Question about Hotpoint 24 in. DWF32P Free-standing Dishwasher
Dwf 33 not taking in water??
  • blandi60 Oct 04, 2008
    same problem. machine display lights up but no sound of water going in. timer counts down but no washing going on. we have checked all pipes and no blockages. also tipped machine backwards to empty water in base. still nothing.....
  • Anonymous Nov 17, 2008
    Yep same problem won't fill.
    Will take apart today and see if blockage and check the micro switch otherwise I am wondering if the intake valve is bust???
My dishwasher cuts out after 15 mins
Posted on Dec 27, 2008
  • 3 Answers
Took sides off to have a look.
Then turned on (but didn't touch!!) and was still making noise but no water. Lifted the float switch up and down and the water then started to come into machine. Drained machine and started it up again a few times to check wasn't a fluke and all seems well again!!! I was virtually on the point of giving in and buying new one as its 8 years old but hurray! not going to be that broke this month!! Husband will be pleased.
Posted on Nov 17, 2008
Dwf 415 dishwasher, overfills with water
gee a whirlpool doing that
check the user manual
the control board failure
water level shut off sensor faulty
water pump failure
check for drain out blockages
http://lastmanuals.com/manual/WHIRLPOOL/DWF-415-W
Oct 13, 2016 | Dishwashers
Whirlpool DWF 407 IKEA Dishwasher serious problem.
a worn film capacitor on the circuit board is the cause of the problem which often manifests itself after several years using the dwf 407. Replacing the film capacitor on the circuit board is the solution! Such a capacitor costs about GBP 2. The removal of the circuit board that is in the door is not very difficult, four torque screws along the inside top of the door (not the two for the door lock) a click system in which the print is stuck in the door. On the print are a few connectors with wires to loosen-take picture or mark them for reassembly purposes. There are several types of DWF 407, sometimes the print is slightly different. But the culprit is always the big gray block. The value that you must have is 250/275 V 1,5UF. Many electronics stores have them or can order them. Soldering you can do yourself if you have some experience or ask your local handyman. It is not very difficult, you have plenty of space on the board and only two feet soldering required. After that my dishwasher was as new at the fraction of the price
Oct 28, 2009 | Dishwashers
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Blocked hotpoint dwf 33
There is a drain hose for your dishwasher and it often gets clogged. remove and clean it , reinstall and problem solved. If this doesnt fixya then might have to throw parts at it. Not sure though without cleaning the hose first. Good luck
Jul 13, 2009 | Hotpoint 24 in. DWF33 Built-in Dishwasher
Pumps in and out but does not wash
is the drain to far down the stan pipe or is the pip low down so just flows out hope this helps.
Feb 24, 2009 | Hotpoint 24 in. DWF32P Free-standing...
The dishwasher is not emptying out the water. It needs to reset and finsh the last cycle. Hotpoint DWF 33
pump under bottom front panel might be clogged remove hose clap from pump,cleanout,also can use shop vac.,also remove lower spray arm then remove filter clean and replace,also check under sink make sure drain hose is not kinked,thanks-mike
May 27, 2008 | Dishwashers
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
194 people viewed this question
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
bosch5
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
