Canon PIXMA MX310 All-In-One Printer
Problem for Canon PIXMA MX310 All-In-One Printer
Canon MX310 Printer - Faxes being stored isntead of printing.
By shades8664 on Sep 04, 2008
I have recently acquired the above printer and have set up faxing OK. The only problem I have is the faxes do not automatically print when I receive them I have to manually request them to print. Is there any way to resolve this.
Have checked the settings and this does not seem to help in any way.
Solution #1
posted on Nov 03, 2009
Not Rated)
ElKaHaJoCo
Rank: Guide
Rating: 100%, 3 votes
When the machine is in one of the following situations, the fax is automatically stored in memory.
- If ink is low or has run out while receiving a fax
- If the paper size/type setting is incorrect
- If the paper has run out while receiving a fax
- If the Output Tray is closed
- If OFF is selected for AUTO PRINT RX
- If you pressed the Stop/Reset button to cancel printing of a fax
The most likely problem is that the ink is low.
You can change the settings to still print if the ink is low by pushing the fax button and then the menu button.
Scroll over until you get to RX settings (I think it is the 6th option) and push OK.
Choose the option to Auto Print RX, and press OK.
Make sure that On is selected and even if it already is the chosen option, press OK.
When the option appears to print with no ink, select yes. This will allow the fax to print even when the ink is low.
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MX310 All-In-One
Questions and Unsolved Problems for Canon PIXMA MX310 All-In-One
Do you recommend Canon PIXMA MX310 All-In-One Printer?
Answer
Answer
I do not have acanon mx310 manual and wish to install new cartriges. How do i do this?
Answer
Hi I am trying to send a fax, enter the number, press start, it will start transmitting but cut out... (More)
Answer
I had a paper jam, pulled out the paper and now the alarm light doesn't turn off and keeps saying:... (More)
Answer
paper jam not jammed the in use /memory is always o
Answer
i am trying to send a fax and somehow is not going through.. the error tx report show as of result ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
