Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
KM 280MAH ICE PRODUCTION LOW. CUBES APPEAR CLEAR BUT NOT FULL SIZE.MACHINE HAS BEEN THOROUGLY CLEANED. HAS NEW WATER PUMP, WATER FILTERS NEW, WATER LEVEL APPEARS GOOD.
  • 828 Answers
Check the condenser if it is restricted in any way it will decrease ice production. Check for water overflow from the sump. Any more water than necessary entering the sump will also cause a decrease in ice production.
Posted on Sep 05, 2008
NEED A REPAIR MANUAL FOR KM-280MAH
Technica go to this web site and look for manual on right hand side.
Look for REV 4-15 and it says for "ALL H SERIES."
Jun 25, 2014 | Hoshizaki Freezer Commercial Ice Machines...
I Have A KM-900MRH Ice Machine Hoshizaky i, recently changed the water pump, and now sims to be that ice is really thin, and is not making enough.
adjust the float (White plastic with black rubber bottom) item next to the water pump. It needs to be all the way down. Loosen the 2 screws and slide it down all the way. This is what controls the size of the ice cube. Other possibility is that there is water leaking our of the sump causing and early harvest cycle to start. Look for both.
Sep 13, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
Feb 12, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Please Heal
starving for water. clean or replace water filter or adjust water float assembly that determines how big cubes are. probably not getting abundant water during timed fill sequence. no water equals little ice.
Sep 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Harvest cycle on ice machines
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
Jun 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Ice cube cycle time very high
i suspect a defective liquid line or pump down seleonid coil. just make sure you hear the "click" when it starts up if not the selenoid coils could be defective. also verify that the condenser fan is running,because if not you are short-cycling on high head pressure. please contact if you need any additional info
Jun 11, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
289 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
