Question about Gaggia Baby Espresso Machine
Leaking water My machine is a Gaggia Baby Dose and this machine drips water from the frother
    Genius:
  • 1,036 Answers
It sounds like the main valve is faulty. Replacements are available or you may be able to dissasemble it and replace the seal.
Hope this helps.
Posted on Sep 04, 2008
Have a baby gaggia coffee machine and unable to find anywhere that will service or repair. The machine has worked really well for 3 years but now is making aloud noise when working and the flow is very...
The loud noise is coming from the vibrating water pump.
One posibility is that is full of scale or and dirt so you can try descale the machine.
Second is probably the water tank can fit corectly on the base and the valve on it does not open correctly or not at all so the pump it can not s**k water but air or a mix of them so we have the loud noise.
Finally you can remove the shower disk on the group head , locate above where you place the filter holder and clean it probably is full of dry coffee and block the water way out.
Please note that can be all above problem together.
Good luck
Mar 27, 2010 | Gaggia Baby Espresso Machine
We have just bought a secondhand baby Gaggia and we cant get the steam to come out the frother. It is an orange coloured machine .
Propably the steam pipe is blocked from dry milk. You can use a thin steel wire insert it in the pipe from bottom. If you manage to open it a little bit and start having steam then by boiling water and leave the steam pipe imerse in it it will melt the remaining dirt and by open the stem valve then the dirt will spoot out. If not then the valve is blocked or broken.
Jan 02, 2010 | Gaggia Baby Espresso Machine
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
Baby Gaggia Dose leaks
On the gaggia clascic there are 2 hoses in the back above the drain tray, are those in the water reservoir? If yes then there is a broken hose on the in side of the machine.
Aug 12, 2009 | Gaggia Baby Espresso Machine
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
No water coming through - New Gaggia Baby Dose
Try this remove the portafilter, then press the button for brewing coffee and then turn on the machine, if both hoses are in the water reservoir, then water should flow out of the head after a few seconds.
Jul 20, 2009 | Gaggia Baby Espresso Machine
Gaggia Baby - water leaking from round the edge of main bulkhead
you need to replace the main rubber gasket within the bulkhead. due to heat and use, the gasket cracks and no longer is able to seal the brew head. a new gasket should be part of the warranty but you can purchase one and replace your self, pretty simple.
Mar 05, 2009 | Gaggia Baby Espresso Machine
Gaggia baby dose solenoid valve
You may get this part from EBay for around $45/£38 a small "How to" below ">
Dec 04, 2008 | Gaggia Baby Espresso Machine
Gaggia Baby Espresso Machine Logo
336 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
