The fuse blows when Phillips televison is plugged into electrcity.
HOW DO I UNLOCK THE TV IT WILL ONLY WORK ON CHANNEL 13
Posted on Nov 06, 2008
Phillips 39" tv problem
a power surge can do alot of damage but does your model have a fused plug? as would check this. if you have changed the power board for a know working one then the main av board has gone this is the board that tells the power board to turn on.
Jul 15, 2017 | Televison & Video
No power supply
yes there is a fuse in a tv, some have a few fuses. usually if the fuse blows then there has been a serious fault and needs to be found before power is plug back in.
May 31, 2017 | Televison & Video
MITSUBISHI XD600U WONT POWER ON, NO LIGHT AT ALL
hi i take it you've checked the fuse in the plug , if ok the fuse inside could have blown, if it as and it blows again then there's dead short in the tv, replace with the same rated fuse thanks
shaun
Mar 08, 2017 | Mitsubishi Televison & Video
The Ele, blinked and now TV won't come on.
first check the fuse in the plug, electricity interruption could be due to a spike, and fuse is designed to blow in case of spike. hopefully just the plug fuse else you will need tv repair perwson
Mar 02, 2017 | Televison & Video
Damaged the plug in cord did I blow a fuse
If there was a spark, I fear the problems could be worse than a blown fuse. The electronics themselves could have been fried.
Feb 11, 2017 | Televison & Video
Philips 42pfl3704d/f7 No power at all
its definitely the fuse. you have to go to the phillips website and type in your model number to get the right fuse. I went thru 3 different fuses and they all blew right away. phillips website sells the right ones 5 bucks each. Get it here and it will save you trouble trust me.
If nothing happens no light or sound when you plug it in to the wall it is definitely the fuse. mine was a T8AH250VP. You have to be sure to get that exact fuse. every letter exactly like that. there are a lot of similar fuses that will blow the moment u plug it in.
Hope this helps took me a month to figure this out. I was going to buy powerbaords for no reason. fixed my 42 inch phillips for under 10 dollars. couldn't be happier. Also always run your tv threw a power ack. If you plug directly to the wall your fuse will blow frequently.
Sep 23, 2012 | Philips 42PFL3704D LCD TV
Why does my abs/speedometer fuse on my 1994 cheverolet astro van keep blowing
at you wheel hub their is a sensor ( you will see electrcal wires runnung from the back of the hub) check each wheel to see if their is a bair spot and its grounding out
Aug 05, 2011 | 1994 Chevrolet Astro
Viking 940 Sewing Machine will not run.
the transformer has broken solder connections between the pins for the plug and the transformer board. Brave? 4 phillips screw. Black box on bottom. remove ribllon cable. Transformer out. 2 screws black cover on transformer off. Theres the board with broken solder joints to the plug pins. The large plug they used on that model broke the solder joint easily. it shoudlnt be blowing fuses though unless he tried to fix it and put in wrong one.
Feb 09, 2009 | Husqvarna Viking 1
Blank
sounds like something in the regulator circuits blowing the fuse. I can post alink where you can get a service manual as well as free support to help you figure it out. Your set is coverd in the DPTV305 series phillips magnavox on page 2 of the phillips section for 10.99 and they email them instantly if you want one.
http://servicemanuals.vstore.ca/
Dec 08, 2007 | Philips 51PW9363 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
