Question about NEC MobilePro P300 Pocket PC
Play audio files
Can the P300 play audio files?
    Master:
  • 903 Answers
Yes, the P300 can play MP3 and WMA music/audio files.
Posted on Sep 15, 2005
My cd30 don't know play the mp3 audio files
Hi
Not all players want to play mp3.and it no use asking him (maskuline in my language) to do it You either have to wait un til you get a new one or play the "ordinary"ones. .
good night
kollagunn
Mar 06, 2012 | Car Audio & Video
Dear sir, i have compaq presario cq40-330tu laptop.i want to play audio in my laptop by using windows xp
...please check your audio driver of your computer if install already or check your audio player if this player can play the audio format that u played...if not install, try to install first before you can play an audio files...or install a audio player that can play the audio format that you have...
Mar 02, 2011 | Computers & Internet
Nokia 6600
You can play any type File in Nokia 6600.But One thing you should be noted that
  • It can Play WAV file With default player
  • It can Play AMR file And some other simple format usually not needed
Actually you needed to play MP3 Files in your Mobile...For Playing MP3 file.....YOU CAN PLAY MP3........
  • You should have MP3 player /any other Playing Software in your Mobile
  • Or You Should have mp3codec in your MObile
You can get Mp3 playing Software From HERE
Mar 28, 2010 | Nokia 6600
CD's won't play on Home & Car stereo after Burning in Mp3 or WAv
most older car and home stereos will NOT play mp3's or wav files reguardless what kind of CD they are written on.
You need a newer stereo OR convert the mp3s to cd audio and then burn them to any recordable cd.. (audio cds can be read by any cd player but will take more space)
May 19, 2009 | Dell Dimension 3100 PC Desktop
How to play audio clip in java
  • Create an AudioClip object
  • Load .au sound file into AudioClip
  • Play sounds once or loop continuously
  • Stop playback
Here's how the code for these steps looks:
import java.applet.*;
AudioClip ac = getAudioClip(getCodeBase(), soundFile);
ac.play(); //play once
ac.stop(); //stop playing
ac.loop(); //play continuously
It would seem logical to use this same code to play audio clips in a Java application. Unfortunately, if you do that you will get errors from the compiler. Why? Because the AudioClip object and the getAudioClip() method are part of the java.applet package -- and are not part of applications. The good news is we can dive down and make things work ourselves.
The trick to solving this problem is to use some undocumented features that are provided by Sun in its JDK. Taking a peek inside the classes.zip file from the Sun JDK (using any of the various zipfile utilities), we find not only the standard Java packages such as java.applet but also sun.audio. (These are in the directory sun/audio.)
The sun.audio package contains everything we need to be able to play audio clips! Here's the code:
import sun.audio.*; //import the sun.audio package
import java.io.*;
//** add this into your application code as appropriate
// Open an input stream to the audio file.
InputStream in = new FileInputStream(Filename);
// Create an AudioStream object from the input stream.
AudioStream as = new AudioStream(in);
// Use the static class member "player" from class AudioPlayer to play
// clip.
AudioPlayer.player.start(as);
// Similarly, to stop the audio.
AudioPlayer.player.stop(as);
To use a URL as the audio stream source, substitute the following for the input stream and audio stream setup:
AudioStream as = new AudioStream (url.openStream());
Playing the audio stream continuously adds a bit more complexity:
// Create audio stream as discussed previously.
// Create AudioData source.
AudioData data = as.getData();
// Create ContinuousAudioDataStream.
ContinuousAudioDataStream cas = new ContinuousAudioDataStream (data);
// Play audio.
AudioPlayer.player.play (cas);
AudioPlayer.player.stop (cas);
Jan 22, 2009 | Computers & Internet
Coby mp-833
If your adding music to the device and its not playing, its because your audio files are not the correct format. This unit only plays MP3 audio or Uncopyrighted Windows Media Audio files. You can test this by connecting the MP3 player, copy one of the sampe audio files under 'My Music' location on your computer and paste it on your mp3 player. It will play the audio fine.
How to play: Hold in play button until red ligh is steady, then press Play again to start the audio.
Make sure you remove any audio file that is not the correct format.
to check format of song:
right click the song, go to properties, under properties it will say 'Type of File', make sure this says MP3, thats the safest way to go.
Aug 22, 2008 | Coby MP-C883 MP3 Player
Hi my Windows Media Player cannot play any files now
open it up, and find the files button and check all files.
Apr 09, 2008 | Microsoft Windows XP Home Edition
Sound card wont play root media files
Hi Hughdog
well, Biostar mobos are know for a lot issues, but depending too, on the OS, windows XP I presume, go on safe mode, and uninstall all audio drivers, and disable on the BIOS audio. then start the PC, and install the audio card. or if is a internal audio reenable again, redetec the drivers, and install them according to the CD and drivers. you should see the play device now and play music correctly.
good luck
Nov 19, 2007 | Computers & Internet
NEC MobilePro P300 Pocket PC Logo
77 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
