Question about Microsoft Windows XP Home Edition
Universal serial bus controllers
If I uninstall my Universal serial bus controllers, will this affect/damage any other part of my pc;e.g. wipe files, programs etc?
thanks
Josie
    Genius:
  • 2,785 Answers
No, the os will reload the drivers again
Posted on Sep 04, 2008
Usb device not recognized
Could be outdated drivers.?
W 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Sep 12, 2013 | Acer Computers & Internet
Usb device not recognised when m audio profire is connected to hp 625
W 7 First, please disconnect all USB devices and then perform the following steps:
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Hope it helps.
Jan 28, 2013 | HEWLETT-PACKARD 625 Tur II P540 Notebook
Usb port dont work
this may vary depending on your operating system for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply Hope it helps.
Jan 22, 2013 | Dell Inspiron 1750 Laptop
I cannot open pen drive in pc
Jan 21, 2013 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
USB DRIVER
You might have to re-install your "Universal Serial Bus Controllers" here is how you do that:
1.Locate "Device Manager" usually by pressing start then typing "Device Manager" into your search menu if you are using windows 7. If not then it is easily found under Control Panel.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the "Host Controller", click "Uninstall" and click "OK".
3. Repeat step 2 until all item under "Universal Serial Bus Controllers" are uninstalled then restart you computer windows will re-install everything for you.
Mar 25, 2011 | Computers & Internet
Plugged in my new webcam Trust spotlight 16428 and keep getting error code 43
My usb port do not work. It did not recognize any devise.
hello
Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager. If you are not comfortable with advanced troubleshooting, try the steps in the "Workaround" section.
To disable and re-enable the USB controllers, follow these steps: Click Start, and then click Run.
Note If you are running Windows Vista, click Start, and then use the Start Search box. Type devmgmt.msc, and then click OK. Device Manager opens. Expand Universal Serial Bus controllers.
Note You might have to scroll down the list to find this item. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled. Check the USB device to see whether it is working.
hope this helps
Jan 27, 2011 | HP Pavilion dv7-1240us Notebook
Will not work in usb 2.0 but will work in usb 1.0
Connect the Player to the USB 2.0 port on the Comptuer then open the Device Manager and expand the "universal serial bus controllers" category.
Under the serial bus controller category, check if there is any exclamation mark visible. If there is any then right click on it and select Uninstall. Restart the Computer after uninstalling the device with exclamation mark. Restarting the Computer with the player connected will make the Computer recognize the connected player.
Furthermore, check whether there is any universal serial host controllers prefixed with "Enhanced".
If there is no Enhanced universal serial host controller listed under the "serial bus controller" category then it's required to install the USB 2.0 driver.
In this case, uninstall all the devices listed under the universal serial controllers category then restart the Computer to reload them automatically.
Sep 17, 2009 | Audio Players & Recorders
Hey, no need to pay everytime, the usb ports will get reinstalled after the pc is restarted, you wont loose anything at all.
Sep 04, 2008 | Office Equipment & Supplies
Compac n6000 usb port problem
The issue could be due to corrupt USB Driver. I will give you a few steps to re-install the Drivers.
Please perform the following steps to uninstall USB Port.
1. Right-click on My Computer icon and select Properties.
2. Click Hardware tab. Click the Device Manager button and double-click the Universal Serial Bus Controllers.
3. Select a device listed under Universal Serial Bus Controller, right-click and Uninstall.
4. Click Yes to confirm the uninstallation of the device.
NOTE: Repeat step 3 and 4 until all the devices under Universal Serial Bus Controller are removed.
The USB port is now uninstalled. Now, restart the system. The system automatically detects and reinstalls the USB port.
Step 2:-
Try the following update for the USB port.
http://support.microsoft.com/kb/822603
Thanks
Rajesh
Jul 13, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
