Question about Palm LifeDrive Mobile Manager Handheld
Hard reset I have tried to do a "hard reset", but always appears directly the screen of the safe or fast delete, nothing about the Palm Powered logo or similar. The sequence that I use is press and maintain the power_on button (with the LD swithed off) and press reset.
    Master:
  • 542 Answers
1 Hold down the power (on/off) button on your device. 2 While holding down the power button, turn over your device so that you can see the back of it. Still holding the power button, use an unfolded paper clip or a similar small object, to gently press the RESET hole on the back. 3 When the Palm Computing Platform or Palm Powered logo appears, release the power button. 4 A message will appear warning that you are about to erase all the data stored on your handheld.
Posted on Sep 15, 2005
Need instructions on a hard reset
On your handheld, launch the Prefs application. Under General, select Security.
If the Password box says "Unassigned," tap the box and create a password for your handheld.
Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
On your handheld, hold down the Power button.
While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
  1. While still holding the Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
  2. A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
  3. You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete
Mar 03, 2011 | Palm TX Handheld
Tip
Factory Reset for Tungsten T5 handhelds
If you've set a password on your device, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
1.On your handheld, launch the Prefs application. From the list that appears, under General, select Security.
2.If the Password box says "Unassigned," tap the box and create a password for your handheld.
3.Once the password has been set, hold down the Power (on/off) button on your device.
4.While holding down the Power button, turn over your device so that you can see the back of it. Still holding the Power button, use an unfolded paper clip or a similar small object to gently press the RESET hole (where?). Keep holding the Power button throughout.
5.While still holding the Power button, the screen will show the Palm logo and a progress bar will appear at the bottom. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
6.A message will appear warning that you are about to erase all the data stored on your handheld. Press UP.
7.You may see a screen that says "Reformatting in progress. This may take several minutes." This screen will remain for several minutes (up to 10 minutes). Don't do anything while this is happening.
8.If you performed this reset correctly, the screen of your device will go blank after several minutes, and you will not be able to turn on your handheld. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again)
9.Your device will appear "dead." To wake up your handheld, perform a soft reset.
on Mar 11, 2010 | Cell Phones
How do I reset my palm z22 to factory settings?
If you've set a password on your handheld, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
  1. On your handheld, launch the Prefs application. Under General, select Security.
  2. If the Password box says "Unassigned," tap the box and create a password for your handheld.
  3. Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
  4. On your handheld, hold down the Power button.
  5. While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
  6. While still holding Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
    887_palmlogo_progressbar.gif spacer.gif 887_poweredcircle.gif Keep holding the Power button during this screen. spacer.gif When you see this screen, you can release the Power button.
  7. A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
  8. You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete.
Apr 15, 2010 | Palm Z22 Handheld
Is there a way I can revert my Palm Treo 650 back to original factory settings
Factory Reset for Treo 700p and 680 smartphones
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again) 9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
if u like plz comment
Mar 11, 2010 | Palm Treo 650 Handheld
I put a password on my palm and don't remember it. i want to unlock it.i tried resetting it but it don't work.
You may need to do a hard reset.
To perform a hard reset:
1. Press and hold the power button on the front panel of the handheld.
2. While holding the power button, use the tip of an unfolded paper clip (or similar object without a sharp tip) to gently press and release the reset button.
3. Wait for the Palm Powered™ logo to appear; then release the power button.
4. When a message appears on the handheld screen, warning that you are about to erase all the data stored on your handheld, press any other button to perform a soft reset.
Mar 01, 2010 | Palm Zire 21 Handheld
Palm z22. wont startup without holding the up arrow key and doing a soft reset. Then Task icon wont load and some of the other applications wont load
Try doing a hard reset. Warning: A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything.
Here are the directions:
  1. Press and hold the Power (on/off) button on the front panel of your device.
  2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  3. If you see a progress bar (see below), keep holding the Power button.
  4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Note: A hard reset does not delete the current date and time. It does restore other settings to the factory default.
The progress bar On some devices, you may see a Palm or palmOne logo and a progress bar first. Do not release the Power button until the second, circular Palm Powered logo appears. From there follow the on screen directions and then do a HotSync. Best wishes
Oct 25, 2009 | Palm Z22 Handheld
I can't get the Palm z22 to come back on after it ran out of power and I recharged it. This is the second time it has done this and I can't remember what i did before to get it started again. just...
If your data from your handset has been syncronized recently, try a hard reset. NOTE: Just be aware that your handset data may be deleted:
  1. Press and hold the power button.
  2. While holding the power button, use the tip of the stylus (or a similar object
    without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
  3. Wait for the Palm Powered™ logo to appear, and then release the power button.
  4. When you see the message that warns you about erasing all of the info on your handheld, do one of the following:
    • Press Up on the 5-way navigator to finish the reset and show the touchscreen.
    • Press any other button to do a soft reset.
  5. When prompted, tap to align the screen, and then select the language you want to use on your handheld. A screen appears showing the Palm logo and a progress bar.
Hope this helps.
Aug 09, 2009 | Palm Z22 Handheld
Palm centro wont boot
Do a reset. You will lose all items on you device.
Take battery out. Put it in and hold the power button on till you see the palm logo the second time. Release when you see the 2nd logo. It will prompt you for pressing up to delete and reset. Press Up. It will take some time to reset and reformat but please wait.
After that your phone should come to the setup screen. I would hotsync after you setup to get your contacts  back.
Apr 25, 2009 | Palm Treo 500 Centro
How to do a hard reset on a palm z22?
Hi here are the steps but ensure to backup data before you make a hard reset
While holding the power button, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
Wait for the Palm Powered™logo to appear, and then release the power button.
When you see the message that warns you about erasing all of the info on your handheld, do one of the following:• Press Up on the 5-way navigator to finish the reset and show the touchscreen.• Press any other button to do a soft reset.
When the Welcome screenappears, the hard reset iscomplete
Hope this helps and do let me know
Mar 07, 2009 | Palm Z22 Handheld
Hard reset
Sep 15, 2005 | Palm LifeDrive Handheld
Palm LifeDrive Mobile Manager Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
