Question about Whirlpool Duet GHW9150P Front Load Washer
Smelly drain water
When my front loading washer drains it smells rancid. I have run bleach in empty cycles to try and remedy this problem, but it continues to return. I even replaced the drain hose thinking water was sitting in the hose and causing the problem. Is there anything else that can be done? Please help! Thanks
M Larke
  • Anonymous Nov 20, 2008
    If I wait a day in between washings I get the same BAD smell. Like the tub didn't finish draining. It's gross.
I had the exact same problem and all of my clothes smelled like mildew. I switched to laundry detergent for front loaders ONLY and have eliminated this all together.
Run an empty cycle one time with 1cup of white vinegar.
Then start washing with the new detergent.
Posted on Sep 04, 2008
Amana washer smell
You have mildew in the machine, best way to prevent it is to keep the door cracked open when not in use. Only way to remedy current problem that I have found works for sure is physically taking the machine apart and disassembling the drum and cleaning it by hand. I had to do my frontloader like that.
Feb 16, 2018 | Washing Machines
My kenmore front load washer has aquired this rank moldy smell. If don't take the washed load out immediately the nasty smell penetrates into the clothes and smells even after drying. Is there some sort of...
you can run a regular cycle with bleach as instructed in the manual. there may be mold on the rubber where the door closes. wash this with water and bleach. to avoid this problem in the future you can loosen the light bulb then you can leave the door open a little all the time with no light. press the off button when not in use.
Jul 26, 2017 | Kenmore 44921 Front Load Washer
Sewer smell when I use the front load washer
try rid-x see if that helps pour down drain pipe for washer then add water you may also want to pour rid-x through toilet as well and bleach out washer
Dec 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
Mildew in ge front load washer
Try two things: Add several cups bleach to the tub and run it a complete cycle. When not in use, leave the door open so it will air out.
Jun 04, 2009 | GE WBVH6240F Front Load Washer
Clothes are sooaking wet when cycle finishes and they smell bad
The wetness is due to the spin cycle either not working properly or not being allowed to finish. For the smell, with the washer empty, run a cycle on hot/whites with bleach only, after the first cycle drains, open the washer and add more bleach directly into the washer.
Apr 20, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Whirlpool front load washer smells
I have a front load washing machine too and my instruction booklet says to run it on the clean cycle once a month with the bleach up to the max. I do this every month with out fail. I also the last load of laundry I leave the door ajar. It will usually dry completly in a few hours. Hope this helps
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Large Appliances
start by cleaning out the filter in bottom,
remove the access panel bottom 3 screws , open filter , some excess water will spill ,
clean it out,
next clean under the rubber flap around front of drum.
run borax through a cycle.
run clorox in a cold cycle
the issue may be that the back of the drum is coated with waxy goop from using too much softener,
Mar 24, 2008 | Kenmore Elite 45986 Front Load Washer
Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Nov 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
137 people viewed this question
Dan Webster
Dan Webster
Sal De
