When
the machine is in one of the following situations, the fax is automatically
stored in memory.
- If ink is low or
has run out while receiving a fax
- If the paper
size/type setting is incorrect
- If the paper has run
- If the Output Tray
is closed
- If OFF is selected for AUTO PRINT RX
- If you pressed the
Stop/Reset button to cancel printing of a fax
The most likely problem is that the ink is low.
You can change the settings to still print if the ink is low by pushing the fax button and then the menu button.
Scroll over until you get to RX settings (I think it is the 6th option) and push OK.
Choose the option to Auto Print RX, and press OK.
Make sure that On is selected and even if it already is the chosen option, press OK.
When the option appears to print with no ink, select yes. This will allow the fax to print even when the ink is low.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Canon PIXMA MX310 All-In-One
Will not feed. I followed user manual instructions (maintenance/clean roller) but still did not...
(More)
Will not feed. I followed user manual instructions (maintenance/clean roller) but still did not feed. Tried cleaning roller with cotton swab and rubbing alcohol. Still did not feed. What is next step??
my canon Pixma MX310 continues jamming when I try to print. It continues to occurr when I try to...
(More)
my canon Pixma MX310 continues jamming when I try to print. It continues to occurr when I try to print with one page. The alarm inidcator is on.
My Canon PIXNA MX310 series office all-in-one printer is giving me a paper jammed error. I cannot...
(More)
My Canon PIXNA MX310 series office all-in-one printer is giving me a paper jammed error. I cannot see any jammed paper. I've unplugged, replugged it in several times. Still get same error message. The Alarm button stays on. It always says, Paper Jammed. Clear paper jam and press OK. What do I do
replaced ink cartridge now 1 printer offline which it isnt 2 keeps saying check ink - new and in the...
(More)
replaced ink cartridge now 1 printer offline which it isnt 2 keeps saying check ink - new and in the right place can you help?
