Question about Palm Treo 700w Smartphone
Treo 700w-Blank screen
I have a blank screen. Reset and removing battery didn't help. Keypad lights up and the sounds of the Treo are present but unable to send or recieve calls.
  • vdas48 Sep 04, 2008
    Treo 700w. I have a blank screen. No phone in or out. Keypad lights up and I've reset and removed battery.The reset audio 'chime' is working but I have nothing but a blank screen. Treo has worked fine for the last 18 months.
  • Palm Master
  • 19,396 Answers
Blank screen often is phone not booting up, not necessarily the display.
Any internal fault can give you same problem.
Posted on Sep 04, 2008
  • 435 Answers
Did you know that the phone and screen can be turned on and off independently of each other? The phone CAN be on and ready to use when the screen is turned off. You can use the other features of the treo without turning on the phone.
If you are not on a call and the screen is off briefly press the power button to wake up the screen. Just do this once! Repeatedly pressing this will just turn off the screen again.
Press the center of the 5-way to turn off the keyguard (which I almost never use) Then, press the power/end button and be patient to wait for the signal to show up.
It sounds like you have set your screen to turn off after 10 minutes of inactivity. If this is okay, then so be it . If not ,you can change this by going to settings>power>advanced, and select the amount of time you wish the screen to be on. I have 1 minute when on battery, and 5 minutes when on external power.
Auto-keyguard and touchscreen lockout automatically enable keyGUARD after your set period of inactivity. To disable, press center of 5-way.
I do not use keyguard because I found it to be more of a PITB than helpful. So my keyguard settings under the settings tab>personal>keyguard are:
Autokeyguard: Disabled
Disable touchscreen: unchecked (while on call in today screen)
  • 66 Answers
The phone and screen can be turned on and off independently of each other? The phone can be on and ready to use when the screen is turned off. You can use the other features of the treo without turning on the phone.
(try holding down the power key when placing the battery into the unit to do a hard reset)
hope this helps
  • Palm Master
  • 13,433 Answers
You may have a faulty screen
Have you tried a HARD RESET?
Perform the following steps:
Pull the battery out. Put the battery back in while holding the RED button down and a reset screen will appear.
Push the up button on the five-way to start the reset process.
Alternate process:
Similar to the hard-reset of the Treo 650. Remove the battery cover.
Press and hold the Red radio button.
Use the stylus to depress the reset button next to the battery.
Push the up button on the five-way when you get a prompt to "Erase all data".
Replacement screens are available on ebay.
How do i reset my palm treo 700w
1. Disconnect the Treo from a charger or USB cable.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/End while you insert the battery.
4. When the screen lights up with the logo appears, release Power/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
Dec 09, 2009 | Palm Treo 700w Smartphone
Palm Treo 700W Smartphone is stuck on speaker phone
Soft Reset
A Soft Reset stops all active (or open) programs and "reboots" the handheld. When the Treo powers back up, you'll start with all programs closed and the unit will be ready to use. The soft reset is intended to reset the Treo if it is malfunctioning or has become bogged down.
The Palm Treo 750 can be soft reset by quickly pressing and releasing the tiny red button beneath the miniSD memory card door:
diagram.jpg Hard Reset
A Hard Reset wipes the internal memory and returns the Treo to its factory specs, in effect returning the Treo 750 to the state it was in when you purchased it. All data entered, preferences set or software installed on the Treo after purchase will be lost after a hard reset and will have to transferred or reinstalled via ActiveSync / Windows Mobile Device Center.
power_button.jpg The Palm Treo 750 can be hard reset by pressing and holding the power button (seen left) while at the same time pressing and holding reset button beneath the miniSD memory card door. Press and hold the two buttons until the screen completely fades. When the screen returns, you'll be given the option to "Erase all data." Select Yes to complete the hard reset. The Treo will now be as it was when it left the factory and you can start fresh. You may have to perform a soft reset after the hard reset to get the unit to power on.
May 11, 2008 | Palm Treo 700w Smartphone
White screen and keypad lights blink
tke out the battery then get an eraser just rub the battery connector sideways....be careful not to dislocate the connector.....and put the battery back-in...u're phone work after this...just email me rosleycatarata@yahoo.com if it works.....
Sep 03, 2009 | Palm Treo 680 Smartphone
The screen is blank white and the back light keeps flashing
Sounds like your charger isn't working. Meter it. Also possible, it may nt be working IN the phone.
Aug 08, 2009 | Palm Treo 680 Smartphone
Palm treo 700w stuck
Have you tried a Master Reset?
Hold the red power (end call) button, take the battery out, replace the battery. You will be prompted if want to reset the phone with Up for yes, and Down for no. This is how to completely wipe the phone to the state it was when you first bought it. Please make sure to have any custom applications and data on the device (other then data that comes from outlook) backed up. When you resync it to outlook, your contacts, emails, calendar etc will come back.
If after a master reset, the phone does not power on, then you will need to get it replaced, as this is a definate sign that the mainboard inside the motherboard is bad.
Mar 13, 2009 | Palm Treo 700w Smartphone
No Screen on Palm Treo 700wx
Send the device to the people over at www.fhonwizards.com for them to troubleshoot and most likely replace the screen.  Although, it may only need to be reconnected inside.
Feb 12, 2009 | Palm Treo 700w Smartphone
Blank Screen
Remove the battery and SIM card, wait about 5 minutes and re-insert everything. If the screen shows up, well and good. If not, there is a problem with the display and you will need to get the device serviced.
Sep 06, 2008 | Motorola Mobility RAZR V3
My treo 700w phone is off
hold the red power button down for 2 sec then it should say welcome if not then take the battery cover off and to the left of the battery is a reset button you can press with the sylus
Jan 03, 2008 | Palm Treo 700w Smartphone
Palm treo 700w
I was able to find many parts for my 700w on ebay including keyboards. You should be able to find what you need too and the keyboard is a sinch to remove and replace onew you have the two needed tools to open your phone, the T-6 screw driver and a cover removal tool that help unsnap the cover which is a bear to do without the tool. Do an ebay search to "Treo Cover tools" or "Touch screens for Treo 650" and you should find all you need.
Robert R.
Nov 03, 2007 | Palm Treo 700w Smartphone
Palm Treo 700w Smartphone Logo
148 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
