Question about Xerox Phaser 8560MFP Laser Printer
Ink Out! It says I ran out of yellow ink. I do not have any right now. How can I bypass the error so I can print in black and white? I do not need the color ink. I have tried to print by changing the color settings in the print document window but my Phaser still says that I need to replace the yellow and does not allow me to print! Please help!
    President:
  • 2,072 Answers
That is a very hot area, Honestly for safety reasons and so as to not ruin the print head or ink loader, I would not recomment putting anything in there. We are talking a heater that gets to 350 degrees. Placine anything in the ink loader other than ink is not a safe practice.
There is no software bypass. The ink must be in place.
Posted on Sep 04, 2008
My printer is out of Yellow ink! I only want to print black n white, but it does not allow me to print at all. The message reads - The printer does not have enough ink to maintain print quality. I have...
The printer will not work under the conditions you indicated. Manufacturer wants you to buy more of their overpriced ink.
U can try filling the yellow cartridge with some ink substitute such as alcohol, doing a hard reset of printer and also uninstall and reinstall software and see if you can fool printer to work.. If so, then you can change preference to just black and white.
Jun 21, 2017 | Office Equipment & Supplies
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
My Epson Stylus NX400 wont print because I'm out of colored ink. I just want to print in black and white and I cannot bypass the error screen.
This because the coloured ink is sometimes mixed to get black. You will also damage the print head on them. Replace coloured ink to fix.
Mar 05, 2010 | HP DeskJet 1120cse InkJet Printer
Empty yellow cartridge, but cannot print in black?
Most printers use a little of all inks in their functioning, just to keep all the inks flowing, so while it is not printing yellow, it uses it in the startup mode to verify function and cleaning mode to clean the nozzles. Manufacturers usually do not put in a bypass for this, because they make money mostly on selling you ink cartridges.
Jan 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Bypass out of ink error on Epson CX6600
You can't bypass it. It need in in all cartridges, even though you are just printing black n white.
Weird eh?
Good Luck :0)
Nov 06, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printing in black & white when color cartridge ran out
One of the possible reason why you can't print black in white because Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. More than that Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head.
Apr 15, 2008 | Epson Stylus Photo 1280 InkJet Printer
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
I had the same problem. Had no choice but to buy the colors I ran out to make the printer work. In order to avoid future problems and save on color inked I attempted to follow the steps of a previous posting, however, that did not work for me. This is what I had did. Print, select properties, advance, continue, check box - Black ink only. Remember when you decide to print in color you must reset your setting and take out the check from the - Black ink only.
Sep 08, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Xerox Phaser 8560MFP Laser Printer Logo
305 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
