Question about Sharp UX 108 Roll paper Thermal Fax
All function mode in ux-108
Every time i dial or press any button or mode its always came out in LCD 6 66666 can you help me about this problem of my fax machine?
  • victor196124 Sep 05, 2008
    your right! the push button switch of number 6 is stock down i dismantle it and remove that button switch using soldering iron and and i test it in a tester and its work fine. but then when i put it back it never dial it anymore on its own.
    i there for conclude that the push button switch of number 6 is stuck down or grounded. and it helps the things i did to release the stock up of that button.
    thank you for helping my problem i really appreciate your response
    Genius:
  • 2,120 Answers
It sounds like 6 is stuck down. Try shooting some canned air around the number 6
Posted on Sep 05, 2008
Manual sharp ux 108
Posted on Nov 07, 2008
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
How to change language?????? kindly explain
Click on the link below to view the Sharp UX 108 user manual. Inside this manual it will show you how to change the language:
http://www.scribd.com/doc/31544424/Sharp-UX-108-UX-178-UX-188-User-Guide
Jan 26, 2011 | Sharp UX 108 Roll paper Thermal Fax
Cant receive faxes using sharp ux-108 model
If it sends ok, then it has probably been switched to "manual reception" or "telephone mode" from "automatic reception" -check manual on how to set.
Dec 04, 2009 | Sharp UX 108 Roll paper Thermal Fax
Sharp facsimile ux-104 how do i send a fax
with phone line plugged in, insert page face down into machine, dial the fax number, press the send/start key.
Jun 30, 2009 | Sharp UX 108 Roll paper Thermal Fax
Sharp UX-B750 won't automatically answer calls.
Your reception mode is set to TEL/FAX or TEL mode, to set it to automatically receive faxes it should be set to FAX. Look at the LCD display ( right section ).
To change the reception mode you can print the HELP LIST by pressing COPY/HELP button.
May 26, 2009 | Sharp UX-B750 Inkjet Fax
Sharp Fax machine - UX-B700
Try this:
Set the fax machine to AUTO reception. Next, you would want to set the proper settings in your Option Set List. To print a list press the FUNCTION key, the number 2 key, then press the # key until it reads OPTION SET LIST in the LCD screen and press the START key. This will print your list. The following settings should be seen: Number of Rings 1 to 4 rings (setting #2) Dial Mode- TONE (setting #8) TAD Connected- OFF (setting #9) * Quiet Detect Time- 04 seconds (setting #10) * Distinctive Ringing- OFF (setting #12) **
Let us know if this doesn''t fix it... we can go from there!
Maggie B
Feb 24, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Cannot find solution to how to replace paper for the Sharp UX-108 Fax machine
I must have an operation manual so Ican follow instruction and at the same time I will know what is the trouble.
Jan 17, 2008 | Sharp UX 108 Roll paper Thermal Fax
Al-1551cs / L!
Sharp Error Codes
Sharp ram clear (most models with LCD displays)
Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Sharp UX-170 maintenance mode: Turn power on, set the line selector at "T" (tone), turn the program switch ON, then press 9 * 8 # 7. Select the next entry from this list: 01 all black copy, 02 ROM/RAM check, 03 auto feeder mode, 04 aging mode, 05 panel check mode, 06 G3 transmission, 07 check pattern, 08 product check (includes diags, 06, 03, 09), 09 signal send mode, 10 memory clear, 11 led array on mode (lamp), 12 product program sw mode, 13 telephone number list printing mode, * soft switch mode, # transmission level. This same procedure works on similar, older models that do not have an LCD display.
Sharp UX-2100 often has power supply problems which cause the unit to lock up.
UX-3200/FO-3250: FO32TD toner/developer costs less than UX30TD and will work in the UX model if 2 fins are broken off so that the unit can be installed in the UX model. Similar duplicity exists with many Sharp laser supplies.
Sharp FO-4800: fuzzy print often results from a bad Motor PWB (polygon mirror) #RMOTN0020GCZZ located in the optical unit.
Nov 06, 2007 | Sharp AL-1551CS Printer
Sharp UX 108 Roll paper Thermal Fax Logo
111 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
