Question about Toshiba Satellite A65-S126 Notebook
Create a backup
How do you create a backup of your system. Currently receiving error messge 0x0000009c (ox00000000,ox805535fo,oxa2000000,ox84010400). Laptop boots up for about 5 min then receive this error.
  • Justin Goldberg May 11, 2010
    You probably have bad memory chips. Can you run a bootdisk that has memtest86?
    I would first use the Windows System Restore first. If that doesn't fix it do a windows xp in-place reinstall.
  • Roberta Smith
    Roberta Smith May 11, 2010
    do you use zonealarm on your computer ?
    Robert
No never hear of zonealarm. I was able to boot up in save mode and retrieve some of my documents but not sure what this critical error is i keep getting.
Posted on Sep 07, 2008
No operating system error in acer v5-471p
Depending on the BIOS used by the system, the error message that appears could also be "Missing operating system". There are both hardware and software issues that may be causing either of these error messages to appear which we will look at in turn.
Is your hard drive detected by the BIOS?
There is the possibility that the connection to the drive has been jarred loose. The documentation for your device available from the Acer website is next to useless and I cannot find a decent shot of the underside of the computer but there should be a means to access the hard drive of your computer via a covered opening without resorting to major disassembly. On most laptops it only requires a small Philips screwdriver to remove it. Just open up the cover and ensure the drive is firmly seated in the connector.
If the drive is securely connected, you may have a failed hard drive. In this case, the drive needs to be replaced, your OS reinstalled (if you have the correct media), and your data restored from backups. You have been making backups, right?
The software side
If you can see your hard drive in the BIOS, there is a problem with the boot record or the BCD (Boot Configuration Database). To fix this, you need to have a bootable repair disc created from your system earlier or a Windows installation disc for the version of Windows currently installed on the machine. The recovery discs provided by OEMs or created by their recovery disc creation software will not work for this. They only place a new copy of the factory installed image on the system and are not the same as the Windows installation DVD.
If you have the installation disc, boot from it.
Oct 24, 2016 | Acer Computers & Internet
How to back up ic power laptop
That's rather a vague question. However there are quick a few packages out there to backup complete systems.
Firstly there is Acronis True Image. This software can create an image or file backup over multiple discs or partitions from a windows environment or direct booting from CD. It supports SSD hard-drives, partitions hard-drives and more. Click on the below link for more information.
Backup software for data backup and disaster recovery in Windows and...
Another software package is Symantec System Recovery. This software does exactly some thing as the above mentioned package as well as check hard-drives for errors, network & system tools.
Here is the link
Symantec System Recovery Desktop Edition
Regards,
Alex.
Jan 25, 2012 | AMD IC Power CN5560 Laptop
Error loading operating system
What operating system? Windows? If so, what version? Linux? Mac?
It could be a corrupt system file or a corrupt section in the MBR of the drive. If you have critical data on the drive that needs backed up, then I recommend that you (from another machine of course) download a live cd version of linux to boot into along with an external usb hard drive. You can then mount your existing drive and copy your data to the external usb drive for a backup of data. I would recommend either PclinuxOS, Knoppix or Puppy Linux. Exit once backup is complete.
Next, boot your machine with either a restore disk received with the purchase of your computer, or if unavailable, boot to a system disk of your current operating system (such as windows xp, etc.). This MIGHT require a fresh install of the operating system - thus the reason for doing a backup of data first. If however, there is a bad sector in the drive's MBR then you're ultimately looking at replacement of the hard drive and then performing a restore or a fresh install of the operating system.
If you find this solution to be helpful, then please take a moment to rate this post. - Thanks.
Jun 19, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
I have ran into a problem with my Acer Aspire 7520g. I started the laptop as usual and it started no problem. I then left the room and when i returned the laptop was switched off. When i now try to boot it...
Ok, you need to boot from your DVD with a Widows, install boot disc, inserted, and boot up on that DVD, then do a startup repair. OR... Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 22, 2010 | Computers & Internet
I want to reset it
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
I Install the window xp sp-1 than my acer laptop screen show the blue screen and the error is 0x0000007B(0xF7A9063C,0XC0000034, OX00000000,OX00000000)
This problem is because of one of the unsuitable driver. Logon to your system in safe mode and update drivers for all the hardware and restart.
Hint: keep pressing F8 while booting to show other booting options from where you can select safe mode.
Feb 25, 2010 | Acer Computers & Internet
System is running extremely slow, when I tried to do a factory restore I get an error code 0xf00000005. I ran hardware diagnostics on the hard drive memory cpu and mobo, tests run extremely slow. I tried...
After using Darik's boot and nuke (DBAN) your hard drive will be wiped clean with little chance of recovery. This also depends on how many passes you used for the disk wipe. More passes = less chance of recovery.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process.
Jan 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
MEMORY FULL IN PHONE
Just Reset Your Mobile Phone Settings RESTORE FACTORY SETTINGS
Automatically Remove all errors from your mobile phones
Before resetting Backup your Contacts Massages and All Gallery
Awais Shahid
Dec 29, 2008 | Nokia N72 Cellular Phone
Acer laptop restore factory settings?
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of select Restore System to Factory Default.
If windows is not working but the system boots -
Reboot the system and when the Acer logo appears, hold down the ALT key and press F10. This starts the recovery process, just follow the instructions.
Oct 19, 2008 | Acer Aspire 5050-3242 Notebook
Booting up
Probably corrupt firmware. You can re-load the backup and restore the system.
Press and hold the SOURCE and STOP buttons whilst plugging into the mains supply.
Continue to hold until recovery option appears.
If this doesn't work, then the backup firmware is corrupt too.
Dec 13, 2007 | Philips WACS700 Shelf System
Toshiba Satellite A65-S126 Notebook Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
