Question about GE Spectra JGBP35 Gas Kitchen Range
Oven takes a long time to preheat
My oven takes a very long time to preheat. Sometimes it takes 30 minutes or longer to go from 100 degrees to 200 and up to an hour to get to 350.
  • 1 more comment
  • deeinma Oct 05, 2008
    I have the same problem, but, it can take an hour or longer to preheat and sometimes, never heats to the needed tempurature!! Have you repaired your problem? If so, how? Thank you
  • soxfaninME Oct 12, 2008
    Similar problem-would set oven to preheat with either convection bake, convection roast or bake and 15 minutes later it would still read 100 degrees with the oven still ice cold. Began to ignite a stove top burner after I had set the oven for preheating and, after running it for 30-60 seconds, the oven ignites then the temp starts rising pretty quickly.
  • Richard Slaten Jan 01, 2009
    My 25 year old original electric Hotpoint built-in oven suddenly takes a lot longer to reach 350 degrees. What's the problem? Thanks
  • 1,543 Answers
You don't list a full model number or how old this range is, or how long / how often you have this problem, but generally it sounds like the oven ignitor is not quite drawing enough amps to allow the gas valve to open regularly. It could be a low voltage related issue, but most likely is a failing oven ignitor. ( WB2X9154)
Posted on Sep 04, 2008
How long do I bake an 8lb shoulder pork roast?
hi Dianna.
Roast in a preheated 500 degree (F) oven for 20 minutes. Reduce heat to 300 degrees and roast for an additional 30 minutes per pound. Total cooking time for an 8lb roast should be about 4hrs and 20 minutes. Remove the pork roast from the oven and let rest for 30 minutes
How long do bake an 8lb shoulder pork roast Google Search
Dec 14, 2017 | Grilling
My oven bakes, but it takes 30 minutes to preheat
Hi friend, thank you for your post!
I know from your post that your Frigidaire oven is working but the preheat takes 30 minutes. This does sound like lengthy amount of time for preheat to be completed. From what you are describing it could be an issue with the panel, element, or thermostat. Since it could be anyone of these underlying issues I would recommend having a professional come out to diagnose your refrigerator to determine the root cause to reduce the risk of unnecessary parts. -Matt
Aug 06, 2014 | Frigidaire 30 in. Electric Gallery Series...
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
Whirlpool gold oven
One must preheat the oven to the desired baking temperature. If the oven is turned on and the food immediately put in to bake, it will take longer to bake the first batch than the second and subsequent batches, because the oven need a few minutes to heat up.
In other words, the oven isn't at 350 degrees the instant you turn it on. It takes about 15 minutes for the oven to reach 350 degrees. I hope this helps.
Jan 20, 2014 | Kitchen Ranges
When i turn on the oven it starts up as normal , "on" then "Preheat" then runs. About 30 minutes later both the "oven on" and the "preheat" indicator lights start blinking.
follow this test and fix it. God bless you
Oven Igniter
As the oven igniter weakens over time, it will take longer for the gas valve to open. If the oven doesn't bake evenly, it may be that the oven igniter isn't opening the gas valve when it should. This will cause the oven to cool down more than it should before the burner reignites. The oven temperature should not cool by more than 40 degrees before the oven igniter relights the burner.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't heat the problem is usually with the heating components. However, if the oven control board is bad, it might not send voltage to the heating components. To determine why the oven won't heat, first test the simpler components in the circuit. The oven control board can't be tested easily and will have to be replaced if it is defective.
Nov 04, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Turn the oven on to preheat, it beeps says that it is preheated but heats at about 100 degrees less than what I have set it for. This just started.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Oven sometimes doesn't heat up. Sometimes heats up to desired temp, then quits working. Sometimes doesn't even heat up at all. When preheated light comes on, thermometer in oven usually says about 100...
This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 14, 2010 | Amana Ovens
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
GE Spectra JGBP35 Gas Kitchen Range Logo
3,176 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
