Question about Navman GPS
Have a navman f10,do i need to buy a memory card and do you plug charger into where cigarette lighter is
Rang technical support and they explained everything
Posted on Sep 06, 2008
I have a garman Nubia 1490. Works OK but will not charge battery when plug into car charger. Have used charger from unit supplied.
Do other devices work from your cigarette lighter? If so, check to see if the red light is illuminated on the charger. If the light is not on, the fuse in it is either bad or the charger is defective. It is not economically worth while to have the charger fixed if it is bad. If your GPS does not use a traffic receiver that is embedded in the charging cable, then any cigarette lighter charger with the right plug for your GPS will work. Otherwise, buy either an OEM or after market replacement.
Mar 22, 2017 | Garmin Nuvi 1490LMT GPS Receiver
My Navman 80T won't charge in the car using the cable it came with, any ideas?
Your cigarette plug may have a short in I had the same problem with my phone charger and had to replace the cigarette outlet
Jan 21, 2013 | GPS
My Garmin GDB 50 MSN Receiver/Car Charger lost the piece on the tip to connect it to the cigarette lighter. Can I purchase the replacement part?
You can buy a complete charger by going to https://buy.garmin.com/shop/shop.do?pID=8526
Click on "FIND A STORE" and select your country.
A cheaper option would be to go to a car accessory shop and buy a plug for cigarette lighter accessories. Take it apart and use the tip out of it.
May 24, 2011 | Garmin GPS
I need to buy a plug for car . It is not charging tne GPS
You can get accessories including the car charger from http://www.gpsnow.com/Garmin_nuvi_255_Accessories.htm
However it's likely that if the car charger is not working that the fuse is blown. The fuse is in the plug that goes in the cigarette lighter socket. To get at it unscrew the ring at the end of the plug. Be careful not to lose the small metal tip. When you unscrew the ring the plug comes apart and you'll see the fuse. You can get replacement fuses at any shop that sells garmin satnavs or car electrical accessory shops.
Before changing the fuse make sure your cigarette lighter socket is working by testing it with the cigarettel lighter or some other accessory.
Jan 14, 2011 | Garmin nuvi 255W GPS Receiver
I have vectorlite 1.5 Million Candlepower light I want to know the ac charging adapter specification. We kind of lost track of particular adapter in recent moving :(. we appreciate your help....
Most of the Vector spotlights use a class 2 charger with an output of 12VDC 400ma with a positive (+) center connector, which are very common. I have several of these chargers from different manufacturers, and I use them interchangably on whichever spotlight I happen to plug them into.
One complication with my Vectors is they use a coaxial connector plug on the spotlight end that is a size N, which is being phased out and Radio Shack doesn'd even carry any more. If you hae a box of misc chargers, find a 12VDC one with a connector that fits your 1.5MCP light, and that is probably the one that came with your light.
Note that you can also charge your light with the cigarette lighter adapter cord that came with it. So if you can't find an AC transformer that fits but you have your cigarette lighter adapter cord, you can buy one of those cigarette lighter size gadgets that plugs into an AC outlet, and then plug your cigarette lighter cord into that.
Jun 28, 2010 | Vector 1 Million Rechargeable Spotlight
How can I open the luggage compartment of a Porsche 911 when the battery is dead?
The best way to do this is to put battery voltage back into the system through the cigarette lighter. You can buy a battery charger at an auto parts store or walmart that is designed to charge the battery through the cigarette lighter. It will have a plug on it that insert right into the cigarette lighter. Let it charge a little, and try the button again. It will pop right open.
Feb 02, 2010 | 2005 Porsche 911
Battery flat cannot release bonnet to jump start
You have to charge the battery through the cigarette lighter. Go to an auto parts store or walmart and there you can buy a car charger that will plug into the cigarette lighter. Once the battery charges a little, you can pop the bonnet. Once you have access to the battery, you can use a heavy duty battery charger or replace the battery.
Feb 01, 2010 | 2004 Porsche Carrera
Is the cigarette lighter also the plug for cell phone charger?
The cigarette lighter plug should also work for the phone charger as long as the phone charger uses the cigarette lighter style plug(long with two metal contacts on the sides and a button contact on the tip). Most standard car chargers will fit both cigarette and auxillary style plugs.
Dec 29, 2009 | 2004 Ford Focus
Need to buy new battery for a 2001 bmw 325. When changing it do I lose all memory settings, radio codes etc
Yes you will. There's a plug you can buy at an auto parts place you will also need a 9 volt battery, that will save your memory, fit's in the cigarette lighter make sure your lighter plug works.just plug in to lighter will save memory while to switch battery out.
Nov 23, 2009 | 2001 BMW 325
My navman s50 working fine , except when the cigarette charger doesn't charge. I check their is power on the car supply. can u help me.
replace the GPS car charger if the cigar lighter has power, but be sure of that 1st by plugging in another car charger like for a cell phone.
Oct 01, 2009 | GPS
GPS Logo
107 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
