Question about Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint FFA70S fridge drain blocked
The drain at the back of the fridage has become blocked. I have tried to unblock by pushing a piece of wire down the outlet but still no joy. Is this anything I can buy to unblock (like sink pipe unblockers) or can I get to this pipe (it is not exposed at the back of the fridge until the drain at the bottom of the freezer).
M Makin
  • mikem212 Sep 06, 2008
    Thanks for this, I've tried poking a wire down the hole quite far and it comes to a hard stop. This would suggest a blockage quite far down so not sure such a device (i.e. snake would help).
    Difficult to see how to unblock unless I can really get at the pipe itself.
  • Anonymous Dec 07, 2008
    The drain at the back of the fridge is blocked. I have tried to unblock by pushing a piece of wire down the outlet but no LUCK
  • 639 Answers
ngfam1 at your service,
Do not use sink chemicals!!!!!!!!!!!!!!
In the hard ware stores or home depot they have small short,
snakes that are flexible and thin that can go in the hole to clear it!
Tell the home depot guy to help you find what I'm
telling you to buy!Print this out and show him what I spoke of!
Bless you,
Please give me a good rating before you signe off
Posted on Sep 04, 2008
Doing good. Carry On!!
by:Plumbers Brisbane
Posted on Jun 08, 2012
Hi our CB18M/1c/FAN keeps gathering water under the salad trays please advice thankyou
You say it runs down the channels.
Is their a drain hole at the bottom?
If the drain hole is blocked then you will need to unblock it using compressed air or a thin piece of medium flexible wire.
It should drain to a pan near the compressor and evaporaste from
there. Sometimes a loose particle of food can block the drain, usually at the back lower position of the fridge.
Jul 25, 2015 | Refrigerators
Hotpoint ffa71
you can dampen a small part of folded to 1/2" wide paper towel, and wrap the dampened paper towel around the end of a straw, stick that in the drain hole and blow.
Apr 30, 2013 | Refrigerators
Water comes in from top under freezer and I get a lot of water in ther drawers and it come out onto the floor from the inside of the refrigerator
you have a plugged drain.take out all the food in the freezer,unplug the machine,remove the ice maker and the back inside wall of the freezer.hit the ice on the floor and crack out as much of it as you can with a plyers or easily with a hammer,then melt out the rest with a hair dryer.once you melt out the ice now you have to free up the'll see a hole under the evap coil,when the heater comes on the ice melts off the coil and drains through thhe hole down to the bottom where it evaporates from the heat of the compressor and condenser coil.your drain is blocked and the water can't drain down.i use a steemer to clear out the drain but if you don't have a steemer you can try a turkey baster or any thing that will push air down the drain to clear it.when you think it's clear pour hot water into the hole,if it drains down you cleared it if not,blow hot air down the hole with the hair dryer thhen try the baster until you free it.when it's clear if you have like a 6 inch piece of house electrical wire or a cable wire strip it down to the copper wire,stick it into the hole and wrap the other end around the heater,this way when the heater comes on the wire will heat up stopping the drain from freezing up so it can't block up any more.let me know how you make out
Feb 21, 2011 | Refrigerators
Clogged drain line, water build up inside food compartment
if lucky you can unblock it with a wire coat hanger, just unravel hanger and push down drain hole.
this does not work pull fridge out and u will see the hose running down to the dissapeter, remove it and clean
if you cant see hose at back it is internal and cannot be taken out
find hole above compressor where water comes from and try to unbock from bottom using coat hanger
if blocked with ice at bottom usually means insulation has broken fridge needed
Sep 25, 2010 | Refrigerators
The hole that drains water away at back of fridge is blocked
Ok you need to defrost this unit eg unplug and leave all doors open for 48 hours then get some "flexy curtain wire (white plastic coated, used for hanging net curtains) this wire is perfect for getting up or down the fridge drain.
Please rate my advice
Mar 25, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Hotpoint FFA70
This will work in most all cases of this type. You need a piece of copper wire, 14 guage, 12 to 16 inches. You can shortin it as you need to Turnoff the power to the fridge. Rap one end of the wire around the evaprorator heater and feed the othe end down the drain tube. This wire will heat up when the heater comes on and will supply heat down into the drain tube hopefully preventing the drain from freezing.
Nov 19, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Water in fridge
does this fridge have a gulley at the back with a drain hole in the middle? if so, the drain is blocked, push something flexible down the drain till water flows away freely
Sep 02, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Water in fridge
Blocked drain channel at back of fridge, get a flexible cable tie of piece of flexible wire push down as far as will go this will resolve fault. Regards Advisor
Aug 20, 2007 | Frigidaire GLRT83TES Top Freezer...
Water on the bottom of the fridge - then turning in ice
drain is blocked. to check, pour water into drain gulley in fridge and it should flow away. to clear, push sometthing flexible down the hole. good idea to pour dilute bleach down hole now and again
Mar 19, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint FFA90 Bottom Freezer Refrigerator Logo
812 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
