Question about Palm LifeDrive Handheld
Frontal buttons pressed through cover
When I use the cover that comes with the LD, frontal buttons normally are pressed and the LD swithes on; is there any way to avoid it?
    Master:
  • 542 Answers
Your problem with the default case is common. Frankly, it is poorly designed. What I did (before I bought a replacement) is switch the power to the locked position when I put it in the case.
Posted on Sep 15, 2005
Leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Mar 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Ld code appears intermittantly
ld is a long drain time...you may have something in he drain or a bad inpeller in the drain pump...it is taking too long to drain out
Sep 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Dryer will not turn on although the timer is working
IF your hearig a click when you push the start button then the button and relay are good check the saftey switch on the door to see if it has come loose and follen down or moved back if the switch is not pressed the motor will not work also I have seen the switches go bad you need to unplug the dryer and cross the too wires togeather plug the dryer back in and press the start button if she starts order a new swith. The motor could also be bad you nees to remove the back cover and check to see when the button is pressed if you are getting the correct voltage you will need a volt meter to check this they cost around 10- 20 bucks if you have correct voltage from the wires and the conections to the motor are ok the motor is no good and needs to be replaced hope this helps...
Jul 07, 2009 | Kenmore Dryers
My dvd doesnt open even if I try from My PC.... I cant acces to me DVD manual openig button because is under the frontal cover of the ACER ASPIRE E 500 how I can remove the frontal cover??
I'm not shure how acers are put together as far as the outside of the pcu. It is probably plastic catches on it. look on top and bottom of it. there might be screws. if not there are plastic pieces holding it on.try to pry it open a bit. take a flash light and see if you can see how it is attached. Good luck.
Jul 01, 2009 | Acer Aspire E500 PC Desktop
Sharp LD-26Sh3U menu locked
RELEASING THE ADJUSTMENT LOCK
Perform this procedure using the buttons on the TV.
1: Turn off TV
2: While pressing the "MENU" button press the "POWER" button continue to press the buttons until "UNLOCK ADJUSTMENT" appears on the screen.
3: Press the "VOL >" button.
That's it you may have to turn the unit off then back on at the end of step #3.
May 18, 2009 | Sharp LD-26SH3U 26 in. LCD Television
Hard reset
1 Hold down the power (on/off) button on your device. 2 While holding down the power button, turn over your device so that you can see the back of it. Still holding the power button, use an unfolded paper clip or a similar small object, to gently press the RESET hole on the back. 3 When the Palm Computing Platform or Palm Powered logo appears, release the power button. 4 A message will appear warning that you are about to erase all the data stored on your handheld.
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
Your problem with the default case is common. Frankly, it is poorly designed. What I did (before I bought a replacement) is switch the power to the locked position when I put it in the case. To perform a hard reset, push the reset button while holding up on the 5-way.
Hard reset
Sep 15, 2005 | Palm LifeDrive Handheld
Palm LifeDrive Handheld Logo
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
