Question about Acer Aspire 5100 Notebook
Acer Aspire 9300 external monitor problem
While I'm waiting for a new inverter (laptop screen no longer lights up), I'm using an LG lcd display as an external monitor. When I try to watch a dvd movie, or click on something that will open up Windows Media Player, the whole screen is taken up by the movie and I lose the ability to do anything, and am stuck with that display screen, even when the file or dvd is done playing.
Pressing the Windows key doesn't help. Pressing the Esc key doesn't help. I end up having to press the power button to shut off the computer, then restart it.
Do you have any ideas?
  • 1 more comment
  • Aspire9300 Sep 04, 2008
    That didn't help. I was still stuck and had to do a force quit. Thanks for trying.
  • Aspire9300 Nov 16, 2008
    Finally solved the problem. Ctrl + W closes the player for me.
  • Daniel Jenkins
    Daniel Jenkins May 11, 2010
    hit alt-enter
  • 37 Answers
When that happens again try pressing alt+esc. If that doesn't help try changing the resolution or the refresh rate of the monitor.
Posted on Sep 23, 2008
I've tried to connect my laptop to a projector but i just get the information projected but cant be seen on my screen of the laptop
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 ASUS and Dell = Fn + F8
Mar 21, 2013 | Acer Aspire 9300-5349 Notebook
Trying to fix laptop screen that is whited out
Alex,
A primer first;
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Acer Aspire 5732z-4855 Notebook PC uses a single CCFL, according to all of the websites that sell the LCD screen. One example,
https://www.laptopscreen.com/English/model/Acer/ASPIRE~5732Z-4855/
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch, or about the width of this letter -> H
Average length is almost as long, as the LCD screen is in height.
A general example of a CCFL,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 8 photos ]
A screen Inverter is used to convert the power from the laptop, for the LCD screen, and Backlight.
(For a CCFL. Most generally LED backlighting does not use a screen Inverter )
Example of a screen Inverter used on the Acer Aspire 5732z series of Notebook PC's,
http://www.lcd-inverter.co.uk/screen-inverter.php/acer_aspire+5732z_lcd-inverter_6130.htm
Primer over.
Your problem could be the graphics chipset, Video Cable, screen Inverter, or LCD screen.
Diagnose:
1) Graphics Chipset;
Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
[ Left rear side has the VGA port. It is White in color. This is a general example of a VGA Cable, and VGA connector, (Port),
http://en.wikipedia.org/wiki/VGA_connector ]
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable attached.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on. By factory default the display should show on the external VGA monitor.
If not;
Hold the Fn key down, (Bottom row, second key from left), and at the same time tap once on the F5 key.
(The F5 key is the Display Toggle-Over key)
Still no display on the external VGA monitor?
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down again, and tap once more on the F5 key.
Good graphics (Display) on the external VGA monitor, means you have a good graphics chipset.
Bad graphics on the external VGA monitor, means you are looking at motherboard replacement.
Sitting here in this chair in front of my computer, I'm willing to bet your graphics chipset is OK.
If the graphics chipset is good your problem is the Video Cable, screen Inverter, or LCD screen.
2) Video Cable:
This is high on the list for being the 'culprit' of the problem.
Why?
Because of it's location.
The Video Cable connects to the top of the motherboard, in an area under the Switch Cover, and slightly to the right of the left Hinge.
It then routes UNDER the left Hinge, and up into the Display Assembly. From there it connects to the back of the LCD screen, and to the screen Inverter.
Just from normal opening, and closing of the laptop over time, the Video Cable may become pinched.
This can lead to pulling on the Video Cable, and may cause a loose connection at the motherboard side, or LCD screen side. Shouldn't be a loose connection at the screen Inverter.
This means the Switch Cover must be removed to check the connection, at the motherboard side. The Display Assembly is opened up, and connection at the back of the LCD screen is checked.
Visual inspection will do NO good. You CANNOT see usually if the connections are tight, or not. It is BEST to physically see if you can plug the cable connections in tighter.
Loose connections of the Video Cable are high on the list, for your kind of problem.
Next is damage to the Video Cable. See if there are any obvious signs of damage to the sheath of the Video Cable. Obvious damage to the sheath may mean damage to the tiny wires inside.
(Stretched/Broken)
Even if there are no signs of damage to the Video Cable, and if physically checking to see if the Video Cable's connections are loose, and this doesn't solve the problem; the Video Cable should be removed, and it's wires checked for continuity with a multimeter.
(You can take it to a 'Mom and Pop' computer store, and have it checked for a few bucks )
Video Cable checks out, the next hardware part in the diagnoses is the screen Inverter.
[Acer nomenclature for the Video Cable is LCD Panel Cable]
3) Screen Inverter:
The thin plastic frame in front of the LCD screen is the Display Bezel.
[Acer nomenclature for the Display Bezel is LCD Bezel.
The LCD screen is an LCD Panel.
Display Assembly is an LCD Module ]
The screen Inverter is located behind the LCD Bezel, and mounted towards the bottom of the LCD screen.
Testing requires a sensitive multimeter. Read fairly expensive,
http://www.fonerbooks.com/test.htm
If you do not have access to a sensitive multimeter, then the next course would be to replace the screen Inverter.
Due to the low price of a new one, this parts changing solution IMHO is feasible.
Screen Inverter is not the problem, then the problem is the LCD screen.
I believe your problem to be the Video Cable. Loose or damaged. If not then the screen Inverter.
This is a link to a free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Drop down to the subheading - Aspire 1200. (1200 in Blue)
Go down to the 9th line (5720G in blue), scroll across, and click on the blue - 5732Z
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (5732Z) it may take up to 30 seconds, before the first page comes up.
This is a direct link. If clicking on it does no good, then copy it, and paste it in your browser search bar. Then press the Enter key,
http://support.acer.com/acerpanam/Manuals/acer/2009/ServiceGuides/SG_Aspire_5732Z_5332_10192009.pdf
1) Removing the Switch Cover - Page 71
2) You MAY be able to split the LCD Module open, (Display Assembly), and be able to physically check the video cable to LCD screen connection.
If so go to Page 95.
If not remove the LCD Module - Page 73
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 06, 2012 | Acer Aspire 5732Z-4855 Notebook
Screen has gone cloudy?
Kevin, Kevin, Kevin,.....you should have posted your problem here first.
Primer:
A Backlight can be a CCFL, or a series of LED lights.
In regards to the Acer Aspire 7720 series of Notebook PC's, the Backlight is a CCFL.
(Approximately 2mm Wide, by close to the height of the LCD screen, Tall )
A screen Inverter is used to convert the power (Electricity) of the laptop, for the Backlight, and LCD screen.
http://www.cdsparts.com/p-97-new-acer-aspire-7720-7720g-7720z-7720zg-series-lcd-inverter.aspx
90 PERCENT OF THE TIME THE FAULT IS THE INVERTER.
The thin plastic frame in front of the LCD screen, (Resembles a picture frame), is the Display Bezel.
The screen Inverter is mounted towards the bottom of the LCD screen, and behind the Display Bezel.
This you already know. Posting for those who read this solution in the future.
Service Manual (Free),
Regards,
joecoolvette
Feb 26, 2012 | Acer Aspire 7720 Notebook PC
White horizontal lines running across laptop screen
I did not see any white lines, Simon, in the screenshot.
Just sayin'.
(Glad you tried to post it though!)
The problem is caused by a faulty Video Cable, or it's in the Display Assembly.
However, you better start the diagnoses with using an external VGA monitor, and see if the lines show up on the external monitor, also.
This would indicate a bad graphics chipset.
For most people that would mean replacing the motherboard.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA connector, on the Left side of the laptop.
Example of a VGA cable, and VGA port, (Connector),
You can use a external VGA monitor that is a CRT type, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
A1) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external monitor.
IF Not,
Press, and hold down on the Fn key, (Bottom left of Keyboard), and at the same time tap on the F5 key. (Top of Keyboard)
{The F5 key is the Display Toggle-Over key }
No?
There are at least 3 display options available.
3) External VGA monitor ONLY.
Graphics look good on external VGA monitor?
Your graphics chipset is good.
Problem is Video Cable, or in the Display Assembly.
B) Video Cable: (LVDS Cable)
http://www.insidemylaptop.com/disassemble-acer-aspire-7551g-laptop/
The above is for an Acer Aspire 7751G, but it is close enough to the 7750G models, and info should directly crossover.
Scroll down to Step 17.
The Video Cable connection to the motherboard, is shown by the yellow arrow at the Top Left.
Note, although the photo is less than, the routing of the Video Cable.
It goes through the Left Hinge.
(Then into the Display Assembly, and connects to the back of the LCD screen)
With normal opening, and closing of the laptop, the Video Cable could be pinched, or have been pinched. Could have been pulled on.
You close the laptop, the cable is slightly pinched in the Hinge, and it pulls loose from the motherboard connection, AND/OR the LCD screen connection.
Doesn't take much of a loose connection. In fact it's hard to discern with the human eye, sometimes.
Make sure this motherboard connection is tight.
You have to open the Display Assembly, and check the Video Cable connection on the back of the LCD screen.
Doesn't look loose? Try to plug it in tighter anyway.
Check the connection of the wire/s from the Video Cable, TO the screen Inverter.
The small circuit board behind the Display Bezel, (LCD Bezel), and mounted to the bottom of the LCD screen.
When on the motherboard side, the side of the Video Cable that runs through the left Hinge, is there any apparent damage? Damage to the sheath of the Video Cable?
If there is, chances are the tiny wires inside the Video Cable, are damaged also.
Check with a multimeter. Perform a continuity test of Each wire.
C) Display Assembly:
Video Cable checks out then the problem is in the Display Assembly.
1) Screen Inverter:
http://www.sparepartswarehouse.com/Acer,Aspire-7700-thru-9800,Laptop,Inverters.aspx
http://www.insidemylaptop.com/replace-broken-screen-acer-aspire-5745g-laptop/
Not your model, granted. Posted for the Display Assembly dis-assembly pictorial guide.
Primer:
A Backlight is a CCFL, or a series of LED lights.
Your laptop uses a series of LED lights for the Backlight.
A CCFL requires a screen Inverter.
A screen Inverter converts the power from the laptop, for the Backlight, and LCD screen.
NOT all LCD screens that use LED lights as a Backlight, use a screen Inverter. I suspect yours does not, as I can't find a listing for a screen Inverter, for it.
http://www.laptopscreen.com/English/section/FAQ/1245191276/Correct%20backlight%20type%20for%20your%20new%20screen/
This would mean that if the Video Cable proves to be good, the next step is to replace the LCD screen.
Shop around for the best price, AND make sure it is a direct replacement for yours.
Regards,
joecoolvette
Feb 12, 2012 | Dell Inspiron Computers & Internet
Hi, im from Kota Kinabalu and have this acer aspire 4315 with NO display (Dimmed display) . It is working fine when i use an external monitor. Fyi, i have a 2 unit used working fine power inverter and lcd...
unfortunatly there are three pieces involved in the dimming of the screen. 1) the lcd (you tried that) 2) the inverter (you also tried that) and 3) the motherboard. I had the same thing happen with my daughter's acer. I bought her a new computer and sold the laptop for parts.
Motherboard replacement on these are a pain.
Sorry for the bad news ... Good luck
Nov 29, 2010 | Acer Aspire 4315 Notebook
Acer dark screen problem
your problem is a faulty ccfl BackLight Inverter, the display uses the backlight to illuminate the lcd screen, the inverter is used to illuminate the cold cathode light in the back of ther lcd theirs countless places to laern about it on google.
They are cheap to replace google your model with inverter at the end..
I cannot say how many I have replaced in Acer systems
I know for a FACT this is the problem. They are cheap inverters.
When you replace this one i would expect it to last longer :)
Jul 10, 2009 | UltraLast ULAC3660L For Acer Aspire...
The screen on my Acer ASPIRE 9300 has turned orange -
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 16, 2009 | Acer Aspire 9300 Notebook
Acer 9300 black screen at start, tried some things, didn't work.
The cables to the LCD and the Inverter board may not be hooked up correctly...
I have manual, I can email it to you. joediaz911@comcast.net
Apr 05, 2009 | Acer Aspire 9300 Notebook
My acer 9300 when switched on shows a blank screen (black with some faint white back ground) but the process of starting windows goes normally coz i can view this when connected to a monitor whats a miss ?...
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Mar 25, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 9303WSMi - 17" LCD Screen is showing coloured static..
More like the LCD Inverter Board..a loose connection would not cause that, unless you pulled the video cable by openening and closing the lid, but again that too is highly unlikely..
Jun 03, 2008 | Acer Aspire 9300 Notebook
Acer Aspire 5100 Notebook Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
