Question about Mitsubishi WD-62525 62" Rear Projection HDTV
NO PICTURE, NO SOUND, CODE 37??????????
Whats wrong when it throws a code 37?????????
  • 2 more comments
  • mvick Sep 04, 2008
    what is DMD????
  • mvick Sep 06, 2008
    so would that mean that the dmd is bad or one of the fans, because with lookin at the back, inside on the top left theres a fan on the top of a silver box that fan works when first trying to turn set on but not the lamp fan or the exhaust fan. should all the fans work when turning on the set?
    would you suggest changing the lamp fan, if so where can i get one???
  • mvick Sep 08, 2008
    i have put power to the exhaust fan and the lamp fan, both work. what supplies power to the fans, where is it located, and are the fans ran off seperate power sources? because the one fan on the top left works when turning the set on.
  • Mitsubishi Master
  • 8,617 Answers
DMD or Lamp fan failure
Posted on Sep 04, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Sep 04, 2008
    Its the Digital module which powers the ballast that has a fan as well as the lamp has a fan also. the 37 code means one of those fans arent working
  • Sonny Berry
    Sonny Berry Sep 06, 2008
    37 is a code for the fan. The lamp fan has to start before the set will start. Its most likely related to a power supply for the fan .
  • Sonny Berry
    I would check it for voltages first, cause if the voltage is there and then the fan would be defective, but if theres no voltage present then you would know its the power supply for the fan
Truck idles but once foot is off the throttle it is shutting off. What might be causing this?
If it runs with the throttle slightly open, Clean the throttle body and IAC motor. Also check or replace the air filter. Break clean and a tooth brush works for the throttle. Takes a second or two to start. Then rev it and spray some break clean in the throttle. Not sure for the wrong engine oil code? What was it?
Oct 24, 2015 | 2006 Dodge Ram 1500
Temp display on door is giving wrong display
this is a fault code.. take a picture of the panel and post it here also picture of the model and serial tag.....I can find the fault codes with the info asked for............ ken
Sep 30, 2014 | Refrigerators
Crank shaft piston sensor
Your going to throw parts at the unknown
for no reason or because you have a code ?
Codes don't tell you what is wrong or to replace anything
Have to component test, to find problems or failed parts
Google a picture, if you want to roll the dice & replace a
good part
Sep 07, 2014 | 2006 Pontiac Torrent
Has picture but no sound
most change the sound region code:try-B/G-D/K-and----I...in tv settings<SOUND>
Jun 13, 2010 | Protron PLTV-37 37 in. LCD Television
Vcr sound but no picture
After checking the connection, played a pre-recorded tape and the picture was displayed gradually. After about 5 mins picture was completly restored. Lost of picture was due to dirty tape heads.
Mar 22, 2009 | Panasonic TH37PX60 37 in. Plasma...
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Oct 12, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
No sound on protron lcd tv
Go to the set up menu and select audio. check that the speakers are ON.. Then make sure that stereo is selected. If the set is set to alt sound there wont be any sound.
Jun 13, 2008 | Protron PLTV-37 37 in. LCD Television
No picture or sound
means run ... or you lost power supply inside the set.
Jan 13, 2008 | Philips 32PT6441/37 32" TV
No sound, no picture and a red light blinks on front panel
If I remember right the set is blinking a code, dont remember which code, but what happened something on the power board failed and knocked out the 5vdc regulation? The power board will most likely need replacement, this should be done by a qualified technincian or someone who knows how to dissassemble/ repair set.
Jul 07, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
