Mother board jumpers setting
Sis mother board jumper setting please let me see how to setting jumpers on the sis mother board 962 lua model no
  • 2 more comments
  • Anonymous Sep 06, 2008
    burned intel p4 2.8Ghz processor, so i found 2 used working replacement p4 processors (one is 2.8 the other is 2.6Ghz) none of them orks in my motherboard witch is a matsonic ms 9357e with sis 962 Lua, in other cpu these processors work ok the p4 2.4Ghz processor of this cpu operates in my cpu what can i do to correctly install my new p4 2.8 or 2.6 processor on my cpu ?
    i believe there is no jumper or deep switch config, and cpu config in bios is set to automatic!
    thanks
  • Anonymous Sep 07, 2008
    Everything is working ok except i have no sound
  • Ravel Lively
    Ravel Lively May 11, 2010
    First of all get your terminology right. Your processors are your CPUs. And what you are trying to place them on is called a ' motherboard '.
    Robert is right, you need to re-type your questions using correct terminology. If we tried to explain anything to you now, you would most likely try to install a motherboard onto another motherboard and then you would give us an IA. No way buddy, get your facts straight, then come back.
  • Roberta Smith
    Roberta Smith May 11, 2010
    please retype the model of the motherboard again
    Robert
6100 disply not working
Posted on Mar 14, 2009
Hoi, kan iemand mij misschien helpen aan een schema of iets waar ik kan zien hoe de jumpers zitten op moederbord van ASUS PSGD 1-VM.. a.u.b. mailen als dat kan naar mastiff070@hotmail.com.
alvast vriendelijk bedankt.
Posted on Oct 20, 2009
  • 981 Answers
Better yet, learn to search for manuals using search engines and at the makers' websites, and read the manuals.  Then explain how you burned a CPU with built-in thermal protection, or just fix what you've done wrong there.  That's all there is to it.
Posted on Sep 10, 2008
Were can i get a manual for jumper settings
Dear,
you don't need to find out manual for jumper setting any where if you see the mother board very closely near which Jumper want to setup you can see the printed jumper setting on mother board only,
Thanks with Regad,
Ankur Goyal
Sep 10, 2015 | MSI Ms-7104 Pm8m-v Via Socket 478 Intel...
I can't find the jumper on my dell inspiron b130
Hi,what type of jumpers do you mean? if you want to clear your bios you can use jumpers calls "CLR-MOS" or "CL-ms" or "cms_clr" that it means CLEAR CMOS or CLEAR MOS (stands for mosfet transistors built in mother board eeprom" you can clear it this way:
shutdown the pc or laptop find the jumper pull the backup battery up use a screw driver or an iron pin to short the jumpers together(if you dont find the jumpers after pulling up the battery short the battery+- together) wait 10 sec and then pull in the battery after that you have to go to your bios setting and set some data if you dont you may see errors like this in your screen before windows start up:
"DMI POOL DATA CHANGED" PRESS F1 TO continue" or something like that;
and if you dont know the bios setting ask from experts to do it for you because this setting is too dangerous and may harm your hardware,if you dont know dont touch it,
and one more thing:
if you mean another jumpers?dont touch it because some mother boards use jumpers for their settings or you may harm your hardware
kind regards
Apr 18, 2013 | Computers & Internet
Thoshi satellite L40 bios password reset
open *********** board battery some time or " mother board battery
inside 3pin jumper switch. open this jumper middle pin to other pin connect some time 1 minute & jumper set previous position.
or" see mother board battery
inside reset switch.
May 28, 2012 | Toshiba Satellite A105-S2071 Notebook...
HP G61 no power
inside reset switch
May 28, 2012 | HEWLETT-PACKARD G61-306NR Notebook
Failed to unlock HDD System Locked
What you need to do is unplug pc, open up the door panel to your pc and remomo cell battery from mother board then find the jump pins on the mother board they look just like the one in back of the hard drive. The jump pins are connected with a jumper similar to the pins jumper that sets up your hard drive to master, cable select, or slave. You need to reset the mother board the way you do that is by removing that pin jumper and replacing the cell baterry then the pin jumper. If done correctly you will reset your motherboard password setting and bios allowing you to boot your operating system. If you need help google your pc manufacture and model number and search mother board jump pins. Or email me with your pc info to andreioneluv@yahoo.com , and I will try to help you find it. Please rate if this was helpful...
Jun 08, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
Mobo Jumper settings for BX pro PC100 Motherboard
*********** board sounds like the same as a Fujitsu board.
D1115
moz-screenshot-1.pngthe user manual can be found at diplodocs
It shows the jumper settings and board layout for a Fujitsu motherboard.
I hope this helps. Have a great day
Mar 18, 2010 | Computers & Internet
Power connector
if you look real closley at the motherboard the pins have identifications right next to them if not the manufacture of the motherboard and they will have the diagram online
Aug 22, 2008 | Computers & Internet
Jumper settings
It all depends on the motherboard model and manufacturer. You may want to lookup motherboards manual on google.
Oct 31, 2007 | E-Machines T1090 PC Desktop
Computers & Internet Logo
1,405 people viewed this question
David Payne
David Payne
