Question about Canonical Ltd. Ubuntu
Ubuntu Screen Problem
Installed Ubuntu 8.04 (hardy) the screen resolution looks like it has a problem, I'm trying to change it, but I can't find where to do so. I don't want to uninstall just because of this problem, there must be a solution for this, please tell me how to change the screen resolution.
Thank you.
  • 122 Answers
Try resolution change or refresh rate look in system files i know linux is hard the first time unbuntu forums .com helped me a lot a lot of questions answered there just trying to help with some sites i used without typing answers and don't want to confuse you
Posted on Jan 05, 2009
Acer aoa 150-1570 netbook, win7 ultimate CLEAN install, dual boot to Ubuntu 11. Orig HDD replaced with a clean 500GB HDD, Clean Installed W7U 32bit from Ext ODD Boot. The screen is partial [an 800x600...
akberztech
Note sure if you have the steps to manually change your display settings in Windows 7 but the link below will help you do this.
http://www1.fixya.com/support/r4290529-change_windows_7_display_settings
After checking these steps and you still have trouble look to see if Sony has a Vista 32 bit driver for your computer because in most cases the Vista drivers will work with Windows 7.
Let me know if you have any more problems or quesitons
Issken
http://www.fixya.com/users/issken
Sep 04, 2011 | Acer Aspire One AOA150-1570 Notebook PC
I have a desktop PC with HP v72 monitor and a GeForce FX 5200 video card installed. I uninstalled Windows XP and installed Ubuntu Server 11.04. The problem is that after the initial boot screen my monitor...
why run server, , sure you actually want a server.. sure.
Linux, run the newest Ubuntu on new pc
or older on older pc, ive no idea at all what PC you have.
v72 old CRT , glass tube monitor a RELIC in today world.
why post OS questions lacking what HP computer you have of 1000s.
XP gone great idea, for sure....
OK F8 is Microsoft , for get them it not MS now, not at ALL.
in the Linux world its failing to find the correct minimum or
best resolution to match your old monitor
the monitor is year 2000.
the best resolution is 1024 x 768
you are using new linux, and it does not use that old old CRT
weak as a cat resolution,
you can use and older linux, or newer monitor
or change the resolution
using
if seen and done this 100s of time, endless,
btw your OLD CRT monitor does not use proper PnP plug and play
data comms.. its too old, why mess with CRTs in 2017?
walmart sells a $45 LCD , use that? and avoid darkages resolutions.
the way to do this is to run in command line mode
and change the config file, called, xorg.conf
https://techblissonline.com/ubuntu-804-set-default-resolution-1024-768-virtual-pc-2007/
there are other ways,
recompile the kernal to default to this reso? relic
or there is hot key at boot, read the manual on ubuntu
and change to lowest poor resolution
then run setups with a working desktop.
ask on a Ubuntu forum, it can vary by year, OS made and version
and what what desktop running of the many.
https://wiki.ubuntu.com/X/Config/Resolution#Resetting_an_out-of-range_resolution
keep in mind
your CRT is not supported now.
you must force it.
one more for V12, dropped the startup manager, wow....
best is to ask only for your version and choices at install time.
grub , KDE? what?
http://ubuntuguide.net/monitor-signal-out-of-range-problem-in-ubuntu-12-04-precise-fresh-installation
Jun 11, 2017 | HP V72 17" CRT Monitor
My screen resolution is changed when i installed ubuntu 9.10. It is not detecting my monitor.
your systems graphic may be Nvdia graphic,try to start in recovery mode or command line and install nvdia drivers manually in command line.
Jan 12, 2010 | Canonical Ltd. Ubuntu
Screen size
I think you will get an answer hre
http://ubuntuforums.org/
Oct 03, 2009 | Philips 150S (White) 15" LCD Monitor
Screen resolution too low.
You will need to compile the drivers. This is difficult but not impossible. Plenty of information on the Ubuntu Forums regarding this.
Aug 21, 2009 | Computers & Internet
Ubuntu 8.04 Sound is Very Distorted HELP!!!
You need to add the following lines to /etc/apt/sources.list file or you need to make sure you have enabled Universe and multiverse repositories in /etc/apt/sources.list file
sudo gedit /etc/apt/sources.list
Make sure you have the following two lines save and exit your file
deb http://archive.ubuntu.com/ubuntu hardy universe multiverse
deb-src http://archive.ubuntu.com/ubuntu hardy universe multiverse
Now you need to run the following command to update the source list
sudo apt-get update
Install mplayer using the following command
sudo apt-get install mplayer
if you want to open mplayer just type
gmplayer
or
You can Open from Applications—>Sound&Video—> Mplayer Movie Player
Install libdvdcss2 and w32 video codecs in Ubuntu 8.04 (Hardy Heron)
Support for WMV, RealMedia and other formats has been bundled into the w32codecs package. This package is not available from the Ubuntu repositories due to licensing and legal restrictions.
For Ubuntu 8.04 (Hardy Heron) Users run the following command
sudo wget http://www.medibuntu.org/sources.list.d/hardy.list -O /etc/apt/sources.list.d/medibuntu.list
Then, add the GPG Key using the following commands
sudo apt-get update
sudo apt-get install medibuntu-keyring
sudo apt-get update
For i386 Users install Codecs using the following command
sudo apt-get install w32codecs libdvdcss2
For amd64 Users install Codecs using the following command
sudo apt-get install w64codecs libdvdcss2
Using above download locations you can install most of the mutimedia codecs for ubuntu.
Mplayer Plugin for Firefox
If you want to install Mplayer with plug-in for Mozilla Firefox run the following command
sudo apt-get install mozilla-mplayer
Apr 21, 2009 | Canonical Ltd. Ubuntu
Trying to run ubuntu
It sounds like Ubuntu chose a screen resolution that your monitor doesn't support. For the sake of sanity, I would a reboot and then try booting to Windows to ensure that what camone311 suggests happened isn't so -- I doubt it, as the install process is more involved than just 1 click - there are SEVERAL variables (time, date, username, passwords, how much of the hard drive to use, etc) that have to be set before anything is written to the hard drive.
If you're able to boot to Windows, then I would boot back to the CD and give it another go. At the menu where it says Try Ubuntu... there's an option to change the graphics modes - I would try safe graphics mode or VESA to see if that fixes the black screen problems that you were having.
Jan 05, 2009 | Computers & Internet
Intrepid Ibex Beta
If you are using a laptop, yes, it is better. Mainly due to some more driver support for wireless and bluetooth. I do not think there is any performance increase, just more hardware compatibility.
I use ubuntu 8.04 Hardy on a PC, there would be no need for me to upgrade at this time.
G'luck
Oct 05, 2008 | Canonical Ltd. Ubuntu
Ubuntu Screen
The same way you set it on any Linux.  If you don't like the gui setting controls in look/feel, feed in boot commandline options or go into /etc/x11/xorg.conf and throw in a few likeable resolutions and restart X.
   These answers are totally in the bundled notes and documentation, not to mention the Ubuntu wiki; why ask here if as if something is broken in a unique way?
Sep 10, 2008 | Canonical Ltd. Ubuntu
Canonical Ltd. Ubuntu Logo
315 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
none
Dennis Gutowski
Dennis Gutowski
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
