Question about Fujitsu fi-4530C Pass-Through Scanner
Fujitsu fi-4530C Sir, We have Fujitsu fi-4530C DUPLEX COLOR scanner when we are trying to scan some documets but its function screen show F hence can't scan the document please suggest? Thanks
    Problem Solver:
  • 16 Answers
Hi
F at power on is a ROM Error. sounds like a main board issue. check for dry joints, but may need the whole board replacing.
Posted on Sep 16, 2009
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
www.fujitsu.com/downloads/.../scanners/.../fi-5650c_ops-guide.pd...
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error Messagesmy.okidata.com/man-OF5650.../006B738F6240C3BF8525678500678C...Make sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Zealandwww.oki.co.nz/support/printer/.../index.aspxOki Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
Fi-6130z continueously scans. It doesn recognize when there is no paper to be scanned
Your scanner went crazy. If you don't want to take it to repair, just disconnet it after you've finised scanning
Oct 09, 2014 | Fujitsu fi-6130z - Document scanner -...
Black line 6130
Are the scan settings correctly specified for the scanning application software used? Check if interface cable are correctly connected.When the error occurs on ADF front, clean the glass inside of Base Unit. When the error occurs on ADF back, clean the glass of the Upper Unit.Check if any dirt get on the white reference sheet?
Also, check the mirror of the OPT Unit dirty, clean the mirrors.
Check the connector and check any cables are damaged,if so, then replace the damaged cables.
If the above doesn't help, then the issue may be due Optical unit or Control PCA problem. hence, you may have to seek the help of Fujitsu scanner technicians for rectification.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Apr 25, 2013 | Fujitsu fi-6130 duplex scanner
The computer recognizes the scanner and successfully installs the hardware. But when I go to use the scanner to scan a file through an online site the driver disappears from the bottom right corner. What...
may be a firewall is blocking it from internet access. check all types of firewalls . better stop them for a period and check it once again. hope that will fix your problem.
Feb 01, 2011 | Fujitsu fi-4530C Pass-Through Scanner
I hope someone knows of an fi-4530c driver capable
Please be informed currently Windows-7 64-bit supported version of TWAIN & ISIS drivers for your Fi-4530C model is not yet released by Fujitsu. For more information, please visit the following link:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/index.html#twain
You may also contact Fujitsu Support for further assistance.
Thank you for contacting FixYa.
Regards,
TechSatya
Aug 01, 2010 | Fujitsu fi-4530C Pass-Through Scanner
Fi-5750C Fujitsu scanner can't change grayscale default setting
Photoshop is not an "advanced" scanning program. To get some "production" and value out of this expensive scanner you need a professional scanning program which also may control the settings of the scanner. Use PixEdit which utilizes the built-in jpeg compression in the scanner. Did a test scanning 10 pages A4 duplex fullcolor. Adobe Acrobat Pro used 4 minutes. PixEdit used 20 seconds. Guess Photoshop (in your version) would also scan uncompressed and not use this good scanner optimal.
Jun 26, 2009 | Fujitsu fi-5750C Flatbed Scanner
Can only scan simplex or duplex
The scanner can scan in either simplex or duplex mode only. If blank page is scanned, then it will appear BLANK, else someone would say, my scanner is not scanning properly! Remove balnk pages using software or sort on file size and delete the small sized files. Take care to ensure they are really blank.
S. Mohan, India
Nov 20, 2008 | Fujitsu fi-5110C ScanMaker Scanner
How to Default Duplex Scanning
  1. Image Scan Can not be Found.
  2. please check and Cable connection
  3. and the scanner is not used by other application.(Code:DS42019)
THIS THREE ERROR WILL SHOW AT MY SCANNER.
AFTER PUT GHOST IT WIL SLOVE.OTHERWISE WIL NOT SLOVE.
COULD U PLS GIVE SOLUCATION
Jul 02, 2008 | Fujitsu fi-4120C Path-Through Scanner
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
Fujitsu fi-4530C Pass-Through Scanner Logo
249 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
