Question about Kenwood Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod? - Kenwood Audio Players & Recorders
    Brigadier General:
  • 8,546 Answers
Actually it's the other way around.
For just listening, any audio device with a headphone/earbud output can be connected to any available analog Line Level input (except PHONO) with a simple adapter. They don't tell you that in the iPod manual because they want you to purchase expensive accessories like docking stations. You'll have to manage the music directly from the portable device.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
Posted on Aug 10, 2011
    Genius:
  • 1,156 Answers
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an can the Kenwood KR-4600 connect - coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
SOURCE:
Kenwood KR-V8070 accept digital signals, trying to hook up to cable box?
The Kenwood KR-V8070 has no digital audio inputs; it only has analog inputs. You can see the manual's diagram of the rear input/outputs starting on page 4 at ManualsLib: https://www.manualslib.com/manual/287040/Kenwood-Kr-V8070.html?page=4#manual . If you need to connect a device that doesn't have an analog audio output, you will need an analog to digital audio converter. This is one version: https://www.amazon.com/SANOXY-Analog-Digital-Converter-Adapter/dp/B005F20756 . You will need to supply all of the audio cables separately.
The later KRF-V8070D does have coaxial and optical digital audio inputs. I hope this helps.
Oct 05, 2018 | Kenwood Audio Players & Recorders
Kenwood kr v5560
You can use either Tape 1 or Tape 2 (play) if not in use.
Aug 06, 2013 | Audio Players & Recorders
Where on the Kenwood KR-V5580 do I connect a sub woofer
Wherever the unidentified subwoofer's manual recommends. As there are no volume-controlled pre-amp outputs it would have to be a model that accepts full-range speaker level input if you want to control its volume locally.
Jul 02, 2011 | Kenwood KR-V5580
I have a kenwood kr-4600 stereo amplifier. On the back are two "jumpers" labeled "adapter". There is one for the left and one for the right. Also on both is IN and OUT. There is a...
They're for inserting any permanently-active analog stereo audio processor like an EQ in between the preamp section and the amp section. Unlike a tape Monitor loop, the output is AFTER tone and volume controls. Owners of Bose 901's would use that connection, for example, because the Active EQ is intended only for the speakers.
May 02, 2011 | Kenwood Audio Players & Recorders
My problem is i not can connect the speaker
Refer to the manual(s). Your unnamed speaker(s) may have special requirements (or not). Either way, the manuals are very helpful and a good place to start.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-X1000-Receivers-manual/id/479dj792/t/2/
Mar 24, 2011 | Kenwood KR-X1000
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
Jan 06, 2008 | Kenwood KR-V990D Receiver
Problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Nov 19, 2007 | Kenwood KR-X1000
593 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
