Hisense color TV ±74cm, Model TC2919H
Looking for circut diagram for this model as the cirut burnt the board and i cannot read the fuse/diode details.
Please assist.
  • Hannes Smith
    Hannes Smith Sep 04, 2012
    NEED THE IC NO N501 IN POWER SUPPLY
  • Hannes Smith
    NEED IC NO N501
I HAVE A PROBLEM IN THE PRIMARY POWER SUPPLY STAGE HAVE CHECKED ALL COMPONENTS AND RELACED STRG96...IC AND OPTO COUPLER .
CAN U LET ME HAVE A CIRCUIT DIAGRAM?
Posted on Apr 09, 2009
How do I enter the service menu in a Hisense TC2919H CRT TV . Thank you. Brian
If you wish to get more details visit the sites linked here. Service mode entry procedure of many popular brand sets are given. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/
Mar 05, 2017 | Hisense Televison & Video
Hisense 55" Model # 55H6B electrical crash
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here. http://homenol. blogspot.com/ http://electronicshelponline.blogspot.com/
Jan 30, 2017 | Hisense Televison & Video
I have a hisense 74 cm colour tv model TC2919H, I would like to know the STR number for the IC
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 14, 2016 | Hisense Televison & Video
What is the Bsc No. Of alopty for a 74cm Phillips tv?(model no.29pt5026/79)
http://electro-medical.blogspot.com/
Circuit diagrams of many popular brand TVs and other devices are given.
Apr 25, 2016 | Televison & Video
Keeps blowing out fuses.
Hi Jeffrey,
There is some short circuit in the power supply board which is causing this. Do not just go trying new fuses, it may increase the damage. Please consult the TV Tech to take care.
Good luck.
Dec 03, 2015 | Magnavox 32MF301B/F7 32 in. LCD TV
Mother board diagram ge cb radio
If the radio is blowing fuses then you are correct in that the protection diode may be burnt. the diode should be black and it should be located near the DC power connector. You should be able to replace it with a 1N4007 Diode.
Mar 16, 2014 | General Electric Radio Communications
I have a 1999 RCA TV model # P52921. It completely shut down. It has no sound and picture. I checked the fuse with my tester and there is power coming out of the fuse. I hear a slight, faint, pulsating...
Check SMPS power supply. DC voltages. First check the power supply
bridge/ diodes. Then check DC votage should be 70% rating of the
capacitor voltage. If the capacitor is dry it will show low voltage.
But the diodes should be OK. Check the high wattage resistors
connected in the power supply. There will be a resistor in the
ac input also. Beyond this check all +DC voltages.
Aug 23, 2010 | Televison & Video
My tv has double images and color is off, how do i fix this?
If it is a 46GW947 there is a common problem---pretty easy to fix
This model with the set unplugged and the back removed has above all the main boards another board suspended over 12 inches from the main boards--it is about 10 inches wide and 4 inches deep---a few plugs, and 4 screws and it comes right out--among other things it is the main power for the CONVERGENCE circuit in this model.
Towards the far right side of the board you will see several diodes-------two of them near each other are much larger----Commonly on this model one of the two SHORTS, stopping voltage to the convergence circuit.
You can test the diode in this case like checking a fuse----it should NOT have a reading like a fuse--if you find either of those two diodes reads across--it is bad and most likely your problem.
Each diode will have a LOCATION number under it on the top of the board----if you find one bad--let me know the location number and I will get you a part number---both those diodes are somewhat special.
If this has helped you, rate this solution as I do this here for free.
SD TECH
Nov 08, 2009 | GE 46GW947 46" Rear Projection Television
Hisense TC2919H Picture and Tuning fualt
I think you should be looking at the tuner itself or on the tuner board for a fault. First check for dry solder joints and if this is not the problem the electrolytic caps next to the tuner may be at fault. Good luck.
Oct 04, 2008 | Hisense Televison & Video
Televison & Video Logo
534 people viewed this question
Top Televison & Video Experts
Electro Med Services...
