You will not find a manual for that small REFLECTOR style telescope. However the picture above-- that you show in your question shows the telescope mounted BACKWARDS actually pointed toward the ground!
Apparently FIXYA also does not know how to set up a reflector style telescope. The eyepiece and focuser end is on the UP end of the telescope with the mirror on the bottom end of the telescope.
Here is a manual for a MEADE brand telescope probably very similar to your telescope.
This is a small reflector style telescope. They all assemble the same way. I will give you a web link for a similar Meade brand scope that you can use to assemble your telescope.
You will not find a TASCO telescope. However Meade maintains a web site with all of their manuals. Look under REFRACTOR or REFLECTOR for one that is similar to your telescope. They all go together and work in a similar fashion.
There are only two types of telescopes --- REFRACTORS, and REFLECTORS-
The refractor has a lens on the front of the tube and you insert different eyepieces in the back-- the larger the number written on the eyepiece the LOWER the magnification-- (DO NOT USE THE 2x or 3x barlow which you may have!-- this creates too much power for this small telescope!-- put it away and never use it!)
A reflector has a main mirror on the bottom of the tube, and a small secondary mirror under the eyepiece hole (focuser end) - front end-- put the lowest power eyepiece into the focuser.
Now with either type telescope go out side during the day and practice focusing on a distant object-- turn the knob SLOWLY. At night the moon should be the first target you try.
If you received what appears to be a smaller telescope -- that is the finder scope-- attach it to the top of the tube on the main telescope. Again during the day line up the small finder scope with the main scope-- look at a distant telephone pole (the very top-- and center this in the main telescope. Without moving the main scope use the finder scopes "screws" to adjust the cross hairs so they are pointing exactly where the main scope is pointed. Now you can use the small finder scope to point the telescope in the exact direction--
