Question about Haier XQG50-11 Front Load Washer / Dryer
Trouble shooting Err7 flashes up when i put spin cycle on
  • 43 Answers
If it doesent spin at all could have a problem with motor carbons if you access the motor you will see two long stick like objects attached to the metal casng on the motor remove and chack the contacts have at least 10 mm of corbon
Posted on Nov 11, 2008
Hi. How can I just to a spin only cycle on my new BWE91683 washer please? Previous Indesit spin only was on dial. Thanks
go to the manufactures website for a user manual download, this machine does not have a onward cycle button so only the manual will help in the trouble shooting guide eric
Dec 20, 2017 | Indesit Washing Machines
Good morning. Have a Whirpool Duet washer GHW9150PWO, 3yrs old, just started flashing "F" code with audible beeps at the spin cycle on the finish side. Checked owners manual under trouble...
well..sounds like perhaps the control board is having a fit..unplug it first, let it discharge(usually around 4 min) and then have a go at it again. Does this occur on all cycles?
Jun 01, 2008 | Whirlpool Washing Machines
Whirlpool trouble shooting
All Spin cycles regardless of load or even when unloaded and spinning?
If so suspension is broken.........Technician repair only, even the balance weights in the tub are too heavy for DIY to remove and replace springs
Sep 07, 2014 | Whirlpool WFW9550WW Duet 27" 4.4 cu. ft....
Not spinning on spin cycle
No spin is electrical!
Nov 28, 2012 | Washing Machines
Spin light is flashing 1min left in cycle door
Take the bottom panel off. The tech sheet is right there. While at it clean out the pump filter.
Interesting home videos
Apr 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The clothes are very wet at the end of the cycle. I have to run a "spin only" cycle to get them dry enough to put in the dryer.
is your "anti-siphoning" valve or pump plugged with lint, etc. debris from previous laundering, also if it dries them sufficiently the 2nd time this is where I would start trouble-shooting the washer
Oct 29, 2009 | Frigidaire ATF6000ES Front Load Washer
My clothes are still soaking wet after the final spin cycle. Someone told me that it might be the pump, but I just replaced the pump and I am having the same problem. I don't think spin cycle is spinning...
there could be a problem with your belt being to loose. how ever i think the main problemis the motor is not turning or gearing up into the high side of the spin cycle.other problem may be the transmssion but i would check the motor first
Sep 24, 2009 | Frigidaire FEX831CS Top Load Stacked...
GE Profile top load washer purchased 2003 water comes out from under washer when spin and drain cycle on. this not mentioned in trouble shooting area. think it is water pump or whatelse can it be?
It has to be in the water exit path somewhere - is there a pump sump inspection? Is there a hose split? Likely the drain hose, or where it connects to the machine. Has the pump split open? Can you remove the machine cover and inspect it while it is doing a cycle so you can see where the water is coming from?
Apr 26, 2009 | Washing Machines
HAIER HW-C1460TVEME-U
Err1 : Door not properly shut
Err2 : Drainage error (clean filter check hose
Err3 : temperature sensor short circuit
Err4 : Heater error
Err5 : water fails to meet specified level within 8 mins check tap, water pressure
Err6 : motor error
Err7 : motor error
Err8 : water exceeds protective level check circuit
End : end of wash cycle
Unb : after the last rinsing cycle finishes spinning fails completelt due to unbalance of the laundry
only reason I know is i looked through the manual after getting it myself could be something to do with running a bath while washer on or something perhaps not enough water getting in if powder channel blocked
Sep 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Open Questions:
See all Haier XQG50-11 Front Load Washer / Dryer Questions
Haier XQG50-11 Front Load Washer / Dryer Logo
119 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
