Question about Toshiba Satellite A10 Notebook
Hard Disc I'd like to up-grade HDD on my laptop A10. Hard Disc is MK4021GAS. Which HDD compatible with mine, but bigger volume, can you suggest? Thanks in advance. Pete.
  • 2 more comments
  • PETE0629 Sep 04, 2008
    I have consern about connection and type (ATA-5). Can you give me exact name of HDD compable with MK4021GAS?
    This is Toshiba Satellite A10. HDD is MK4021GAS. I need bigger one, but compartible.
    Thanks.
  • PETE0629 Sep 05, 2008
    Actually, I have 40 Gb at the moment. I'd have 80 or 120.
  • nishg Sep 28, 2008
    I m facing the same prob.want an 80 GB drive.plz tell me the best available option
  • 66 Answers
Hi,most laptop hardrives are the same type  (IDE,SATA are your two main type)
yours is a IDE HDD just have a look online for one or go into a computer shop
(P.S if you upgrade you will have to coppy all your files from your old HDD to the new one)
hope this helps
Posted on Sep 04, 2008
I need to reboot windows xp on my toshiba satellite laptop
The Toshiba Satellite A10-S169 includes several utilities to improve the performance or security of the computer, and to reconfigure the system's settings. Toshiba Satellites running Windows Vista 32-bit and Windows XP come with the Toshiba HDD Recovery Utility, which allows you to create a recovery CD of your system and applications. The recovery CD will allow you to restore your system and its settings in case your hard drive fails.
Click "Start." Click "All Programs." Expand "Hard Disk Recovery Utilities." Click "Recovery Disc Creator." Select "CD" as the type. Check "Recovery and Applications." Insert a CD into the disc drive. Click "Burn." The Toshiba A10-S169 will begin writing the recovery content to the CD. Follow the on-screen prompts to burn your recovery files to disc. Hope this helps.
Jan 10, 2013 | Microsoft Windows XP Professional With...
Tecra A10 won't boot up. Laptop was dropped when running and froze. Shut it down to reboot but doesn't work at all. When the power button is pressed, the HDD LED illuminates for just over a second and then...
I suggest try going to Local Computer Centers, Have them check what hardware's are having problem, most likely there are problem with LCD, Motherboard, HDD.
Apr 21, 2011 | Toshiba Tecra A10 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          SATA hard disc compatibility
          Actually, there are two good reasons not to swap that drive into the new laptop,
          First, you never want to boot from or install software to a drive you're trying to recover as everything you do to/with the drive runs the risk of causing further damage.
          Second even if it weren't for the damage, you simply aren't likely to have the right drivers unless both laptops are the exact same model.
          My suggestion is just get the new laptop you want, then attach the damaged drive with the enclosure to the new laptop then run your recovery software. If that doesn't work, you will likely need the help of a Pro.
          Try Armor-IT Data Recovery, they are listed in the FixYa database and service clients from all over North and South America.
          Hope this helps FixYa,
          Chris
          May 19, 2009 | Computers & Internet
          Hard drive
          I think as bigger drive as ya can afford say up to 80GB.. would be OK.. just make sure that the new drive is same type as old and ya be all good.
          Jul 28, 2008 | Toshiba Satellite A105 Notebook
          Hard disk
          not too hard..should be a couple of small cross screws under the bottom, just remove them, and slide out the old drive..
          May 12, 2008 | Toshiba Satellite A10-S100 Notebook
          I need to replace my hard disk notebook with a bigger capacity hdd
          Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
          You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
          I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
          I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
          Feb 18, 2008 | Toshiba Satellite A10 Notebook
          Want To Replacing My Toshiba A10-S330 Hard Disk
          Normally you can upgrade to a new hard disk to the next bigger size, so from 40 Gb, then perhaps a 60 or even an 80 would work. Even if the BIOS/motherboard would not recognized the new size, Windows XP would and be able to access it.
          However, I don't think that the size should really be the main concern. I think that your selection should be based primarily on the power consumption. Most laptops have a preset power distributed to its devices. If you are going to use a bigger size HD with a bigger power consumption, Windows (or even your BIOS) might recognize it but the power distribution might be over worked.
          My suggestion would then be go to the next size but keep in mind the power rating/consumption of the old when selecting.
          I am enclosing an image of my laptop's HD. Pls note the rating DC+5V 0.7A for this 60Gb HD. The 0.7A is its current consumption/rating.
          Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
          Good luck and kind regards.
          Dec 12, 2007 | Toshiba Satellite A10 Notebook
          Toshiba Satellite A10 Notebook Logo
          113 people viewed this question
          Top Toshiba Computers & Internet Experts
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
