Pc HP T620a recovery problems
Recently I replaced a new hard drive in my HP T620a. Now it want load system recovery cd . As I put the recovery cd it says its not for this model PC. Hard drive works fine as. I have portable USB in closed case And check with my friends PC . I have it on master the drive and I also tried the slave but the same thing comes up on the screen,can you help me thanks
  • cunha Sep 04, 2008
    its 7 cds i had to burn it also gave me choice cd\dvd to burn but
    dont have dvd burner.
    my friend lent me his hard drive to try it out and it works but its old drive only 4GB
  • 477 Answers
Hello.
seems like its wrong recovery cd or its corrupted. contact hp for new Recovery cds and tell them about your problem. Im sure they will help you.
you should have 2 disks one recovery pro disk and one os disk. start with the recovery pro disk.
Good luck.
Posted on Sep 04, 2008
  • Filip Eastman Sep 04, 2008
    if you get it installed on one harddrive you can try to ghost the disk to the new disk with a ghost program norton ghost or a ghost freeware program. do you have xp ?
F11...system recovery in hp laptop
System recovery is for serious disk/operating system corruption problems. There is a system recovery partition on HP laptops that contains routines to restore your laptop to the configuration it came from the factory with. Backup all your personal files to a CD or USB stick or portable hard drive before using system recovery as it will erase anything you have added to your primary hard drive since it left the factory. That can especially be a problem if you have upgraded to a newer version of Windows than what your laptop came with, as HP is somewhat 'known' for not upgrading the recovery partition if you don't have recovery CD's for the new operating system bought from HP. If your recovery partition has been erased or corrupted, you will have to either use HP recovery CD's (which may be available from HP if your laptop is new enough)
or do a format and complete installation from the proper Windows installation CD. Either way, your personal files are toast if you don't back them up first. In some cases of operating system failure, you can get an external USB drive box, put your old HDD in it and use another computer to try and read files from the disk to try and save your personal files.
Jul 23, 2014 | Computers & Internet
Replaced motherboard &hard drive in hp pavilion, now it will not recognize reovery cd
By replacing the Hard drive you have removed the recovery partition with the operating system on it.
Did you make a backup of the Operating system to a set of CD's or just the Data?
If it was just the data you need a new operating system through HP Tech Support. The instructions are here
EmptyPortlet
Feb 13, 2013 | HP Pavilion Slimline S3020N PC Desktop
Replacing major hardware in a computer makes it a whole new computer. The motherboard is the operative part here that is causing your problem. When you replace a motherboard it becomes a new machine entirely. It won't recognize the recovery CD because it doesn't recognize your computer as the same machine it was loaded on. You will have to buy a new copy of windows to put on your computer.
Problem with HP pavillion ze4900 harddrive. bios says no IDE device when trying to find hard drive.
You can try to boot from CD/DVD drive with XP cd to see if the install program can find the hard drive. Try to use default setting in the BIOS.
Sounds to me like your hard drive crashed. I had one that did this and same thing. You can either replace the hard drive, use an external hard drive/flash drive (load the os and download laptop drivers) or use a cd based OS like Knoppix.
If you need help with the XP CD let me know.
I hope this helps!!!
Jan 22, 2013 | Computers & Internet
I have a NC6000 whose hard drive stopped working and I replaced the hard drive and I could not get the software to load. I replaced the motherboard and now it will load but it still is not loading al
hi,
please check whether the hard drive is loaded properly into the computer.Turn on the compupter try to go to the bios of the computer and there do the harddrive long test.if the test is failed then the harddrive has gone bad.if the test is passed then try to install the operating system with a recovery cd's.if you don't have the recovery cd's then you need to call HP to get the recovery cd's.
Nov 15, 2011 | HP Compaq nc6000 Notebook
Cant restore to factory condition
HI......................
It should have come with a system restore disk. Back up what you want to save and load the disk and then reboot.
You can go to compaq.com and order the system restore disk if you can't find the one that came with the computer.
Compaq Presario V2000 .? that is hp set up see if they have the system recovery set up on that
HP computers no1 they have the verry best recover system of all
click on start /all programs
in the list go to pc help & tool
then click on
hp-pc- recovery tools-cd
noW click on
creat the recovery tools cd
use a cd(r) disk ...to creater the pc tools cd
then click next
and wait for it to creat a
system tool recovery cd
do not stop it at all
when the system tools
cd is created your have
a system recovery tools
cd- this cd will reinstall
all the software that came with the pc and
now coz we have reset the software it will
restall the software that is on the pc and
reinstall windows xp home and set it back up
windows xp will be reinstalled and set back up
the
hp-pc-tools cd
this just reinstall's the software that was on the
the hard drive at the time you buy the pc it will also
install windows xp. os .with out asking for the windows xp cd
creat multiple partitioins
hp-pc-dvd revovery creater cd
then click on
hp-pc- recovery creater cd
use a dvd (r)disk .do not stop this till the .hp-recovery .creater cd's have been made.then your have your .hp-recover creater cd's
what.hp-creater cd's do
use a dvd(r) disk
to create the revovery creater cd
you will have 2 options
options 1: to just install the windows xp & the software that was on
the hard drive from day 1 without for mating the hard drive
options2: will format the hard drive
and reinstall windows xp with out asking for the windows xp cd
& install the software that was on the pc from day1
hp-cd's & windows & product key cd
your windows product key
can be fond on the side of the pc or on the top
or at the back of the pc
now its best to write that windows product key
and keep it in a safe place
and put that windows product key in to a notepad
and copy the notepad
to a back up cd put the
product key cd. in a safe place with windows xp & the hp-pc-recovery cds
all in a safe place
now you can make back up copy's of the recovery cd's you have made
with the hp.cd creater cd's you use sonci my dvd to make copy's of them cd's
with hp-pc-recovery cd you can use windows burner or sonic my dvd
to make a back up copy of that cd
then make them as the cds for what they are but make as back copy cd's
then your not get any of them mixed up then put them all in a safe place/with
windows xp cd so no one can damage them
Use your RECOVERY CD. Make sure to back-up all your important files before doing the recovery. i found
http://www.techexcess.net/hp-operating-system-cd-340180-002-recovery-software.aspx
selling this cd.
GOOD LUCK...............
Sep 23, 2011 | HP Compaq Presario V2000 Notebook
Recovery disc problems
the cd recovery you have need connect to hard disk by some files system when u change new hard miss these files so cannot do it. only u recover by use ghost from image
Jan 19, 2010 | HP Pavilion DV6700T Notebook PC
How to restore hp pavilion to factory settings?
Hello
Thank you for using
FixYa for your problem
Restore the PC to original condition with the HP Recovery Manager If the computer cannot open to the Windows desktop, follow the steps below to use the f11 key to launch the HP Recovery Manager and return your notebook to its original factory condition.
  1. When the notebook is powered on, press the wireless button to turn ON the wireless switch.
  2. Turn the power off and on to restart the computer.
  3. Press the f11 key to launch the HP Recovery Manager. NOTE: If the HP Recovery Manager cannot access the hard drive to fix the system errors, use the personal recovery discs to recover the hard drive to its original condition.
  4. When the Welcome to HP Recovery Manager windows displays, click Next .
  5. When prompted to perform a Microsoft System Restore , select No , and then click Next .
  6. When prompted to perform a System Recovery , select Yes , and then click Next .
  7. When prompted to Backup Files , select the desired option.
  8. When prompted to perform a Recover your computer to original factory condition , select Next and allow the system recovery process to complete.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | Dell INSPIRON 6000 CENTRINO...
HP DV8000t Hard Drive Failed
Just replace the old one and put in your restore disc and it should ask if you want to boot from the cd and that will take care of it
Dec 30, 2008 | Micro Electronics WinBook Si Notebook
I can't do a full system recovery
It's very possible that your hard drive has failed, and the recovery is stopping because it's unable to read/write to/from the drive. Try a new hard drive.
Jul 21, 2008 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
David Payne
David Payne
