Bush IDLCDTV32TV22HD parts supply
Who supplies parts for this model we are looking for a screen driver board (V32Bc3) and also the LVDS cable from the board to the screen .The set is fitted with the Vestel 17MB15 chassis. Regards John (Email John@john.techie.org.uk)
Hi can you said me if you can have the v32BC3 and the lvds cable?? where you have?I have the same problem and i search the same item. thank you .Freddy
Posted on Jun 28, 2009
I have a samsung lnt4066 led TV with a distorted picture. I have replaced the main board, power supply and the t con board with no success. I have pictures of what the TV is doing and would like to sh
You either have a bad t-con board or the screen is bad. Check to make sure all the ribbon cables are seated fully and connected. Even replacement parts can be bad sometimes, new and used both.
Jan 09, 2015 | Samsung LNT4069F 40 in. LCD TV
Tv working fine earlier, then screen turned white.
hi, here is you gonna do first turn off the tv unit and unplug it for a while to reset the power supply. and then re plugged it again then power it on let see if it back to normal operation. if does't work and the screen is only white but with sound the cause is with in the t-con board. the t-con board is mounted underneath cover with metal shield. you will need to remove the back cover to access the internal part. then look for a burnt part in the board, if no sign of burnt part tried to re seat the lvds cable going to the t-con board.
Nov 26, 2012 | Televison & Video
Hi, my goodmans ld3266d powers up with sound only and a horizontal line accross the top of the screen, which appears to be the picture compressed to around two or three pixels deep(no screen damage). is...
do see some what of an osd on the screen when pull up the menu? if you do i would look at the controller board or lvds cable or ribbon cable to panel
May 17, 2010 | Televison & Video
Screen will periodically go half black. Then it goes back to normal. Or the black slowly creeps up from bottom of screen.
Ur backlight video board is dying,just not completely dead yet.Must replaced to solved this prob.
Dec 11, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
A black image appears and goes away every once in awhile. you can still see the picture but the part that has dark image looks all ugly.
When you have video display problems such as shadows and lines that go away after warming up, or come and go during viewing, it is usually the LVDS cable and T CONN board going bad. The screen can have one of the following or combinations of blurs, different layers of brightness and lines. It could be the backlight but most of the problems with the LNT4661F have been this.
I had the shadow and line problem and replaced both the cable and board for $120 and that fixed my problem. The TV was only 18 months old. Since I had the TV apart, I went ahead and replaced the capacitors on the power supply board so I wouldn’t run into the clicking problem that also affects this model TV. You can find the parts numbers for the LNT4661F cable and board below. You can find links to YouTube ( Part 1 & 2) to show how to replace the capacitors. Good luck.
Samsung A/S-T CON BOARD BN81-01312A
Samsung Lead Connector LVDS BN39-00883A
YouTube (Part 1) http://www.youtube.com/watch?v=Mm51C_RDIZE
YouTube (Part 2) http://www.youtube.com/watch?v=BNHHrgX_6cs
Nov 28, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Lg 50pc3dhas a sound but no picture
Failure in either of the following can cause no video output.
  1. Display Panel
  2. Y Drive Board
  3. Y SUS Board
  4. Z SUS board
  5. X Drive Boards
  6. Tape Carrier Package (TCP)
  7. Main Board
Try these if you have electronics background :
Note: Touch your fingers repeatedly to a ground connection point or unpainted metal in the product before proceeding.
  1. Unplug the unit.
  2. Remove the back cover by removing the screws holding it.
  3. Disconnect the LVDS cable from the power supply or from the main board. LVDS cable runs from the right bottom of the power supply to the upper left of the main board. Power supply is located at the upper center of the unit and the main board is at the right bottom of the unit.
  4. Plug the unit back and turn it on or the unit turns on automatically.
  5. Look for the Control Board. It is located right at the center of the unit below the power supply. It has a LED on it.
  6. On the Control Board at the right bottom of the MCM chip, the big chip right at the center of the board, you can see two test points. Short across the two test points.
  7. If there appears a picture of cycling colors and patterns, the Y-SUS, Y-Drive, Z-SUS, Power Supply, X-Boards, TCPs and Panel are all OK. The Main Board or the LVDS cable is defective.
  8. Check LVDS cable continuity.
  9. Replace Main Board if LVDS cable is good.
  10. If no picture of cycling colors appeared on step 6, some adjustment is off or some portion of the signal is missing.
  11. Check fuses or continuity of voltage supply lines going to the X Board/s, Y SUS and Y drive Boards and Z SUS Board.
  12. Replace blown fuses, connect broken lines, and resolder loose solders.
  13. If no apparent damage is found, ask for a qualified or experienced technician's service. Massive and sophisticated tests and voltage readings are required and proper tools are needed such as oscilloscope to find which signal is missing. The parts to be tested are prone to handling damage and requires proper handling and testing.
Nov 24, 2009 | LG 50PC3D 50 in. Plasma Television
I have a plasma tv 42 in and I have a black screen. What is wrong?
There are a lot of possibilities. If you could give a lot more detail that would be great. Also how long have you owned the tv? Does the tv turn on at all? is there audio? Does the onscreen menu come on? Once I have more information I can assist you further.
Thanks,
Lee
Nov 05, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Turn on lg 42''plasma tv.get sound but no picture
  1. Panel
  2. Y Drive Board
  3. Y SUS Board
  4. X Drive Boards
  5. Tape Carrier Package (TCP)
  6. Main Board
  1. Unplug the unit.
  2. Remove the back cover by removing the screws holding it. No need to remove the stand.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Big black bar in the middle of the screen vertical
You will need to replace the Main board and I would also replace the LVDS cable that connects the main board to the LCD panel. Very easy to do, but might take about 2 hours depending on your comfort level.
You will need:
Screw Driver
LVDS cable – Part # 0500-0505-0540
Main board – Part # 3632-0652-0395
Those part numbers will work if you have a model number VOJ320F1A.
If you post the model number I will try to find the part number for you.
thanks
Aug 11, 2009 | Vizio L32 32 in. LCD HDTV
32inch westinghouse LCD TV flickers/slighly shaky picture-LTV32W1
try reseating the LVDS cable inside the set it is the multi wire connector from the main board to the LCD panel (top portion of the panel). if that doesn't look to see if the back lamps are remaining lit during this problem. if they go out the problem may be power supply or inverters (lamp power supply).. some panel makers make these available as a seperate part, some do not and the panel must be replaced. if the back lamps stay lit it is the main board. start with the LVDS cable first.
Apr 24, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
312 people viewed this question
Top Televison & Video Experts
