Question about HP OmniBook 6000 Notebook
My usb is not working
My usb does not work at all when a usb device is inserted
Samsung r519 usb ic
All USB not working? If not remove USB device re-boot and then re insert USB device. Still does not work check Device Manager look for any errors under the USB list. That said, how old is your Samsung and what are you using in your USB port?
Oct 29, 2012 | Samsung R519-53S Notebook
Kingston Datatraveler Windows 7.
1]Go to control pannel
2]Go to System and Security
3]Go to Device Manager
4]Click Universal Serial Bus Controllers
5]Right click the USB
6]Click Uninstall
then Reboot computer while pendrive is inserted in USB
Then connect to the internet.
When you connect to the internet if the said USB is empty
(i.e. no device is inserted in it) they install the device
eventhough the device is not present, causing the said error.
Aug 15, 2012 | Kingston Computers & Internet
The wd is not being recognised on my laptop. It does not show up
Did the WD Hard drive come with a software driver installation package? What operating system are you using? If Windows, please check Windows "Device Manager" and verify if there are question marks next to the device when inserted into USB port. I would also recommend upgrading the firmware on this model:
http://www.wdc.com/wdproducts/wdsmartwareupdate/Step1.asp?id=wdfMP_Essential&os=win
Have you verified that other USB-compatible devices work in the USB port that you are using? Have you tried inserting this device into another USB port? If you are using multiple USB ports for multiple devices, try removing all USB-compatible devices and then re-insert WD hard drive on its own.
Please email me your results at JDavis@csical.com. Thanks!
Nov 16, 2010 | Western Digital My Passport Essential 320...
One of the USB devices attached to this computer has malfunctioned, etc.
This problem is caused by a USB ports of the motherboard. Try to insert the usb devices in the different usb ports and if all ports you inserted encounter the same problem then probably the ports has technical hardware problem. To solve this, buy an expansion usb card to your computer. Be sure also that the usb devices you inserted in your computer in properly working and has no defect to determine that the ports are the problem and not the devices. Please don't forget to rate me..Thanks..:-)
Oct 26, 2009 | HP LaserJet P2015 Printer
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
My computer not recognized the USB Flash memory, but it recognized other device like the mouse, webcam scanner, digital camera ... Thanks for your help
if usb flash memory is working on other computer/laptop then do the following step.
Insert the usb flash memory.
Goto desktop, right-click my Computer, click Properties, click on Harware tab, click Device Manager button.
There should be yellow exclamation(!) sign showing Unknown Device
Right-click and select UnInstall.
Reboot your laptop
It should work.
May 30, 2009 | Dell Inspiron 6400 Notebook
HP OmniBook 6000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
