Question about Hitachi 1TB External USB 2.0 Hard Drive
Problem with Hitachi 1TB external hard drive
Hello,I bought a hitachi 1 tb external hard drive (110 volts) and accidentally plugged it into a 220 volt outlet.
When plugged into 110 volts again, it cant be detected through the USB port.
Is the any chance I can still recover the data stored in this drive? Is it just the adaptor that was damaged or is it the hard drive itself?
Kindly email me for answers at laketiko@gmail.com.
Thank you very much!
Most likely you just burnt up the adaptor. You can order another one from Hitachi.
The data is probably still intact on the drive itself.
You can connect it to your computer with an adapter that plugs into the drive itself and the usb port on your computer. It then shows up as a drive letter as normal.
You can buy these sata to usb adapters at most computer stores for around $25. Tiger has a nice selection:
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=sata%20to%20usb%20adapter
I would pick one with an external power supply. It also connects to your hd. The ends are keyed so you can't miss-plug them.
Or find a local computer tech (most have this cable in our toolkit) and he probably will copy your data in a few minutes for you.
Posted on Mar 05, 2009
  • 734 Answers
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 12, 2008
How to fix couple of DELL desktops where I plugged them into 220 volts Power supply when they were set for 110 volts? More details below.
you could try replacing the power supply. if it still does not work, you probably fried the processor or motherboard. (or both). just make sure the replacement power supply has the same type of connectors on the power leads to the motherboard, hard drive, etc.
Aug 15, 2015 | Dell OptiPlex Computers & Internet
Driver wont auto download
The model number you are referencing is an 1TB Internal SATA Hard Drive and does not require drivers to install and function. Did you install it in a external drive enclosure? Can you explain better what you are trying to do?
Apr 28, 2014 | Hitachi H3D10003272S) 1 TB SATA Hard Drive
Power supply specs Hitachi Lifestudio Desk Plus
Hitachi Lifestudio Desk Plus Hlsdpub10001bbb 1TB Drive and original AC adapter have been separated. Need to know Adapter output Voltage/amperage identify original or acceptable replacement.
Sep 17, 2013 | Hitachi Lifestudio Desk Plus...
Hitachi 1 TB external hard drive won't power up
yes you can fixed it replase cover and and cut hdd and buy new rak out side and conected the new rak with hdd that is very esy
Apr 23, 2013 | Hitachi Touro Desk 1 TB USB 20 External...
SATA Hitachi 1 Tb HARD DRIVEi AM TRYI8NG TO INSTALL A NEW HARD DRIVE ON MY DELL 4700 AND I CANT FIGURE IT OUT IT IS SAYING NO ( BOOT DEVICE NOT FOUND)\
Dear Jackson,
If you are connected your new hard drive, You just have to go into BIOS and set your old hard drive as first boot device . its all. for BIOS choose f2 or f10. Good Luck.
Nov 20, 2012 | Hitachi 1TB External USB 2.0 Hard Drive
Hitachi 1 TB not showing
You need some expert help. Do a google on "do it yourself data recovery consultant"
Oct 24, 2012 | Hitachi 1TB External USB 2.0 Hard Drive
Hi i'm from greece and i bought a hitachi simple drive external hard drive 1 tb about 4 months ago it worked fine but now suddently it stopped . i tried to take it of the power and i also removed the cable...
you must have short in the wire hooked up to external try jiggling the base of wire pluged up to port on the external see if you see the light on hard flicker on off if thats the case its your wire for right intell you get a new wire prop something underneath wire intell you see the light stay on.
Feb 24, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
My XP will not boot when my Hitachi 1TB External USB 2.0 drive is connected. It gets as far as showing the Pentium screen and stalls.
Its probably trying to boot from your external drive.
Go into your bios and reset your boot setting to HDD0 as your first boot device, Disk drive 0 second and floppy third, unless you want to boot from an external drive. That being the case select an appropriate order.
If the bios shows your external HDD as HDD0, then you have to work out which is the drive carrying the operating system and set that to your first boot device.
To get into the bios, watch the boot screen for a key to hit to enter setup, normally its the "DEL" key.
May 03, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
Dead hard drive -retrieve data?
take your drive to a computer hardware
i think the media of your disc is weak
change the media after consulting the hardware mechanic.thanks
Dec 28, 2009 | Hitachi 1TB 7200RPM 32MB BUFFER SERIAL ATA...
Hitachi 1TB External USB 2.0 Hard Drive Logo
386 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
