Question about Sony Handycam DCR-TRV33 Mini DV Digital Camcorder
Video I can't load the videos to my computer. Is there something I am doing wrong, or doesn't it offer this function. I can transfer the still pictures no problem Please help!
    Master:
  • 763 Answers
Did you try to install the driver of your camcorder to your pc? if not then install it and it should be working for transfering videos. Use Ulead movie maker to upload your videos to your pc. after editing the whole videos save it with any types of videos. hope that helps!
cheers
CHARCOIS
Posted on Sep 04, 2008
My sound doesnt play back when i transfer the video from my camera to my computer, what do i do?
try restarting your computer and copy it again. if that doesn't work, its probably the file type of the video, try converting it to another video type.
Aug 11, 2012 | Sakar Digital Concepts 87492 Point and...
Why don't the AppsLib work
Watch this Video: http://www.youtube.com/watch?v=6BrWSC2uiAg
The model he's using is the 7022, but the same procedure works for the 7125. Download the APK files that are linked in the video description and then connect you 7125 to your computer to copy them over. Once you have them copied, use the APK Installer that came pre-installed on your 7125 to load them. Make sure you load them in the order given on the video! I loaded them in the wrong order the first time and had to do a factory reset because the Back button (silver circle) no longer functioned.
Once you do all this you will be able to load the typical Android Marketplace and ditch the AppLib that doesn't seem to work.
Dec 27, 2011 | Tablets & eReaders
My pinnacle one touch video transfer device won't recognize my ipod touch..is there something i can do to make it work ?
I bought this device last week online and it doesn't recognise anything: nor my VCR, video camera, DVD player ... ! Do you already have a solution for this ? Could it be an error in the pinnacle video transfer system ietself? If you have an answer , please email me at simon00028@hotmail.com
Feb 24, 2011 | Pinnacle Video Transfer
How can i display a portable swivel projector from my laptop using a vga connection? Once im connected all i see is a color bar screen on the wall, do i press something to enable the picture?
There are different types of video outputs which your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Weigh the strengths and weaknesses of each types of video input and output. VGA projectors are the most common type, indeed it is likely that any projector in current use will have a VGA input. However, VGA video offers the lowest resolution of the these three types. S-Video offers a higher resolution than VGA, but is prone to screen flicker, especially when you are connecting your laptop to a power supply while presenting, rather than running off the battery. HDMI offers the highest picture quality of the three, and supports audio data transfer as well. However, know that HDMI-equipped laptops and projectors are more expensive than those that utilize the other video transfer formats.
Choose a video data transfer standard best suited to your price range and needs. VGA is always the safest bet, but if you are purchasing a new laptop computer, try to find one within your budget with an HDMI output as well, as it will provide the best quality and allow you to transmit audio without the use of extraneous equipment. S-Video inputs are found on nearly every LCD and Plasma television, meaning that if you are giving your presentation connected to a television rather than a projector, this is a viable option as well.
Make sure you know how to tell your computer to recognize that you wish to use a projector as a secondary video output device. On Windows-based laptop computers, this usually involves pressing the "Function" (or "Fn") key, followed by one of the numbered "F" buttons along the top of your keyboard. In most cases there will be a graphic of what looks like a television screen on the correct "F" key (e.g. "F4"), but if you aren't sure consult the manual that came with your specific model.
Connect your video cable of choice to your projector and your Windows laptop, turn the projector on, and press the correct function key. If you have a solid video card, pressing the same key combination a second time will allow you to view your laptop's screen both on the computer itself and as a projected image simultaneously.
Connecting a Macintosh laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
Try a dry run of your presentation using your own laptop and the same projector you will be using, if possible. It pays to be prepared, and your audience will be able to tell if you are fumbling around for the right function keys on the day you present. Your confidence will help you start your presentation off with a bang, and it will show.
Aug 30, 2010 | Toshiba Satellite A135-S4527 Notebook
How do i transfer my pics frm my laptop on my ipod touch pls advise
Transferring photos from PC to iPod touch is not that difficult. iCloud and iTunes can both be helpful.
Using "Photo Stream" to sync photos automatically with iCloud is pretty convenient. Go to "Settings > iCloud > Photos (Photo Stream on iOS 6)" and then turn on My Photo Stream. Then get your iCloud started on your PC. In the iCloud Control Panel, Check the "Photos" and then enable the "Photo Stream" option. After that, import the photos into the "Photo Stream" folder on your PC, and then you will be able to view the photos on your iPod touch. Using iCloud to transfer photos from PC to iPod touch is easy, but this method needs Wi-Fi connection. Only over Wi-Fi connection can iCloud sync photo on PC with iPod touch.
transfer-pics-frm-laptop-ipod-oxaxc0rwhkhzilrwacqreyis-3-0.png Using iTunes to sync photos with iPod touch is also easy. But you should be very careful of the syncing function of iTunes because it is a double-edge sword. Once wrong click, you may lose data in your iPod.
1. Plug your iPhone into computer via the USB cable. Launch iTunes if it doesn't launch automatically.
2. Find "File" option on the upper left corner. Then click "Add File to Library".
3. Select photos from your PC and then iTunes will sync the photos to iPhone automatically.
http://www.leawo.org/tutorial/how-to-transfer-photos-from-pc-to-iphone.html
Jul 06, 2010 | Apple iPod touch
Shot video as always. But today cannot get camera and computer to link. When I plug in camera with fire wire, I hear the typical tones that mean something has been connected, but the camera does not go...
The Camcorder will not listed in the My Computer window.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Good Luck!!!!!!!!!!!!!!!
Sep 08, 2009 | Video Cameras
Want to transfer videos from a mini DV cassette to computer.
YOU NEED THE SHARP CD-ROM TO LOAD THE VIDEO DRIVERS ON YOUR COMPUTER TO RECOGNIZE THE CAMERA...PART # IS CDSKAA028WJ01
Dec 24, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Up loading video
install the cd driver camed with your camcorder to your pc and it should be recognizable after you install it. hope that helps!
cheers
CHARCOIS
Sep 06, 2008 | Canon Elura 40MC Mini DV Digital Camcorder
How do I transfer video and stills to my computer?
Palmcorder Digital Camcorders offer you three easy ways to transfer images to a compatible PC2. * i.Link Lets you connect your camcorder to a PC for advanced viewing and editing purposes3. This digital technology also lets you connect your camcorder to a similarly equipped camcorder to make duplicate copies of your recordings with practically no loss of picture quality. * CARD LINK SD Memory Cards offer a simple, lightweight way to transfer your images to a PC4. It even lets you create images on your PC to use while you shoot videos with your camcorder. This revolutionary medium is included on all models with the CARD LINK function. * DV Studio This convenient feature allows you to link the camcorder to your computer via the USB port. Then, you can easily transfer still images captured on Mini DV tape to your computer4 for use in e-mail or printed documents. Please Note: 3-Way PC Link features may or may not be compatible with other operating systems.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Logo
60 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
