Question about Oracle 10g Database Standard (ODBSEONUPP0)
Oracle date problem
I have an Oracle date problem I want to use in the where also a time filter not just a date filter, how do I add it?
select count(*)
from table
where DTTM > '10-Jun-08';
Thank you.
All dates are actually date-time fields - if you don't specify the time, Oracle defaults to midnight. To filter date-time specify the date-time string as a formatted field like this:
select count(*) from mytable where dttm > to_date('20080610181907','YYYYMMDDHH24MISS');
This is the date June 10, 2008 at 6:19:07 PM as an example.
Posted on Nov 28, 2008
I originally istall oracle 10g in my d drive now
you can uninstall by using settings > control panel > add/remove programms and select 1og otherwise have CCleaner software to remove 10g
Nov 10, 2009 | Computers & Internet
Transforming birthdates into year codes
Here is a solution that might work for you. Please be mindful that there are several different solutions that will achieve the same thing in Excel (I am assuming Excel is your software).
1) Make sure each column in your spreadsheet has a heading.
2) Highlight (select) the column of birthdays.
3) Choose Format from the menu bar.
4) Choose Cells... from the drop-down menu.
5) For the "category", choose Custom.
6) In the "type" box, type yyyy
7) Click OK and when you return to your spreadsheet, you will see only the years displayed. However, when you try to edit a cell, you will see that the entire birth date is stored and preserved.
8) Now, highlight the entire table
9) Then, choose Data from the menu bar
10) Choose Subtotals... from the drop-down menu
11) In the "At each change in" box, choose the name of the column with the birth dates
12) In the "Use function" box, choose Count
13) Leave all other choices at their defaults
14) Click OK, and you are done.
Using this method, you can continue to enter the data as you always have. In that way, the birth date info is never actually destroyed or converted. What you are doing is simply deciding what is displayed.
I hope this helps.
Aug 02, 2009 | Microsoft Office Excel 2007
In excel how to display date in previous cell, a hyphen, and the end of that month
I'm not sure exactly what you mean, but you can highlight the cell that you want, right click, select "format cells", select "date" in the "numbers" tab and scroll through a bunch of different options for displaying the date.
Jun 08, 2009 | Oracle Database Enterprise Named User Plus
I have a column A with repetitive dates. Column B with repetitive names Example: 05/01/09 a 05/02/09 b 05/03/09 a 05/01/09 c 05/04/09 a 05/01/09 d 05/03/09 c I want to count how many a,b,c,... I have for...
Use 3 pivot tables, put a, b, and c in the row areas and "Count of a", "Count of b" and "Count of c" in the data sections. That will give you a count of each date for each column
Apr 28, 2009 | Microsoft Computers & Internet
Linking tables in Oracle
While I'm not saying it's not possible, it's not something Oracle (Or any relational database) is designed to support, so don't be surprised if this isn't possible or extremely difficult.
Relational databases support predictable relationships. IE: Table 1 relates to Table 2 in a given way.
Relational databases do not support varied relationships depending on the data in each row. The query engines simply can not join data this way.
If you provide me more details about your data, I might be able to propose a table structure that doesn't require a different table for each row of data in ROOT.
Feb 12, 2009 | Microsoft Computers & Internet
Steps in saving file in excel to database
severals solution :
- save file as text separated by comma and use sqloader from oracle
- use function in excel to concatenate insert order : "insert into TABLE_NAME (field1,...,fieldn) values (A1,B1,...,??n);". Save file as text with sql extension. Connect against roacle db and execute file previously saved.
- use ODBC from MicroSoft
Dec 11, 2008 | Microsoft Computers & Internet
How to print only selected fields in ms access.
open your table in query, follow steps to do this...
1. open new query in access
2. locate the table
3. once table selected, select field name in selected table you only want to include in query
3. once finished selecting the field save the query
4. you can now view selected field in your table and print as well
5. you can edit the query anytime if you want to add or remove field
6. query will not affect your table since this is only query.
hope this will help you....
Oct 22, 2008 | Microsoft Access 2002 for PC
Microsoft Access Query
Your date form is what it wrong. In order to use dates in Access with a BETWEEN function clause the values have to specifically be dates.
You can create dates in literal strings using the # sign to bound them, as in:
Select DISTINCT [ActivityDate] between #1/1/08# and #12/31/08#
#....# tells Access to treat this literal string as a date.
If you are using non-literal values, such as a parameter handed into the query, which would then be a variable, you can't use #some_variable# to cause Access to view it as a Date since #...# is for literal values only. To convert (also called "casting" a variable), use the CDate function. CDate likes to know what format to expect the string to come in though so it helps to pass that along, as in:
Select DISTINCT [ActivityDate] between CDate(begin_dt_string) and CDate(end_dt_string)
Remember the date string you pass into CDate has to be readable as a date by CDate. So make sure you pass in something that it can handle (use the IsDate() function to check to be sure so you can avoid a runtime datatype casting error). If your locale is US, then passing in x/y/z it will take for MM/DD/YYYY. If Europe, it will take it as DD/MM/YYYY. So keep that in mind.
To convert out of a date, use the FORMAT() function. That is how you get a date data type value to become a string value.
More fun reading:
http://www.techonthenet.com/access/functions/datatype/cdate.php
http://www.techonthenet.com/access/functions/advanced/isdate.php
http://www.techonthenet.com/access/functions/date/format.php
Hope this helps!
Feb 11, 2008 | Microsoft Office Access 2003 (077-02871)...
Oracle 10g Database Standard (ODBSEONUPP0) Logo
760 people viewed this question
Top Oracle Computers & Internet Experts
CNewton2
CNewton2
Level 1 Expert
cwradio73
Bonded Repair
Are you an Oracle Computer and Internet Expert? Answer questions, earn points and help others
