Question about Palm TX Handheld
Palm tx When I try to get on the web my palm resets and I am unable to connect. Than I have the problem of not being able to turn it off. It starts back up again. ???
  • Val_a_kelso Sep 06, 2008
    Hey, my friend and I are having the exact same problem with our palm TX's and we cannot figure out a solution. We are wondering if it is some application that we have on our PDA's, because we have 25+ apps on ours. Do you have any application on your PDA, if so, would you mind sharing which ones you have. We want to figure this out and we want to help you figure it out also, because it is so FRUSTERATING!! Thanks.
  • 39 Answers
Try to delete cookies and cache. then resync. if that does not work try to recreate internet account
Posted on Oct 27, 2008
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Unable to connect with desktop through usb cable
Jan 24, 2011
1 post
Oct 19, 2004
Mar 16, 2004
Dec 18, 2002
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Palm unable to read card
Usually you just need to reformat the card to fix it. It may be reable in a pc/laptop so you can get anything important off first. Reformat copy your stuff back on and you should be good to go.
And yup this happens rather randomly and at the most annoying time possible usually ;-]
Mar 19, 2010 | Palm TX Handheld
Have to reset Palm TX to power on sometimes
I have a palm TX and it usually just sits for a minute or two when I use blazer. I have also found out that the pda will always reset itself and it only freezes when it has a lot going on. It stays frozen for a while, but eventually unfreezes. As for the home button, it's probably worn down. My power button and my up button have almost completely stopped working.
Sep 09, 2009 | Palm TX Handheld
My 5 yr old Palm Tx suddenly started trying to
I did a warm reset and it worked. Just hold the up key and reset!! good luck
Aug 29, 2009 | Palm TX Handheld
Unable to connect to internet
Here is a link to Palm support services. I recently had a problem with my TX and I did the free chat service they offer. The technician I had completely solved my problem. You can do a phone support if you want but that will cost you around $15. The chat and forums are free. The chat feature is towards the bottom of the page. Hopefully this will help. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/supportservices/page_en.html
Jul 23, 2009 | Palm TX Handheld
Palm TX handheld
First you need to reset the TX:
hold the reset button on the back of the unit, then turn the power on. Hold the power button while releasing the reset button. The TX will power up to the screen where it will ask you if you want to reset it to factory default.
Afterwards go to this link,
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1568,E=0000000000263321976,K=3877,Sxi=4,case=obj(32859)
and download the Palm Desktop/Sync software and install it onto your PC. After installing the the Palm Destop software, connect the sync cable to the PC via the USB, then connect the cable to the TX and push the sync button.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 29, 2009 | Palm TX Handheld
My Palm TX device is not initializing. it says "palm powered" then a loading bar starts at the bottom of the screen, then it turns off...and it repeats the same thing over and over again.
Have you tried a hard reset? In case you need to know how...Hold Power button on Top of Palm down, then press reset button, then release reset button and continue to hold power button down until second Palm logo comes on screen and progress bar at the bottom of screen completes. If you release the power button and it asks which language you want to use you have done this correctly.
Jan 21, 2009 | Palm TX Handheld
Error on palm tx page requested cannot be displayed
You need to clear previous network settings and reconfigure again.
Jul 14, 2008 | Palm TX Handheld
Palm TX Handheld Logo
42 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
