Question about Plumbing
Mixer tap on the kitchen sink
My mixer tap on the kitchen sink is lifting up away from the basin, is there any way I can tighten it. I have looked underneath and there is no screws.
    An expert whose answer gotĀ voted for 100 times.
  • 171 Answers
Hi gt_elijah.
I'm Harvey the Master Plumber.
You want to know if there any way to tighten a faucet on a kitchen sink?
Yes! All faucets have to be secure, but there are as many diferent methods as there are diferent manufacturers. If you are unfamiliar with the diferent methods then you might not recognize the screw, nut, bolt or fitting when you look at it. Also, for many, a special tool is required. It might be wise to have someone local look at it.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
Single lever moen kitchen tap base of unite moves when swinging tap from side to side. Looking under sink I see a nut attached to a threaded spindle, how do i tighten it up, there is very little space for...
A "basin wrench" is the special tool you need. They are pretty cheap. Any hardware or home improvement store carries them. They might even have them at Walmart. Google images for basin wrench and you will see lots of illustrations, including how to use it. Good luck Please vote if you found this helpful Al K
Apr 01, 2011 | Garden
Hi While I try to rotate the tap , the whole base is rotating with it ( delta 470 ss)
A "basin" wrench will be needed to get up under the sink/faucet base to tighten the nuts that hold the faucet in place. It's a simple job but requires the agility of a contortionist to get at.
Apr 26, 2010 | Delta Model 470: Signature Kitchen...
I am guessing you have the square one then. You need to fit your waste as normal, Send the waste through a hole in the surface you are placing the sink on and make your connections underneath. I use plumbers mait as a sealant when tightening the outlet. You then need to think about your taps. Since they are totally separate from the sink you can use what you want. Most people would use a monobloc riser though, secured to whatever surface you are laying the sink on.
You don't say how much you need to know about connections / plumbing etc. Please ask again if you are stuck with these.
Oct 20, 2009 | Home
I have mixer taps fitted to my kitchen sink which leak from under the mounting seal when the taps are turned on.when the taps are turned off the leak gradualy stops and the actual tap never leaks,do the...
It appears that the seal at the base of the tap is worn or the screw collar is loose - try hand-tightening it. It may cure your problem. Plumbers tape is a white tape that helps seal water pipe joints!
Oct 08, 2009 | Plumbing
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Oct 05, 2009 | Food Mixers
Kitchen sink leak
Where is it leaking from? is it a single spout/mixer tap?
Please verify, and i should be able to help you
Steve :o)
Jul 17, 2009 | American Standard Home
Kitchen sink drain is leaking
Yes all can be replaced. They sell complete replacments at Orchards, Home Depot or Lowes. Just make sure you are getting the right parts.
Apr 18, 2009 | Eljer 212-1088-00 White Dumount Double...
How to remove a cast iron kitchen sink installed
Turn the water supplies off unscrew the hoses,get a flashlight and look under the sink you should see clamps around the top holding it in, unscrew these and pull the sink out.
Feb 22, 2009 | Eljer 212-1088-00 White Dumount Double...
Plumbing Logo
804 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
