Question about NEC MobilePro P300 Pocket PC
Socks Proxy Client and Winsock Proxy Client
Does the P300 support Socks Proxy Client and Winsock Proxy Client?
    Master:
  • 903 Answers
Yes, (Socks v4 and v5).
Posted on Sep 15, 2005
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Socks proxy finder
I hae proxies they are great but problematic. Check the address that the proxy server is suppose to be on, make sure it is up and running. Is there a reason for using a proxy? Company policy? or used for security?
Jan 05, 2014 | Computers & Internet
Frequent VPN connection drop on my wifi
If you can't connect via the Internet to your workplace network from home (or another location), check the items in this list:
  • Make sure that you typed the virtual private network (VPN) server name exactly as provided by your network administrator.
  • You must have an active Internet connection for a VPN connection to work.
  • If your modem is external, make sure that the modem power is turned on.
  • Contact your network administrator to make sure that you have the appropriate connection and domain permissions on the remote access server.
  • This could be a certificate problem. For assistance, contact your network administrator.
  • A VPN connection won't work with an active Winsock proxy client. Contact your network administrator to make sure the Winsock proxy client is not enabled.
  • If you know the IP address (for example: 131.107.10.25) of a website, type that address in the address bar of your web browser and press Enter. If this works, there is probably a Domain Name System (DNS) resolution problem. For assistance, contact your network administrator.
  • If you have special software that's required or installed by your workplace, it could be part of the problem. For assistance, contact your network administrator.
  • If you know the IP address (for example: 131.107.10.25) of your VPN server, type that address for the VPN connection, and then press Enter. If this works, there is probably a DNS resolution problem. For assistance, contact your network administrator.
  • There could be a problem with the server you're trying to connect to. For assistance, contact your network administrator.
If you try to connect with a VPN connection and you see a message that says "The local computer does not support encryption" and has the error code 741, it's possible that the encryption that your computer uses doesn't match the encryption used by the VPN server. To change the encryption settings so that your computer uses the recommended setting of 3DES, follow these steps:
  1. Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
  2. Right-click the VPN connection, and then click Properties.
  3. Click the Security tab.
  4. Under Data encryption, select Maximum strength encryption (disconnect if server declines), and then click OK.
  5. Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
  6. Click the VPN connection, and then click Connect to try connecting again.
Apr 21, 2013 | Belkin Surf N300 Wireless N Router
Due to some restrictions in our college its now imposible to acess Facebook even while trying to use different some proxy servers. So can u please help me with better alternatives.
1. Try using a webproxy, eg. https://hidemyass.com/, more on this page: https://proxy.org/cgi_proxies.shtml
2. Try using a socks proxy (you have to set these up in your browser)
3. Connect through a VPN, available from http://cyberghostvpn.com/ and others.
4. Use a machine you have SSH access to, to set up your own proxy.
Aug 25, 2011 | Computers & Internet
Yahoo mail want load
check other email account like gmail
i encounter same problem when i use certain proxy server, they block mail accounts and certain website. check if your using any proxy, try to change it to a different one.
this site offer free proxy servers http://www.hidemyass.com/proxy-list/
Dec 14, 2010 | Yahoo Mail
I cant get connected to the internet everytime i try it keeps saying- im working off line, how do i fix this?
go to your internet exploror, click "file" on top left of page....check to see if "work offline" is checked..if it is, uncheck it and try again.
Dec 29, 2009 | Computers & Internet
I can't access to Y! messenger.
Try Yahoo Web Messenger.
Aug 21, 2009 | Yahoo Messenger
Error 81003004.......unable to login error showing ; check network connection
May be your Network Admin/ISP blocked your messenger port....Please contact your network administrator.....if you use socks proxy please clear the proxy from network connection>Lan Setting>Unselect Use Proxy Server.......etc. or check the Connection Preferences in the messenger window and select Connect directly to the internet and save....All the best
Aug 02, 2009 | Yahoo Messenger
Hello
SOCKS is an Internet protocol that facilitates the routing of network packets between client-server applications via a proxy server. SOCKS performs at Layer 5 of the OSI model - the Session Layer (an intermediate layer between the presentation layer and the transport layer).
Clients behind a firewall may connect to a SOCKS proxy server in order to access external services through the firewall. Such a proxy server controls the eligibility of the client to access the external server and, if the client has eligibility, passes the request on to the server. SOCKS can also be used in the opposite way, allowing the clients outside the firewall ("exterior clients") to connect to servers inside the firewall (internal servers).
SOCKS software
* Kernel SOCKS Bouncer ksb26 (Kernel Socks Bouncer) is a Linux Kernel 2.6.x Loadable Kernel Module that redirects TCP connection (to user-defined target hosts) through socks 4/5 chains.
* SS5 Socks Server is an open-source SOCKS4/SOCKS5 server.
* Dante is an open-source SOCKS4/SOCKS5 implementation with commercial support developed by Inferno Nettverk A/S.
* OpenSSH allows dynamic creation of tunnels, specified via a subset of the SOCKS protocol, supporting the CONNECT command.
* WinSocks is a light-weight SOCKS4/SOCKS5 server developed by Proxy Labs.
* SOcat Multipurpose relay (SOcket CAT): includes socks4, and socks4a functionality (Linux / Mac)
* FreeCap Socksifyer for Windows, any App can run its network traffic transparently via a SOCKS or HTTP proxy.
* Simple Socks Server for Perl - SSS is a Simple SOCKS Server written in perl that implements the SOCKS v5 protocol.
* Sun Java System Web Proxy Server is a caching proxy server running on Solaris, Linux and Windows servers that supports HTtp://S, NSAPI I/O filters, dynamic reconfiguration, SOCKSv5 and reverse proxy.
* BarracudaDrive Web Server - commercial SOCKS HTTP HTTPS tunnel/server, available for Windows, embedded Linux and Mac OS X (PowerPC)
* DeleGate is a multi-purpose application level gateway and proxy server which runs on multiple platforms. Beside SOCKS it also supports HTTP(S), FTP, NNTP, SMTP, POP, IMAP, LDAP, Telnet, DNS and many more.
Jan 05, 2009 | Computers & Internet
NEC MobilePro P300 Pocket PC Logo
292 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
