I have forgotten the password on my eurotrol 2 heating controller and cannot now alter settings. the pre set password 0000 as been changed some time ago, can you help
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Check the manufactures webpage and type in the model # .
Posted on Sep 04, 2008
How do I change the parental code as I have forgotten my PIN no
From PS If you select (Settings) > (System Settings) > [Restore Default Settings], you can reset the password to [0000]. Note that all other settings will also be restored to their default values.
******Note that as stated this will REVERT BACK ALL OTHER SETTINGS TO DEFAULT SETTINGS******
Or you can Try using the default 0000 passcode
Oct 02, 2015 | Video Game Consoles & Games
Forgotten parental control password
Try returning to the initial setup routine and resetting or disabling the pc password
May 31, 2013 | Viore 1111010006 Main Board for LC13VH54...
How do I change the pin number on my PSP? I have forgotten what I used :-)
Forgetting your PlayStation Portable password can be frustrating; it can limit how much you can do with your PSP device and disallow you to make changes to your settings. Here are some tips to changing your PSP password so that you can remember it and enjoy your PSP to its full extent.
1. To change your PSP password, you must first restore the default settings of your PSP.
2. From your welcome screen, choose "Settings." Under settings, choose "Restore Default Settings."
3.When you choose to restore the default settings, your password will be set back to the default password, which is 0000.
4. Return to the "Settings," and choose "Change Password." If you remembered your old password, you could enter it now, but if you've restored the default settings, enter in 0000 when the PSP prompts for your password.
5. You now have access to change your password to anything you'd like. Enter your chosen numbers and save them.
I hope you find it very helpful.
Thank you for choosing fixya.
Aug 11, 2011 | Sony PlayStation Portable (PSP) Console
I just need instructions on how to set the temperature on my mistral fridge freezeer, please
please be aware that the temperature for the freezer compartment cannot be changed, this is pre set at the time of manufacture, only the fridge can be altered. The main reason for problems with zoned temperatures are to do with the compressor over heating. Unfortunately Hotpoint designed the compressor to switch itself off if the ambient (room) temperature exceeds a pre set figure. This in turn will obviously then lead to an increase in the temperatures of your fridge and freezer. I'm afraid the only solution to this problem is to relocate the whole unit to somewhere much cooler, especially during the hotter weather. This should in time sort the problem out. Also double check that the grill at the very bottom on the front, is not blocked up with dust etc.
Jul 01, 2011 | Hotpoint Refrigerators
Samsung m300 forgotten password
call customer care from ur mobile device *2 they can reset it in technical support
Jun 08, 2009 | Samsung SPH-M300 Cellular Phone
My psp security code has been forgotten, how to unlock?
1) Go to 'SYSTEM SETTINGS'
2) Then go down to 'RESTORE DEFAULT SETTINGS'
3) Press 'YES'
4) Everything is back to normal
5) Default password is 0000
Jan 07, 2009 | Sony PlayStation Portable (PSP) Console
Lost password
if u haven't altered your password before it will be set at 0000. .......
Oct 26, 2008 | StarTech.com StarView SV211K 2-port KVM...
How do you reset forgotten parental control password?
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
Nov 29, 2007 | JVC AV-36260 TV
V-chip code forgotten
I found this to work on my Toshiba TV/VHS combo MV19M4 after trying others suggestions that had worked on similar models but nothing worked on mine. Maybe it will work for yours. Follow these steps:
1: Unplug the TV for 1 minute then plug it back in.
2: In the menu select "TV Set Up".
3: Move the blinking block to beside "V-CHIP Set" BUT DO NOT SELECT IT.
4: Hold in the number 1 button on the remote.
5: Hold in the volume down button on the TV.
Your TV will turn off. Give it a few seconds to reset itself and then turn it back on and you will have to completely reprogram your settings. When you go to the V-CHIP settings it will ask for your new code.
- Jenny
Nov 01, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Heating & Cooling Logo
146 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
