Question about Samsung SCX 4521F All-In-One Laser Printer
Fax Machine Samsung Model SCX-4521F
My machine has been receiving and faxing fine. All of a sudden it says Memory 98% and will not receive or send a fax. What can I do to correct this problem?
    Sergeant:
  • Samsung Expert
  • 406 Answers
Kindly update me Is it printing/Copying working properly.
This issue with printing part. Kindly clear memory. Check Cartridges.
Posted on Sep 27, 2008
My all incoming fax is going to machine memory, my machine is samsung SCX-4521F, please advise me how can i solve the same & i wanted to take incoming fax in directly computer, kindly tell me setting...
my all incoming fax is going to machine memory, my machine is samsung SCX-4521F, please advise me how can i solve the same & i wanted to take incoming fax in directly computer, kindly tell me setting of the same. Thanks
Jul 09, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I am using Samsung SCX-4521F machine in which I am able to receive fax messages but unable to send fax using this machine. what should I do to get the problem resolved and to use the machine for both...
Please to assure that the cable from your wall connection go into the printer first and then from there with another cable to your phone. Second set up the printer as fax by using the original soft ware cd or download the programm from samsung webside. Make sure the phone and the fax are compatibile!
Apr 18, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I have an SCX-4521F and suddenly I cannot send or receive a fax. There is notification that a fax has been sent to me, but it does not print. When I send a fax, it tells me there is "no answer"...
Hi, I am Steve and I and going to help solve your issue.
I am going to start with the 2 simple things that may be causing this. Please accept my apologies if you have tried both of these solutions. If you have please let me know and we can go on to more advanced troubleshooting.
As the machine has suddenly stopped sending or receiving faxes I am assuming it was working prior to this issue.
The first thing to check is whether the machine is still setup to enter fax mode. the best explanation for this is directly from the Samsung support - click here for the instructions on ensuring automatic fax mode is enabled.
alternatively the memory could be full. again I am going to use the Samsung support site instructions to help you clear the memory - click here for the instructions and you want to clear the fax memory (option fax feature) if this does not work it may also be worth using fax setup and advanced fax - these will reset the fax machine to its factory defaults.
Please let me know if these solve your issue, if not we can move onto further troubleshooting?
Jan 13, 2011 | Samsung SCX-5115 Fax Machines
Scx-4521f fax not sending and not receiving
4521f printer fax receive but not print so whats your problem
so plz solve this problem
Mar 25, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Describe your i have samsung 4521f laser printer i cant receive fax Problem
Good day Sir,
The condition of your machine is cannot received faxes. My suggested solution is Fax mode should be selected. Make Sure that there is paper in the tray and also check to see if the display shows "Memory Full".
Have a nice day.
Oct 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Cannot receive faxes on Samsung SCX-4521F
I'm not sure if I can help you or not, but I do have a suggestion or 2, that may help isolate the problem.
The solution I gave you initially, is the usual culprit for the situation you are experiencing. If the machine can "send", then "receiving" is not normally a problem, as long as the reception settings are correct. You said that "sending works fine"?
Since you have multiple faxes, you might try swapping the locations, or at least try the Samsung in a known working environment, to see if it behaves the same. If it works on another line, then try the other fax on the "Samsung" line.
That's all I have to suggest right now, but I'd be anxious to hear if there is any change.
Apr 25, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Fax received goes directly into memory of the machine my mchine is samsung SCX 4521F
Good day Sir,
If you don't want other people to view your received documents, you can use Secure Receiving mode. In this mode, all of the received faxes are stored in the memory.
To turn Secure Receiving mode OFF:
  1. Press menu until "Advance Fax" appears on the top line of the display.
  2. Press the scroll button < or > until "Secure Receive" appears on the button line and press Enter.
  3. Press the scroll button < or > to display 'Off" on the bottom line and press Enter.
  4. Enter the 4-digit password and press Enter.
The mode is deactivated and the machine prints all faxes stored in memory.
5. To return to standby mode, press Stop/Clear.
Have a nice Day and God bless.
Apr 16, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Fax problem
I had the same problem! You have to set your fax machine option to DRPD mode. Menu, to Fax setup, to DRPD mode, press ENTER, ENTER again, it should say waiting ring, you then have to call your fax line. Back to Fax Setup, Recieve Mode, press DRPD mode. This way your machine well distinguish a different ring for your fax.
Dec 18, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Samsung scx-4521f fax memory received but never print out.
In 3 second make combination on you Samsung 4521F 'Menu'-#-1-9-3-4. You will enter in tech menu. Select 'toner'-new toner-yes. You will receive faxes. It really works.
Oct 24, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
391 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
