 5. Malwarebytes AntiMalware www.malwarebytes.org Each of these include trials and/or free versions that you can use to get rid of the infection. I'd also recommend following it up by posting a HiJack This log to one of the many support forums available, including TeMerc Internet Countermeasures; www.temerc.com/forums To do so, please see the following instructions; http://temerc.com/forums/viewtopic.php?f=12&t=18 A list of other trusted support forums can be found at; Alliance of Security Analysis Professionals http://asap.maddoktor2.com
Posted on May 27, 2008
SOURCE: Re-install a program from the trash bin
hullo there
if you just deleted the spyware just restore it from your trash bin but if you uninstalled it then you will have to reinstall it using either your software cd or its executable file.
Posted on Jun 25, 2008
Computer and printer quit communicating. Lost printer icon on desktop. How do i reload printer software?
    Follow these steps to install the beta driver for your printer: From the Apple menu, select System Preferences. Highlight any Epson printersand click the button to remove them from the Printers list, then click OK. Select the folder labeled EPSON and drag it to the trash.
    How to Uninstall and Reinstall Your Printer Driver - Epson
    www.epson.com/cgi-bin/Store/support/supAdvice.jsp?noteoid... Epson
Jan 27, 2016 | HP Deskjet F340 All-In-One Printer
The light marked Ethernet is blinking very fast and im having trouble getting a lot of sites
Make sure all the cables are plugged all the way in... run a virus and spy ware scan... a good free spy scan is spybot... clean all extra files through the computer clean defray area found in program section... and maybe a defrag..... this is for the outside problem of a full computer that may have too many spy ware taking up your Internet and cookies filling your computer.... this could take some time but your computer will work a lot faster
Dec 02, 2014 | Gateway Att 2 Wire High Speed Internet...
Spy call recorder downloaded. Asking for registration key... Unable to start spy call
Ihave a nokia N70 & it has the display problem .How much will cost for changing display
Jul 02, 2010 | Nokia N70 Cellular Phone
My PC always hang!
A lot of things can do this.
  1. Make sure you are running only one anti-virus program and one spy-ware solution and that it is up to date. More is not better, the similar products will compete and give false positives on each other.
  2. Make sure that there are no virus or spy-ware running on the machine. If you do not have a product to check I recommend AVG and Spy-bot because they are both free and are reliable.
  3. Run disk checks on your C: drive, scan it, and de-fragment. You can do it by right clicking the drive and selecting properties. It will be on the TOOLS tab
  4. Make sure that you have enough drive space. You must have at least 200MB free on the primary drive or Windows starts to lag badly.
  5. Make sure that you have enough RAM. Right click My computer and select properties. Many computers come with only 512MB or less of memory. You need at least 1GB with all the new patches that Microsoft has put out.
  6. Do not run an excessively large number of USB devices without using a powered HUB and make sure that the power supply in the PC has enough power to run all the devices attached to it. Most OEM PC's come with a 250w power supply, if you have added anything after market like Video or sound upgrades, you may need to take the power supply to 350-400w.
  7. Don't run programs that for which you don't meet the system requirements. If your running something like Mass Effect to on a Celeron it is going to restart and hang.
Mar 11, 2010 | Computers & Internet
My computer has been running very slowly
http://www.iobit.com/advancedwindowscareper.html   uninstall u r spy ware anti virus  then install the new avg antivirus
after that  Click on the Above Link. Download Software!!!
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
Apr 02, 2009 | Navarre PC Tools Spyware Doctor W/...
My lap top is extremely slow whenever i am doing anything online
uninstall unwanted software click start> control panel> Add/Remove programs
Delete junk files
1. Click run start> Run> type %temp%
2. Click run start> Run> type temp
Restart computer.
GooD Luck !
Dec 08, 2008 | Sharp Actius AL27 Notebook
hullo there
Jun 25, 2008 | Computers & Internet
Spy ware disk
Only way to get the key code legally is to purchase it from the software manufacture.
Mar 07, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Properties and Control Panel
This is often a symptom of a spy-ware infection, if you don't have an anti spyware program I suggest you get a copy of Adware and run it to check for infection it should get rid of any spy-ware infection, here is a link
Hope this helps
Dec 02, 2007 | NEC Versa FX Notebook
Computers & Internet Logo
16 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
