Question about Dopod 818 Pro Smartphone
Me again hi Abhish, thank you for replying. But it could not help me to solve the problem. When I connect my mobile to PC there appears a window saying Found new Hardware Wizard, which includes 2 selection. - Install the software automatically (recommended) - Install from a list. I chose the first but after searching some minutes it says "The hardware wasn't installed because the wizard can not find the necessary software" Now, what should I do?
    Genius:
  • 1,239 Answers
HI.
DO U HAVE THE NOKIA PC SUITE CD..
IF U DON'T HAVE.. TAKE THIS LINK DOWNLOAD THIS ONE. AND INSTALL IT WILL SOLVE THE PROBLEM. www.softpedia.com/get/Mobile-Phone-Tools/Nokia/Nokia-PC-Suite.shtml
THANK SIR,
IF ANY DOUBT , I AM THERE TO ASSIST U.
DON'T FORGET TO VOTE ME..
Posted on Sep 06, 2008
Printer is offline
Hi Lacey,
Disconnect the printer completely and unplug from power.Reboot your PC.Check for any jammed papers in the printer paper paths,these may cause the printer to 'go offline.'
Connect everything again and make sure its well connected to your PC.
Turn the printer off and on again.Problem solved?
If not,uninstall the printer[hoping you have the installation disks],reboot your PC again and install the printer software again.
Hope this helps.Thanks Lacey!
Please rate this answer.
Nov 23, 2011 | Canon Pixma MX410 All-In-One Printer
Hi, I have Nokia N72 mobile. I was using GPRS connetion thr mobile phone. It was working fine few days back. But when I format my mobile, I am not able to connect to Nokia-PC-Suite. Whereas I'm able...
Dear User,
you need to use the option called connect to PC which will define the interface of usage again , that is via USB cable or Bluetooth, I suspect you used Bluetooth hence the pairing has gone after format, you need to repair your PC and cell phone again.
if you use cable then make sure the cable is fitting proper at the pop port and follow the procedure for connecting as i mentioned, also get the latest PC suite (7.1.51.0 is what i have , maybe now there is a newer one still) , its much more easier to connect on it.
May 06, 2011 | Nokia N72 Cellular Phone
Dear Friends My Toshiba Satellite L35 S2194 PC does not respond to the function Fn + F5 to connect to a video projector Hewlett Packard. Pressing the function above options do not appear on the screen...
Hello www_privater. to "Display the Projector."
Do the following:
Right click on an 'empty' area of the "Desktop." paul7of9_150.jpg Next, select to 'open' the "Personalize" shortcut!
In the next 'window,' {In the right} "Task" area.
Click on "Connect to a "Projector" or other external display."
paul7of9_151.jpg "The {Windows Mobility Center} 'program' opens!
paul7of9_152.jpg Now, look for the "Presentattion Settings."
Click on the [Turn-on] button.
"This 'should' have the "Projector" listed / appear!"
"Please let me know if you 'need' further assistance; by posting a "Comment 'or' Rating the Solution." Thanks, your 'response' is important!" paul7of9
Mar 07, 2011 | Computers & Internet
I am unable to connect my samsung s5233 mobile to windows 7?
hi
new version of windows seven will not support the old software.. moreover windows seven will not support the PC suite software of your mobile. kindly install windows xp and try it.. your problem will be solved..
thank you
Dec 20, 2010 | Samsung Star GT-S5233 Cell Phone
Connectivity problem with computer
Hi, downlaod the driver from following link
http://www.bioticaindia.com/motorola-w375.html  and click on Download link
Please rate my reply if problem is solved. Thanks!
Mar 26, 2009 | Motorola Computers & Internet
About service reply
Hi there
Thanks for posting your problem on fixya
According to your information after dialing *123# reply massage doesn't appear please first check your sim card *123# this number gives only a airtels balance inquiry if you have any other connection then call customer care and try another number if you have airtel then call 123 number this number provide you your balance details.
If your phone on warranty then rush to nokia service center and check up your mobile.
Is this solution helps you little bit then please vote for me
thanks
Robert
Sep 11, 2008 | Nokia 3250 Cellular Phone
Sigmatel s4
hi there!
you first have to install the driver software for your cell phone...
as in windows Xp it shows MT6225...
after installing the usb drivers when you connect your cell with usb cable on the cell phone a menu will appear...
- Mass Storage
- Com Port
- Camera
you have to select the mass storage option then your cell will show it self as a usb disk in PC... and if you have Memory card then there will be two usb drives appear in your My Computer Window....
you just have to copy paste your files...
Aug 29, 2008 | Handmark Software MobileLists (950142) for...
Baixing TV200 Mobile USB not connected to PC
I Have the same from, my phone baixing tv200 cannot connect to my pc help me with drivers, plz.
Aug 26, 2008 | Siemens M56 Earbud Hands Free Headset
Can not connect using LG Mobile Sync
I HAVE LG CU500 AND I WANT TO CONECT WITH MY PC. I HAVE USB CABLE BUT, MENUAL SAYS U NEED TO BUY SD MICRO CHEEP I DONT WANT TO BUY WITHOUT THAT HOW CAN I CONECT WITH MY PC HELP ME
May 27, 2008 | LG CU500 Cellular Phone
Mobile software
The software and the drivers found in the Internet work fine. However, everything works except java installation (failed to install java error). I fixed it changing the set up of the Tx and Rx cables inside the data cable. It´s quite easy. Hope this can solve your problems.
Jan 05, 2008 | Handmark Software MobileLists (950142) for...
Dopod 818 Pro Smartphone Logo
65 people viewed this question
Top Dopod Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Dopod Computer and Internet Expert? Answer questions, earn points and help others
