i have ben trying to sync my mobile phone to my pc and it is really frustrating, it is coming up with this error message:-
Contacts : Synchronise ( MS Outlook )
Initialize connection with MS Outlook (I)
Calendars : Synchronise ( MS Outlook )
Todo : Synchronise ( MS Outlook )
Memo : Synchronise ( MS Outlook )
Synchronisation failed.
Fail to connect to the phone, Please check the COM port and connect in idle screen.
This is a new PC i have got, it worked fine on my old one. I have checked the compatibility mode is set as WXPSP2.
Can somebody please help, i have tried everything!!
Thanks
Comments:
Sep 14, 2008
- Hi Cvandoes.
Just tried your suggestion, and i played around with this before and nothing happened. However this time, the LG PC Suite was using COM PORT4 and the USBCOM PORT in Device Manager was using COM PORT5, i changed this to COM PORT4 and had an error message saying, 'this com port is already in use, are you sure you want to continue' i continued and it looked like it was really going to work, i got quite excited, but then when clicking on syncronise now in pc suite, i got this error message:-
-   I have the same problem but it only seems to have happened within the last few months, prior to this my phone syncronised without any problems, I have e-mailed LG without any success.
It cannot be a result of having VISTA as I have always been able to before unless its due to an update-   harrykerr100
Sep 07, 2008
-   I HAVE THE SAME PROBLEM I HAVE BEEN TRYIN TO DO IT FOR HOURS NOW.-   charlottetom
Sep 06, 2008
-   I have the same problem, The T-mobile shop said that it could be a problem with Vista, i have checked at microsoft and the viewty is not listed as one of the phones they have worked with. I am on the third KU990 in the last 7 days. This seems to be a common problem and as of yet i haven't found a way round it.-   stevengshaw
When you go through the connection wizard on the LG PC Suite take note of the port number that it is using.
Then go to device manager(for win xp go to start/control panel/system, click on the Hardware tab then device manger) on your pc. Expand Ports(COM & LPT) and right click on LGE Mobile USB Serial Port and select properties. Take note of what port is indicated in brackets. Go to the Port Settings tab and select advanced. Change the com port number to what LG PC suite was using. Select OK, OK and try connecting again with the Wizard and see if you can transfer data etc
Let me know if that helped.
what happens when we connect lg ku990 to charger? first it displays 'please wait 'and then indicates...
(More)
WHAT HAPPENS WHEN WE CONNECT LG KU990 TO CHARGER? FIRST IT DISPLAYS 'PLEASE WAIT 'AND THEN INDICATES CHARGING ICON ALSO LG LOGO .IS THIS A FAULT OR WHAT?PLEASE HELP ME
