Question about Sharp Microwave Ovens
I have a Sharp microwave approx 10yrs old. It's quite a large beast that does every thing, white, touch pad. The food is not warming up but the tray rotates and light is on. Any ideas? Regards Roy 07766 028526
In the meantime a local repair (sole trader) replaced the above mentioned parts HV diode and replace 2 fuses. He warmed a cup of water to test and I took it home. With in 5 mins of use at home the same happened again. It was not louder then usual.
As a compromise he gave me my money back and I said he could keep the microwave.
Thank you for your response, very much appreciated. I will know where to come next time for expert advise.
Regards, Roy
Posted on Sep 10, 2008
Burns my popcorn constantly. is there a different setting i can put it on?
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Microwave making loud noise while heating food. And food does not get warm or hot.
sounds like the magnetron has failed on this is located in side behind the control panel touch pad and if replaced usually requires disassembly of the outer shell of microwave... it is a common problem with microwaves and can be fixed just requires taking apart unit to do it...good luck to you
Jan 09, 2011 | Kenmore Microwave Ovens
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Jun 25, 2010 | Sharp R-1610 Microwave Oven
Kenmore microwave's exterior and buttons
Hi it is quite normal for the outside of a microwave oven to get quite warm to the touch. with regard to the buttons not working; this will be due to a faulty touch panel mebrane that will need to be replaced. They are not too expensive so is a viable repair
Hope this helps
Jan 07, 2010 | Microwave Ovens
Oven resets (like power failure) frequently - either while pressing buttons or while cooking food. Approx 5 yrs old - problem just started.
The following parts may cause this problem and must be tested:
Control Pad: This is most likely the problem , testing the contol pad is quite complicate.
Door lock: A defective door lock can cause the magnetron and turntable motor being turn off erratically. This wont cause the program to reset.
Power cord and power connection solder joints: this can cause a microwave restarting because vibration caused by the oven working cause power interruption.
A bad shielding to controller board can also cause the microwave resetting because of the interference caused by magnetron on control board circuits. This is also quite common.
The control pad or control board are the parts that are most commonly causing this problem.
Dec 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Code F6, E0, "Communication Error"
Hi. this code represents a key pad or control board malfunction. you will have to make sure the key pad or control panel connectors are connected tightly and securely. If the wires and connectors are secure, the actual control board may be faulty and you will need to replace it at this point.
Mar 01, 2009 | KitchenAid Microwave Convection Oven
My touchpad does not respond when touched.
it depends on how old the unit is as sharp as a lot of manufacters will only hold parts for up to 5 years for domestic are looking at getting a new keypad at a cost of approx £15 to £35 plus fitting
Jul 31, 2008 | Sharp Microwave Ovens
Microwave touch pad work light doesn't work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa:
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 29, 2007 | Microwave Ovens
Microwave Keypad Is Hot
check blower fan, and maintained gap between oven and wall at last 2 feets. some heat comes to pad very heat may be some prolem. check every thing and reply me.
Aug 21, 2007 | Emerson MW8108P Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
