Question about Samsung SCX 4521F All-In-One Laser Printer
Problem with printing
I keep on continually getting as CRU fuse error when printing. i have put new cartridge in and it isnt it.
Its when the machine hybernates, and a new print task is sent to it that it happens. if the printer is at ready stage and a new print job sent to it then it doesnt have this error message
to rectify the problem i onyl have to open and close the printer cartridge door.
it quite a strange error and i was wondering if you can help please
    Problem Solver:
  • 8 Answers
CRU Fuse Error The toner cartridge is
not installed correctly.
Install the toner cartridge
correctly. See “Replacing the
Toner Cartridge” on page 8.4.
www.zinetic.o.uk
Posted on Sep 19, 2008
CRU FUSE ERROR SAMSUNG
hello,
their is small fuse in your toner cartridge.you have to replace it . it is also damage.
Jan 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Inserted new toner it says CRU FUSE ERROR
If you have a CRU Fuse error, you have probably purchased an after market toner cartridge. If so, take the cartridge out of the machine and at the back of the cartridge you will see a small 'dummy' fuse. Take that 'dummy' fuse out of the cartridge and your printer will work. I know, it happened to me.
Nov 16, 2010 | Samsung SCX 4521F All-In-One Laser Printer
I have error with this title: CRU Fuse error, but this is not stable. if i put out the cartridge and put-on again. it will removed and machine will running well. but it will come back at the next print...
This is a fuse error which is on the Cartridge, please check the cartridge very carefully, the fuse is somewhere on the edge of the cartridge/s, simply remove it and try again. You problem will be fixed. I hope your cartridge must be similar with this one.. (click here)
Fuse:
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 30, 2010 | Samsung SCX-4016 Laser Printer
How to solve CRU Fuse error ?
Check the TONER Cartridge and Reinstall it
CRU Fuse Error
Means : The toner cartridge is not installed correctly
You can set the machine to ignore the “[Toner Empty]”
message and to continue printing incoming faxes.
Ignoring the Toner Empty Message
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button < or > until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button < or > to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Jan 21, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Error fuse CRU, how to solve it? Thank you!
first u must change the fuse in toner cartridge,or u can take the fuse out off toner cartridge and put the programme menu # 1934 menu and going to new cartridge .
Nov 02, 2009 | Samsung SF-560 Plain Paper Laser Fax
CRU fuse error , the machine is not working.
I'm guessing that it''s remanufactured?
There is a small fuse on the front of the cartridge that may have not been replaced (or not installed at all). This is required to reset the toner unit - it basically blows at installation.
You can try this -it applies to another similar model, but may work for your as well to reset manually:
Press "Menu"....1934 (you may have to press "#" before the number??)
display will read something like "Tech mode"
Keep pressing "Menu" until displays "new cartridge"
Then press "yes", or "ok" or whatever applies to reset.
Please rate me
Mar 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
CRU Fse error
Was the "Off Brand Toner" a used refill cartridge? Usually this error is caused when the drum (That statically attracts the toner to it) has worn out. This can be caused by too much light exposure, or just from overuse.
I would suggest bringing back the cartridge where you bought it from and asking them to switch it out.
Oct 22, 2008 | Samsung ML 2010 Laser Printer
Cru fuser error
I already solved the cru fuser error by replacing the fuse of the toner cartridge.Thanks anyway for this information.
Jun 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Have a cru fuse error
Rick and Felix are discussing the fuser, not the fuse error you are getting with the your printer. The error relates to a small fuse that is on the toner cartridge which goes into the printer. I am having a similar error message after getting a replacement from Cartridge World (although this is not the first Cartridge World replacement for this printer).
After much research, one suggestion was to remove the cartridge fuse and reinsert the toner cartridge. That worked for me and the CFU Fuse Error message disappeared for me, but I am trying to find out the PURPOSE of having a fuse on the toner cartridge itself. To protect the toner cartridge? Protect the printer? Other?
Mar 10, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Double page copies and CRU Error
CRU Fuse error equates to a problem the machine has reading the print cartridge installed in the machine. It has nothing to do with the fuser.
Suggest that you change the print cartridge.
Oct 01, 2007 | Samsung SF 5100 Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
272 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
